TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > General BMW X5 (E70) and X5M Forum (2006-2013)
      04-06-2022, 10:45 PM   #45
Kdawg550GT
Drives: 550iGT
Originally Posted by bad///Mechanic View Post
I'm interested in those as well but not sure which check valves fit. Could you post a link to the ones you got? Also interested in what you had to do to modify the flapper.
Is the CCV similar between N63 & S63? Sorry I'm sure that's a noob question. But I'm a noob!
b///M
N63 considerably different. At least mine is. I have the first gen 2010 n63. Here are the jegs one way valves. Open them up. You’ll see a small white flapper. I tweaked the spring so it just hangs there. I marked the top of valve so I knew where the top of flapper was when I installed.
https://www.jegs.com/webapp/wcs/stores/servlet/SearchResultsPageCmd?q=+555-150023&storeId=10001&catalogId=10002&langId=-1
      12-29-2022, 01:26 PM   #46
JellyStyle
Builder of Special Cars
JellyStyle's Avatar
202
Drives: G12 B7,F02 750li,E70 X5M,E46M3
Location: Dallas, TX | Farmington, UT | Gainesville, FL
S63 isnt the same as this N63 setup
Folks - the E70 S63 (X5M), compared to the E70 N63 (X5 5.0i) has a connected bypass between the driver and passenger sides. I followed this entire thread, and I see where all the connections are going, but with an S63 for the same years (2010 to 2013), it's different.
Has anyone installed Sophisticated Redneck setup on an S63 and eliminated the bypass across the top between the two sides? Any issues with it?
Any input would be greatly appreciated.
Joe
      01-02-2023, 06:31 PM   #47
Drives: 2012 BMW X5 50i
Joe
No need for the crossover tube when you install the catchcans, I sent ya a PM with more info and will dig up the pics on where to cut the CCV lines on the s63 and send to you and post them in this thread also for reference for anyone else thinking of the mod.
argento538.00
TTV8M123.50
      01-02-2023, 06:56 PM   #48
JellyStyle
JellyStyle's Avatar
202
Thanks so much for the help and clarification, I ordered all the parts per your post about the mod.
      01-03-2023, 12:33 AM   #49
No problem happy to help
      01-03-2023, 12:37 AM   #50
Below are pics on where to cut the CCV tubes on the M. From there you can install the -8an male fittings as mentioned earlier in this thread. You can use a 3/8" npt tap to make it easier to thread in. Make sure you use a 3/8" npt tap and not just a normal 3/8" tap. There is a huge difference between the two.
      03-29-2023, 02:09 PM   #51
jdrex
Drives: 2011 BMW X6
N63 warning
Just wanted everyone to be aware that the aftermarket replacement parts are defective. The original part has a breather hole next to the one way flapper. This breather hole is missing on the aftermarket parts sold everywhere. Please see image of the original part I uploaded here....
      06-17-2023, 10:05 PM   #52
dew62
Drives: x8m
Hello a question on the catch can does it have to be a 3 port or 2 going to buy a baffled unit .
      06-27-2023, 09:55 AM   #53
Lilian242
Drives: Bmw X5M E70
  [0.00]
Who can Send me pic for s63 catch can
      06-29-2023, 09:30 AM   #54
JellyStyle
JellyStyle's Avatar
202
Sophisticated Redneck - is building them, you can PM him.
      06-29-2023, 11:44 AM   #55
Lilian242
Drives: Bmw X5M E70
  [0.00]
I cant Send pm
      07-01-2023, 02:38 PM   #56
JellyStyle
JellyStyle's Avatar
202
I cant Send pm
because you have a new account, likely spammer. ha
      07-04-2023, 03:38 AM   #57
Lilian242
Drives: Bmw X5M E70
  [0.00]
Sophisticated Redneck Send pm
      07-22-2023, 07:52 AM   #58
punisher12b
32
Drives: 2011 135i
If I am reading this right we only need about 6ft of 8an and 4ft of the 6an correct the links are showing like 16ft
also is it critical to run the Vac gauge at road speed? can it just be set for idle? or to many variable? just trying to piece together everything..
      07-23-2023, 10:40 AM   #59
JellyStyle
JellyStyle's Avatar
202
buy from Sophisticated Redneck and get it done right, otherwise, you're ging to do a ton of back and forth with a range of opinions, Troy is the only dude that did all the testing on vacuum and proper pressure balancing, he makes the kits now, with special M mounts that are CNC'd
      07-26-2023, 12:28 PM   #60
WalletH8sMyX5
Drives: 12’ X5 x35i
Would this work for an n55 engine ?
      08-08-2023, 07:46 AM   #61
punisher12b
32
Drives: 2011 135i
I think he is VERY busy, as I have reached out.. i amazoned his entire list posted... I can return and buy from him though ... but I need to do it sooner than later.
      08-08-2023, 08:44 AM   #62
JellyStyle
JellyStyle's Avatar
202
He is busy, working on all the machining for the new CCV setup that allows no plastic adapters. you can make the current version without the nice machined adapters but I'm waiting for his skilled work to be done. See pics, this is how much he's doing for the CCV setup for the valve cover adapter for the N/S63, it should be ready in a week or two, once he gets a few sets anodized black along with the mounts.
along with video of how its made:
Along with the mount for the Catch Can's themselves too.
Give me 2-3 weeks and he can make more, i assure you its worth the small wait.
RL18273.50
Dave0037.00
      08-09-2023, 07:36 AM   #63
punisher12b
32
Drives: 2011 135i
That is nice.
      08-09-2023, 04:44 PM   #64
REVELDE_89
Drives: X5M
SIGN ME UP!!!! Ill take a prototype version if it gets me one of those bad boys sooner!
      08-09-2023, 06:20 PM   #65
JellyStyle
JellyStyle's Avatar
202
will post to the thread when pics are ready, pre-anodizing, and post, should be no more than 7-14 days depending on the shop once they have in hands.
      08-14-2023, 06:33 PM   #66
9kracing
I like to party
9kracing's Avatar
Drives: E46 Dinan S3-R
I'm in for a S63 kit
xbimmers
