Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > 16" or 17" winter tires for 330i
      09-20-2009, 05:30 PM   #1
jrougeux
jrougeux's Avatar
Drives: 2006 330i - 6SPD ZSP ZPP
I'm about to buy a set of winter wheels/tires for my 330i, which currently has the staggered 18" wheels and RFT summer tires that come with the sport package.
Two choices to make here for the winter set up:
#1 - 16" or 17" wheel
#2 - 205mm width tires or 225mm width tires
I live in Kentucky, so I won't be driving in the snow constantly. But we always have a few ice/snow storms that will completely disable a BMW with summer tires! They will go on the car in late November and come off in early March.
I am considering going with a 205/50R16 setup, as this would be the least expensive. This is the OEM size for the 325i.
Any reason to go with the 17" wheel or the wider tire?
2006 330i - 6MT ZSP ZPP
      09-20-2009, 05:33 PM   #2
remmib
General
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
You need 17" because 16" wouldn't fit over the brakes on the 330i.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      09-20-2009, 05:54 PM   #3
jrougeux
jrougeux's Avatar
Thanks! Good to know, I was about to order some 16's.
Any thoughts on the 225/45R17 tires vs the 205/50R17?
      09-21-2009, 06:11 AM   #4
remmib
General
remmib's Avatar
Norway
1568
I've got 225/45/17 tires with no problem in the snow. I think most have 225 tires, can't remember seeing many 205/50/17 on e9x in here.
      09-21-2009, 07:34 AM   #5
Nikos335i
Nikos335i's Avatar
Greece
92
Drives: 2012 B8 S4 & 2013 F30 328xi
2012 Audi S4  [9.00]
2007 E90 335i  [9.00]
2011 Audi A4 Avant  [10.00]
Agreed most run 225-45-17. I run Toyo Garrit KX tires in this size.
'12 B8 S4 Ice Silver on Black/Premium/DSG/Sport Diff/Nav/Carbon Inlays/19' Titanium Wheels/RS4 Grill/AWE exhaust/Alu Kreuz/H&R OE/Pagid RS19
'13 F30 328xi Sapphire Black/Coral Red/Sportline/gloss black with matte red/Style 397 18" wheels
gone: '07 E90 335i, Alpine White/Black with aluminum/sport/ steptronic/paddles/premium/Logic7
gone: '06 E61 530xi Sapphire Black/Black with aluminum/premium/panoramic sunroof/Logic7/PDC
      09-21-2009, 08:22 AM   #6
jrougeux
jrougeux's Avatar
But wouldn't the 205 tire provide better bite in the snow? The 325i/328i base models come with a 205/55R16 tire stock, so it's not like the 205 width would be too narrow for the car...
      09-21-2009, 12:58 PM   #7
Gary@TireRack
Moderator
Gary@TireRack's Avatar
Drives: Formerly 1995 M3
If they both are the same brand and model of tire, the 205/50R17 should have a slight (but not huge) advantage in loose or deep snow. On packed snow and ice there should be little difference.
Winter
http://www.tirerack.com/a.jsp?a=AH8&...nter/index.jsp
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp
Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum.
      09-21-2009, 05:50 PM   #8
jrougeux
jrougeux's Avatar
Winter
Thanks Gary, I will be going with the 225/45R17 tires.
I noticed that tirerack.com has the Dunlop SP Winter Sport M3 ROF and the Bridgestone Blizzak LM-25 RFT within a couple of dollars in this size (runflat).
Do you recommend one over the other?
      09-22-2009, 12:07 PM   #9
Gary@TireRack
Moderator
We consider these to be pretty equal to each other, with perhaps a slight advantage in snow traction with the LM25.
      10-30-2009, 08:13 PM   #10
alsamtu
Drives: 2009 323i
From my experience up here in Ottawa, Canada, the larger the aspect ratio the better in snow. As far as ice is concerned, nothing works.
So Gary from TireRack is partially right. And because when it snows, it does not snow "ice" all the time, I would go for the 50s.
16", 17", tires, wheels, winter
