BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > BMW F20: Problems with electronic power steering
      12-08-2023, 11:42 AM   #1
Alessiof20
Drives: bmw serie 1 f20
Hello guys, has anyone ever had problems with electronic power steering?? I have a bmw f20 120d Msport, I recently had to replace the steering box as it was damaged... The steering box I mounted was complete with motor so initially I mounted it with its motor. From there I only had problems because the car didn't recognize the new motor so the power steering light came on and the motor only turned on via the diagnosis, that is, as soon as the ignition was turned off and on again the motor no longer turned on unless again through the diagnosis. The diagnosis showed the error in the EPS coding. The mechanic, therefore, unable to code, presented me with two options: to have the new motor coded in BMW or, alternatively, to reassemble the old motor. We tried to reassemble the old motor and the power steering light disappeared, but the motor grinds on the belt as soon as it comes into operation..
      12-08-2023, 05:06 PM   #2
No one
Drives: F21 118i
Hello.
So what's your question? I had my steering rack replaced, luckily on a BMW recall, for free . As you should see already, you chose wrong: the car has to be re-programmed for the new steering rack. Now you might need another one and try again. Your mechanic should be responsible for failing to implement the option you chose, of course.
      02-29-2024, 04:24 AM   #3
mfractal
VAG Survivor
mfractal's Avatar
40
Drives: E90 335i
isn’t it just a coding issue ?
F10 535i LCI, Hybrid Turbo, Custom Inlet, Spool FX-150 Pump HPFP, TI Automotive LPFP, DV+, Phoenix IC, FTP CP, High Flow Cat, M5 Mufflers, Custom Tuned By David Shoup.
      02-29-2024, 01:17 PM   #4
DomMuc
DomMuc's Avatar
506
Drives: G87 M2
inside the rack is the EPS ECU .. newly installed ECU (EPS-Rack) needs to be coded and programmed to the Car and Cars i-step level
