TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > I cloned my MSV70 DME
      09-13-2014, 12:58 PM   #1
hassmaschine
Drives: "NBO" 330i
I couldn't resist - I have all the tools (BDM) and know how, so why not?
$75 test subject picked up off ebay (from a 2006 530i):
that white goopy stuff is seriously annoying. I'm guessing it's some sort of heatsink compound - even slighting touching it will get it all over your fingers. ugh.
also the other side of the board I hadn't seen before, some seriously large capacitors:
Perhaps to drive the valvetronic motor? that's my guess.
Added BDM header, did a full dump just to have a backup:
Pulled my DME. People say to unplug the battery, but my experience is that's actually a bad idea. the DME won't care, but you'll reset every other module in the car. just be careful and for god's sake don't try to turn it on, lol.
added BDM header to my original DME to make my full dump:
download my original files:
Upload to the test mule:
Now this is the part I wasn't sure about. Would the CAS need re-aligned? Would I have to recalibrate anything? the answer is no! I plugged my original DME in first to make sure it would start, and it fired right up. Then I swapped it with the test mule, crossed my fingers (after spending 10 minutes looking for my key), and it fired right up as well!
next I'm going to cut a hole in the case of the test DME, make a longer ribbon cable and then I can write to it from inside the car without having to take it out. If I ever want to go back to stock all I have to do is put the original DME back in, but as far as the car can tell, it's exactly the same anyway.
and now that I have a dump of my stock maps, it's time to start digging and tweaking.
Appreciate 10
      09-13-2014, 01:20 PM   #2
avocet
Drives: 2007 328i 2011 X5d
Lol. Damn smart people.
Appreciate 9
tsm00764.50
Pinscher112.50
Indyeah141.00
CDirks135.00
      09-13-2014, 01:23 PM   #3
hassmaschine
Drives: "NBO" 330i
I think people are too afraid of these cars, seriously. The turbo motors are always going to get all the attention from tuners and the aftermarket - but there's lots left on the table of the N/A motors, and I doubt any of the big tuners have done anything new in some time. it's like we're perpetually stuck in 2007.
and fortunately for us, BMW didn't lock these things up like MSS60 and the newer ones that are all encrypted.
Appreciate 5
      09-13-2014, 02:54 PM   #4
dtea604
dtea604's Avatar
28
Drives: 06 E90 325i
Ur ballsy and way damn smarter then I am. Round of applause for even attempting.
      09-13-2014, 03:31 PM   #5
Mike.
Mike: Everyone's Pal
Mike.'s Avatar
2044
Drives: F80 M3
2013 BMW 335xi  [10.00]
mess with the valve lift
Alpine MSS Stage 2+ E30 tune|MST Intakes|VRSF Single Mid Pipe|Agency Power Intercooler|VTT Full solution crank hub fix
      09-13-2014, 03:37 PM   #6
hassmaschine
Drives: "NBO" 330i
I intend to. My wife's E91 325xi could use a bump in torque/hp.
now to figure out how to sneak her DME out so I can clone it too... lol
there are other things I want to do, I think the engine is a bit nerf'd just after 6500rpm. it seems like it falls way harder on it's face than it should, I don't think it's VE related, I think BMW purposely cuts timing and fuel, sort of a soft rev limit. I also think a lot of the adaptations are extra aggressive to deal with people who run 87 octane.
There's a billion maps/settings, but just perusing I saw the DISA activation stages, rev limits, top speed limit, injector constants, maximum ignition retard maps, etc. I didn't specifically see valve lift yet but it's in there somewhere.
      09-13-2014, 03:42 PM   #7
Neckbreaker
Drives: E90
what does this do ?
      09-13-2014, 04:14 PM   #8
hassmaschine
Drives: "NBO" 330i
what does what do? I took a used DME and made a clone of my original DME. now I have 2 that I can swap into my car. One to tinker with and one that I can rely on to get me to work on Monday morning if (when) something goes wrong.
Just did a quick compare between the 530i and 330i maps. Basically 80% the same but the 530i was an automatic so that's probably where most of the differences are.
      09-13-2014, 04:57 PM   #9
Mike.
Mike.'s Avatar
2044
Drives: F80 M3
make your own tune and sell it!! haha
      09-13-2014, 07:13 PM   #10
Taskmaster
Japan
2465
Drives: M235i 6MT / E92 328 Msport 6MT
From looking at all these N series dyno s over the last year, the 325i looks to cut lift/power after 6300RPM - but I don't believe there ia much left on the table. I would be surprised if you picked up 4whp over an existing tune. Headers and valvetiming changes are probably be the big gainers anyhow.
      09-13-2014, 07:27 PM   #11
DesertBMW
Drives: 1996 328i with N55 engine
I did try this one time and it did not work. There was checksum error.
      09-13-2014, 08:03 PM   #12
hassmaschine
Drives: "NBO" 330i
I checked them after i flashed it and they were all fine. Did you modify anything? I flashed 3 different chips.
      09-13-2014, 09:36 PM   #13
e90ben
e90ben's Avatar
27
Drives: No more Beemer
dear hassmaschine
Congrats! You're on your way to silence the critics
      09-13-2014, 10:01 PM   #14
hassmaschine
Drives: "NBO" 330i
Maybe, I'd like to log the DME while on a dyno. It feels like it should pull strongly all the way to 7000rpm.
      09-13-2014, 11:16 PM   #15
playground
Hong Kong
32
Drives: M3
What are you using to work on the DME?
WinOLS? How much did you pay for the cables and data for the MSV70 and 80?
Become like water my friend.
      09-14-2014, 12:10 AM   #16
hassmaschine
Drives: "NBO" 330i
A hex editor and tunerpro. WinOls demo version can be used to read maps.
      09-14-2014, 10:48 AM   #17
e90ftw
39
Drives: G87 M2
Good stuff
      09-15-2014, 02:30 PM   #18
playground
Hong Kong
32
Drives: M3
Nice. You have to devirginize the previous DME right?
      09-15-2014, 02:43 PM   #19
hassmaschine
Drives: "NBO" 330i
no. When you flash the full dump from the original DME, it erases everything on the clone during that process. It's like copy and paste from one DME to another, albeit a little more complicated than that.
virginizing would be a difference process. You'd have to know what sectors of each memory chip to zero out. but since you can copy everything verbatim from one to the other, there's not really any point in doing that.
      09-15-2014, 07:11 PM   #20
Taskmaster
Japan
2465
So what is the difference between the MSv70 and MSV80?
      09-15-2014, 08:59 PM   #21
hassmaschine
Drives: "NBO" 330i
Newer software, slightly different hardware. I'm pretty sure you can do the same thing with msv80, as long as it has a working bdm port.
      09-15-2014, 09:18 PM   #22
hassmaschine
Drives: "NBO" 330i
On further reading, msv80 has a tricore cpu. So you need something that can get into boot mode and read the internal flash of the cpu.
