BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30 328i 335i Front Kidney Grill / Grille removal and replacement DIY
proTUNING Freaks
      01-25-2016, 07:58 AM   #199
Jason954x
Jason954x's Avatar
123
Drives: 435i xDrive
Weather is decent today, so I did mine.
      01-26-2016, 11:10 AM   #200
marcw
marcw's Avatar
Drives: 2021 M2 Competition
Did mine on Saturday.
      01-26-2016, 11:21 AM   #201
marcw
marcw's Avatar
Removing the bumper cover seemed crazy to me. Too many things that could go wrong, so I removed the grills by just going through the slats. I used an old PC expansion slot cover to give me leverage especially with the bottom clips. I started with the passenger side working my way from the right side counter clockwise. The top clips are easier to reach than the bottom ones. Only the first one is hard. Getting out the second one took less than 30 seconds.
      02-10-2016, 01:53 PM   #202
RedKloud
RedKloud's Avatar
737
Drives: BMW i4 M50
Sorry for bringing an old thread back, but I have to tell this to everyone who will listen: I'm not a DIY guy at all, and was able to change both gills in under 10 minutes, without removing the bumper cover or using any tools. And the old grills are perfectly intact.
Finally some benefit of having puny forearms and hands!
      03-04-2016, 09:07 PM   #203
hollandog
hollandog's Avatar
Drives: F30
2016 BMW 340i  [9.00]
Originally Posted by smithf32 View Post
I had to break my old ones off due to extreme cold lol.
It was so cold in NY when I got my grills that the bumper would not flex enough for me to fit my hand in there after removing the 6 top screws or so.
Only other option was from the front but I couldn't get my hands in there good enough to actually release the clips, so I went ahead and cut two of the slats out LOL! I figure I can leave the black grill on on return in 3 years or I can just buy one right side grill, it won't kill me.
I will recommend people just don't even bother to do this when its freezing cold out. I came close to breaking a tab on the bumper itself due to lack of flex and one of the plastic pieces from the grill getting bent and then stuck in one of the clips. If I didn't break it then I came damn near close LOL but I'm pretty sure I did not because my grills sit perfectly flush.
It's 35F outside now I was trying to take out the grill. snapped one of the blades and wasn't able to remove the grill......
Damn it I might just break a few more blades and release the grill with fingers.
Who knows this is harder than I was expecting.
      03-05-2016, 09:30 AM   #204
hollandog
hollandog's Avatar
Drives: F30
I think because of the cold temperature, ~33F this morning. The plastic is not flexing enough.
Used some brutal force to get that mfkin clip off.
Ripped it apart. Straight to the trash.
      03-17-2016, 12:58 PM   #205
XKxRome0ox
e90noob
XKxRome0ox's Avatar
Drives: '08 E90 M3
who carries the best aftermarket black kidney grilles?
      03-17-2016, 01:15 PM   #206
hollandog
hollandog's Avatar
Drives: F30
OEM is $99 from ebay.
      04-04-2016, 05:44 PM   #207
bimmer_girl89
bimmer_girl89's Avatar
88
Drives: 2020 F39 X2 xDrive28i
I am a girl and have small hands. I was able to do this switch without using other tools other than my hands
      04-04-2016, 07:17 PM   #208
ErkanTR16
64-bit
ErkanTR16's Avatar
Drives: 2018 BMW 340i xDrive
Got mine from ECS Tunning.
https://www.ecstuning.com/BMW-F30-34...lle/ES2707739/
      04-13-2016, 03:06 PM   #209
HKColter
Drives: '16 F36 4GC
Originally Posted by Dyl View Post
Great thread.
Battled trying to do this yesterday without research. Checked this thread half an hour ago and 15 minutes later it's done. Easy.
Oh and here is a pic of my black 4GC with it done because i've not seen many images of them on a black f34/6
I'm thinking of doing this for my '16 4GC. Was the process much different or fairly similar to the F30 instructions above? Any help specific to the F36 would be appreciated. Thanks!
      04-13-2016, 05:10 PM   #210
Dyl
Dyl's Avatar
433
Drives: 4GC
Totally the same way of doing it. I'm really glad I did, it looks great on my GC...
