      01-28-2018, 06:53 PM   #155
walkie86
Frog Lover
Australia
69
Drives: 2006 E87 130i
IMG_2536 copy by autofocus .net.au, on Flickr
My automotive adventures: AutoFocus.net.au
Current: '06 Le Mans Blue 130i 6MT | '01 RS Clio I 172
Ex: '05 RS Clio II 182 Cup | '08 RS Clio III 197 | '14 RS Clio IV 200 Sport Trophy | 2x '01 RS Clio II 172
      01-29-2018, 12:42 AM   #156
awhc
Australia
Drives: E85 Z4 3.0si
I read the standard headunit system in 130i does not allow music to be played, it can only do phone calls. Will the 130i with iDrive allow music to be played over bluetooth?
      01-29-2018, 05:01 AM   #157
walkie86
Frog Lover
Australia
69
It's got an AUX-in point but for bluetooth I believe you need an LCI model.
awhc7.00
      01-29-2018, 06:15 PM   #158
MJS130
Drives: 2007 BMW 130i M Sport
Originally Posted by walkie86 View Post
Hey mate - I ran 225/40 front and 255/35 rear. Looked fantastic but probably a bit too much tyre on the rear, especially with uprated front sway bar leading to more understeer. They're the same size rims as stock 135i rims, which run a 245 on the rear from factory I believe.
Stuck with the 17s and went 225/45 front and 235/45 rear. Potenza Re003 all round, love them on my wife's megane so went with them. Going from 215 to 225 in the front has reduced understeer, definitely feels more balanced to me. Wider rears does look nicer though
      03-07-2018, 02:33 AM   #159
awhc
Australia
Hey Walkie did you only get the Subframe Nolathane bushes?
Any other bushes worth swapping out? Differential bushes, control arm bushes etc.
      03-07-2018, 04:44 AM   #160
walkie86
Frog Lover
Australia
69
Hey mate, yes I only did the rear subframe bushes. My car feels pretty tight at 100k km so haven't felt the need to play with any other ones just yet.
      03-07-2018, 05:02 AM   #161
awhc
Australia
Ah alright, did you buy yours locally in Sydney?
I've also been struggling to find an N55 muffler called ASV Euro Parts, Exotic car parts, went to place in Seven hills. Where did you get yours?
      03-12-2018, 06:23 PM   #162
walkie86
Frog Lover
Australia
69
Gumtree for the exhaust mate, they pop up from time to time.
I bought my bushes online from somewhere like Ezi AutoParts.
      05-30-2018, 07:10 PM   #163
walkie86
Frog Lover
Australia
69
Organised a group run last Sunday morning. Good mix of cars turned up! 130i still going strong the other blue 130i in the photos is Nathan's/Brintech's recent S65 swap
IMG_2844 copy by autofocus .net.au, on Flickr
IMG_2856 copy by autofocus .net.au, on Flickr
IMG_2861 copy by autofocus .net.au, on Flickr
IMG_2894 copy by autofocus .net.au, on Flickr
IMG_2868 copy by autofocus .net.au, on Flickr
woosh212.00
      06-05-2018, 08:54 AM   #164
woosh
woosh's Avatar
Australia
212
Drives: rs
The GT3 would've had fun behind that Mazda3 #bumpertobumperaction
      06-06-2018, 06:59 PM   #165
walkie86
Frog Lover
Australia
69
The 3 was perhaps the quickest car on the day, judging by its tyre wear, whilst the GT3 had under 2k km on it from memory (991.2 manual!) so wasn't pushing beyond about 5/10th
      06-07-2018, 05:50 AM   #166
PG
PG's Avatar
Australia
41
Drives: 2008 135i
is there anyway to get involved in the group runs? I have driven past you guys a few times near the blue mountains on my own runs
      06-07-2018, 07:41 AM   #167
walkie86
Frog Lover
Australia
69
Message me on instagram mate, I have a few DM groups for runs on there:
http://instagram.com/autofocusaus
      08-19-2018, 02:39 PM   #168
hks200
Drives: N/A
unfortunately not, the best I could do was get a working USB unit from a E84 X1. Easiest way to get bluetooth streaming in a 130i is via a small usb powered bluetooth receiver that is plugged into the AUX.
Gone--- 02' ABP ITR 6MT | 06' BSM 130i 6MT - RIP | 99' Altezza RS200Z 6MT | 02' WRX STI 6MT
      08-19-2018, 02:42 PM   #169
hks200
Drives: N/A
This is a great photo! Glad I managed to get on this run and take your car for a spin walkie86 need to get myself back in a BMW asap!
      08-20-2018, 03:03 PM   #170
Aus335iguy
Aus335iguy's Avatar
Australia
650
Drives: 2009 e92 335i MSport DCT
2009 BMW 335i  [10.00]
There's some android based touch screen units that are getting pretty good. You can find them on the Chinese eBay for about 500au landed. If you have idrive its easier otherwise you need to cut the dash.
When you doppelkaplung you doppel your fun.
      01-13-2023, 02:25 AM   #171
moebiuz
moebiuz's Avatar
Colombia
106
Drives: BMW 130i
Few small updates.
BMS spacers - 10mm F / 12mm R (bought used, 12-months old)
BMS E-chassis extended bolts (bought new)
BMS 'Short throw clutch stop" (bought new)
IMG_1602 copy by autofocus .net.au, on Flickr
IMG_1594 copy by autofocus .net.au, on Flickr
Front before
IMG_1600 copy by autofocus .net.au, on Flickr
Front after
IMG_1607 copy by autofocus .net.au, on Flickr
Rear before
IMG_1596 copy by autofocus .net.au, on Flickr
Rear after
IMG_1603 copy by autofocus .net.au, on Flickr
Rear before
IMG_1597 copy by autofocus .net.au, on Flickr
Rear after
IMG_1604 copy by autofocus .net.au, on Flickr
IMG_1608 copy by autofocus .net.au, on Flickr
BMS Short throw clutch stop. I had to remove one spacer to get enable the car to start with clutch engaged.
IMG_1610 copy by autofocus .net.au, on Flickr
IMG_1612 copy by autofocus .net.au, on Flickr
Overall, the BMS spacers seem very high quality and the looks are improved greatly. It still looks "factory" but just better. The clutch stop removes a little bit of travel but I guess it won't really make a difference until fast shifting on a mountain run.
I also bought 12mm spacers for the rear but im rubbing quite badly... :/ did you modify anything? I have style 313 wheels which are the same offset and width as your 269. Hope you still check this forum lol
      01-13-2023, 02:29 PM   #172
asbrr
545
Drives: 2014 335ix M-Sport
Yes, 12mm is not good in the rear. I used to have the same setup, I ran 12mm at the front and 10mm rear. Still had to slightly fold the bumper tab where it meets the fender a bit at the rear. I was lowered slightly on a Bilstein B12 kit.
For 17" winter sizes I'd swap the 12mm to rear and 10mm front and had no issues (215 width winters).
So long story short, there's not much room and 12mm for sure would rub in my experience on big bumps.
      01-20-2023, 07:33 AM   #173
bobowar135
bobowar135's Avatar
Australia
3479
Drives: 08' Sedona Red 135i
I was originally looking for a used 130i because they were a good compromise between the sedate 125i and the more balls out 135i. Unfortunately the 130i was pretty much non-existant on the Australian used car market, so my balls got to breathe some fresh air.
Esteban43818.50
