TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > General BMW X5 (E70) and X5M Forum (2006-2013)
      04-03-2024, 10:01 AM   #1
xTrEeMx
Drives: BMW X5 E70 4.8i 2007
BMW X5 E70 4.8 - Rough Idle and Misfire at cylinder 8
Hi there guys, i have an issue with a X5 2007 4.8i.
Before changing the chains, oil pump and everything on the engine.. there was a missfire at cylinder 1. (This was before a year ago). After changing everything, car was working fine, until started saving misfire at cylinder 8 with errors:
These two comes together
2E2B
2D32
And sometimes with 55C3 - which i consider is the lack of the engine power.
After driving it for like a week or more.. but sometimes it could occur day after day... gives these errors: Spontaneously.. i've reset the adaptations of the throttle body.. also the body is clean. Coils, Spark plugs are good.
2CF0
2CF1
2CF9
2CFA
2CF8
2D00
2D13
I am thinking about the harness that goes to the throttle body. I saw that it is an issue on these cars.. With INPA it shows when saving the errors that:
Voltage throttle valve potentiometer 1 - 0.86V
Voltage throttle valve potentiometer 2 - 4.20V
Is this okay or it means i am correct about the harness ?
With all these error car has rough idle.
After cleaning the codes.. car works just fine with no symptoms of any issue.
xbimmers