      04-13-2016, 06:53 PM   #211
the_man_in_blue
75
Drives: It's blue.
Easiest mod ever.
      04-13-2016, 07:39 PM   #212
HKColter
Drives: '16 F36 4GC
Thanks for sharing, Dyl! Yours looks great. I'll have to order the grills and get it done.
      05-12-2016, 11:12 AM   #213
etinifni
etinifni's Avatar
Drives: 2012 328i Modern Line
Nice
      06-01-2016, 07:02 PM   #214
Clift
Drives: 2015 328i M-Sport
Less than 15 minutes using an ECS grill. Thanks for the instructions.
      08-23-2016, 07:49 PM   #215
anselansel
35
Drives: 2021 430i
I did this the other day. I tried the way described and it was PITA. I then took wd 40 and squirted it on all the latches. started to pull on it and it came right out. The SA at the dealership said thats how they do it. I was shocked at how well it worked. Kinda scary but it came right out super easy..
      10-21-2016, 01:50 AM   #216
Kabrich
Drives: '13 AH3 (335IH) 3F93 MSport
Originally Posted by 1.fresh.f30.335 View Post
Hey guys,
This is a quick guide to removing and replacing your kidney grills.
Estimated Time: 15-20 minutes
I hope this helps answer any questions and Good-luck![/size]
This was so much easier than I was expecting thanks to your instructions and pictures. I figured 15-20 minutes was going to be needed just to get 1 grille out. Then the entire process actually took last than 10!
Many Thanks!
Originally Posted by the_man_in_blue View Post
Easiest mod ever.
Agreed
      12-28-2016, 04:10 PM   #217
maxdriver
maxdriver's Avatar
88
Drives: ‘23 GRolla; MDX S
I was able to loosen up the top and sides of the stock grill with my fingers, but was having no luck with the lower. I read up some more and decided to go with the WD 40 and attempt to pull it out...it worked! Thanks for all the input from other forum members - greatly appreciated!
      02-18-2017, 05:43 PM   #218
turbocomppro
turbocomppro's Avatar
59
Drives: 2022 M340i
I just did mines on a 2016 328i LCI. There are 2 additional clips on the sides for a total of 8 clips. If you look at the OP's pics, you can actually see there are holes for the 2 clips on the side. After loosening the top clips, you must loosen the side clips in order to loosen the lower clips. Otherwise, you may think it's stuck and try to force the lower piece out and break something. Just a FYI.
      03-26-2017, 10:44 PM   #219
maxdobe
maxdobe's Avatar
Drives: BMW
So glad I found this thread!! I'm going to try the easy wd40 methods others have had success with, sans tools. I'm shopping around for carbon fiber grills for my f36 440ix GC.
Is Anybody here running cf grills? My front splitter is OEM cf so thinking the match may look good. Bummed bmw doesn't make the accessory part. I think I landed on giving RW Carbon's cf grills a shot. Never ordered from them before so we'll see how it goes.
      05-09-2017, 06:52 PM   #220
GTBrandon
GTBrandon's Avatar
Drives: 13' M3 Competition
What type of paint and clear coat sprays is everybody using
Current: 12' E70 X5D | 04' Yamaha Warrior
Past: 13' Audi S6 | 13' E70 X5M | 13' E92 M3 Comp | 14' BMW 335xi GT | 95' E36 M3 | 84' BMW 733i | 06' Porsche Boxster S | 15' Jeep Grand Cherokee | 06' Acura TL |
85' Honda Shadow VT700 | 05’ Yamaha R6 | 12’ Triumph Tiger
3 series f30, 3 series f30 forum, 3 series forum, 3-series forum, bmw 3 series f30, bmw 3 series forum, bmw 3-series f30, bmw 3-series forum, bmw f30, bmw f30 3 series, bmw f30 3-series, bmw f30 forum, diy f30, diy guides f30, f30 3 series, f30 3 series diy, f30 3 series diy guide, f30 3 series forum, f30 3 series grille, f30 3 series grilles, f30 3-series, f30 3-series forum, f30 diy, f30 diy guides, f30 forum, f30 forums, f30 grill, f30 grill diy, f30 grille, f30 grilles, f30 grills, f30 kidney grille, f30 kidney grilles
