Oil Life Monitor Programmed to Stop at 186,000 Miles - UPDATE 7/2016
11-10-2017, 09:12 PM | #199 |
General
17381
Rep 18,774
The problem is you then learn to ignore the ding when there is a real issue at hand. Like a low fuel warning. Don't ask...
cliffschum15.50 |
11-10-2017, 10:15 PM | #200 |
1208
Rep 2,835
Oh my car gets absolutely obnoxious when it thinks it is below 35 miles to empty. Warning in normal gauge cluster and warnings at bottom of iDrive screen and BINGS all over.
11-21-2018, 08:25 PM | #201 |
Robot
1691
Rep 2,193
I wanted to share my experience with resetting the E90 oil service reminder. When I first bought my car it had 218K miles (yes, call me crazy for buying a high mileage BMW but the price was right) and I immediately did an oil change. The reminder reset and showed 4300 miles until the next oil change. At around 222k miles I changed the oil again and I wasn't able to reset it. I tried several methods, using the BC stick on the left side of the steering wheel acted like it reset but after the clock symbol the remaining mileage didn't change. I tried tool32 on my laptop and while I confirmed it incremented the oil service reset count, it never actually cleared anything.
I was reluctant to take my car into a dealership to have the oil service programmed out so I used the instructions in the PDF attached to the first post in this thread along with ISTA+ software to remove the oil service indicator myself. I spent more time waiting for my laptop to boot than it took to perform the coding. It's literally just navigating a few menus and takes a few seconds to execute the job. NO MORE OVERDUE OIL CHANGE REMINDER! It was also removed from the iDrive display - previously the first row had the oil change but that's gone now. |
10-10-2020, 07:22 AM | #202 |
Rep 109
08-27-2021, 11:47 AM | #203 |
15
Rep 78
I think this is happening to my car as well now. 2006 E90 330i. I had the last oil service done at BMW at about 222k miles. Right now it has about 224k miles and the oil service will only reset to zero but counts backwards, or negative. I just found this thread and just ordered a scan tool but i was hoping to:
1. read the code with a scan tool, possible deactivate it if supported 2. Talk to (waiting for a call back) from my local BMW about the bulletin and see if they will deactivate it free, showing the bulletin 3. pursue DIY deactivate with some type of software. I still have to look at this post in full, but it looks like there isn't another problem elsewhere, like I originally thought, with a level sensor or pressure sensor. Also the last two posts had members with similar mileage as mine, which i found strange and nowhere near 300,000 kilometers |
08-28-2021, 09:13 AM | #204 | |
General
17381
Rep 18,774
Just get the software patch coded, that is the only thing your car needs.
08-28-2021, 05:22 PM | #205 |
15
Rep 78
Okay tool32 or insta? Which is more user friendly if I have neither ? Thanks for following up, you’ve been great at being on it. Glad it doesn’t need a real repair at least.
08-29-2021, 07:31 AM | #206 |
General
17381
Rep 18,774
I don't know. I had a dealership do mine. Look over on the Coding subforum. Several guys over there figured it out a few years back.
11-02-2021, 10:28 PM | #207 |
Rep 11
Will you still get an accurate oil level read.
Even with the engine oil quality or life no longer working, when you get the check engine level "Inactive" signal.....does it still read the oil level correctly?
11-08-2021, 03:13 PM | #208 | |
Robot
1691
Rep 2,193
If you're getting "Inactive" on the oil level menu, there's a problem with something on the BSD bus. That isn't related to the oil change interval. I actually had this happen to me - started seeing "Inactive" when checking the oil level (long after I disabled the CBS oil change interval). I initially thought I had a bad oil level sensor, however when I scanned the codes using ISTA+ it provided the diagnostics procedure which required disconnecting the devices on the BSD bus one by one until the bus was functional again, with ISTA+ monitoring the status in real-time. Water pump, alternator, oil level sensor, and intelligent battery sensor (IBS) are the four things connected to the Bit Serial Device (BSD) bus. In my case once I disconnected the water pump the bus was functional again, and replacing the water pump fixed the problem. |
01-11-2023, 10:14 AM | #209 |
16
Rep 78
FWIW, this glitch seems to slowly fade..
At 242K, my oil Life warning alert no longer appears all the time. Sometimes system check reads “ok”, with no red triangle. Occas I can even reset oil life monitor (to 22K, for example), but it doesn’t last for more than a few miles. Yes, it’s a software glitch, an inconsistent one at that. Original oil level sensor is still working fine.. |
10-02-2023, 08:52 PM | #210 |
82
Rep 201
It is set at maximum 25 lifetime resets. At which point you can no longer reset the intervals and have to code it out. I’m about to do this soon on my e60 at 221,000 miles
10-11-2023, 07:11 AM | #211 | |
General
17381
Rep 18,774
Matt Z34.50 |
10-21-2023, 07:21 AM | #213 | |
Rep 583
it is indeed shameful that you were placed in the spin cycle with no apparent off-switch to get out....i too would be if the customer service "professional" on the phone call provided me with the SAME PHONE NUMBER that i had just called. why would BMW intentionally design a process to eliminate OCI @ 300K K's? did they think no one would achieve high(er) mileage? |
Efthreeoh17381.00 |
11-08-2023, 06:36 PM | #214 |
255
Rep 2,547
Does anyone know if Carly can be used to program this feature?
01-11-2024, 09:33 AM | #215 |
Rep 1
Curious if anyone else is seeing this based on number of oil changes or even overall time? Our 2011 328i won't reset anymore. It only has 93K on it, but since around 2016 it's been getting less than 5K a year and I've been changing it yearly. I've changed it 9 times starting at 56K. I'd have to check the records from when the car was still under the BMW service, but I don't think there were more than 3 that BMW did so I'd say it's been 12 changes max.
