BMW M3 Forum (E90 E92)
BPM
      03-31-2024, 01:21 PM   #1
DetroitP
16
Drives: E92 M3
ABS Fault - Wheel speed sensor - Front left active fault (not reading)
Hello: An ABS fault appeared for the front left wheel sensor and as result I have replaced it with a new sensor. That didn't fix the issue, thus, I moved the sensor to the right side to see if fault code moves and it didn't. Then looking through my Schwaben datalogger for all 4 wheel speeds, I see all 3 reporting data while moving in straight line, expect for the front left as indicated by the fault code. However, If I turn or drive in a circular pattern then the faulty wheel speed does read. Any idea what may cause the speed sensor not read while driving in straight line?
Vehicle: 2008 E92 M3, 140k miles, DCT transmission
Active fault codes:
5D91 - DSC: wheel-speed sensor plausibility, front left.
5D96/not present: DSC: wheel-speed sensor direction of rotation front-left
5D90/present: DSC: Wheel speed sensor power supply
many thanks in advance
      03-31-2024, 01:52 PM   #2
Brandoch
Brandoch's Avatar
481
Drives: 2009 E93 M3 DCT
Active fault codes:
Have you looked at the wiring? Sounds like a possible broken wire, loose connection, or corrosion.
      03-31-2024, 03:37 PM   #3
DetroitP
16
Drives: E92 M3
Yes, I have checked the wires & connection multiple times and everything seemed sound. The only thing I am suspecting at this point is the wheel hub, but I am not aware of how to check it. Any ideas before I attempt to purchase a new hub?
Thanks for the input
      04-01-2024, 11:32 AM   #4
DetroitP
16
Drives: E92 M3
bump
      04-16-2024, 08:42 PM   #5
DetroitP
16
Drives: E92 M3
Update:
I replaced both front wheel bearings and problem still persists. Any other ideas?
Thanks
      04-21-2024, 06:59 PM   #6
DetroitP
16
Drives: E92 M3
Another update:
I pulled the fender liner, and checked the connections and wires. No visible damage of any sort. Any other suggestions I can try?
Thanks in advance
m3post
