05-25-2021, 01:24 PM | #45 | |
21
Rep 66
https://f30.bimmerpost.com/forums/sh....php?t=1621134 |
Stlblues68.50 |
05-25-2021, 06:08 PM | #46 | ||
Rep 5,392
05-25-2021, 06:15 PM | #47 | ||
Rep 5,392
05-25-2021, 07:17 PM | #48 | |
21
Rep 66
Side note: These current measurements, is with more fuel than the before measurements. I'll remeasure in a week to see if the springs settle out, and the gas will be near the same amount then. Driver Front: Before 10.5cm -> After 8.9cm Total drop = 1.6 cm Passenger Front: Before 10.6cm -> After 8.6cm Total drop = 2 cm Driver Rear: Before 11.2cm -> After 9.3cm Total drop = 1.9 cm Passenger Rear: Before 10.7cm -> After 8.9cm Total drop = 1.8 cm As for the -05 not dropping more than the -06 part number. My guess would be the springs may need some time to settle, and the old springs and struts were original with over 80K km on them, so maybe they had more of sag to them as time went on! Did your Eibachs springs settle at all? |
05-25-2021, 08:28 PM | #49 | ||
Rep 1,649
05-25-2021, 09:23 PM | #50 | |
21
Rep 66
Driver front: 36cm Passenger Front: 35.7cm Driver rear 36.3cm Passenger rear: 35.9cm Would like to know other measurements on lowered f30 xdrives! |
05-26-2021, 08:36 AM | #51 | ||
Rep 5,392
2015 335i Xdrive |
F30xn553.50 |
05-26-2021, 08:51 AM | #52 | ||
Rep 5,392
Use a four foot long level and some blue painters tape. I put blue painters tape across the top of the fender lip. Then line up the level vertically on the ground so that its edge goes through the center point of the BMW wheel logo. Make sure the bubble in the level is in the middle. Then mark on the blue painters tape, the exact vertical spot on the lip. Then measure from wheel centerpoint to mark on painters tape on fender lip. The wheel centerpoint never changes since it's the center of the wheel hub. So it's always perfect reference point if trying to compare how much a suspension has been raised or lowered. Just make sure that you used this same method to getting starting points at all four wheels with the stock suspension. Even if two guys had the exact same wheels, if they use the top of the wheel rim as their measuring point, their measurements might not be comparable. That's because they could have different tires at different air pressures. If their measured tire diameters aren't exactly the same then even with identical wheels their measurements aren't comparable. Always use the wheel centerpoint to take drop comparison measurements! Hope this helps! |
F30xn553.50 |
05-27-2021, 01:26 AM | #53 |
Rep 15
I am also looking to get the 06 or 05 springs, do you have any pictures of how your car sits?
eibach, f30, h&r, springs |
