BMW X3 Forum
BMW X3 Forum
      03-08-2024, 10:32 AM   #1
Wgosma
Drives: 2012 F25 X3 28i (N52)
Rear Brake work...
Has anyone used the BimmerLink/BimmerCode app's 'Brake Service Mode' to retract the caliper pistons for replacing pads? I think the last time I did rear pads I removed the parking brake electronic motor from calipers and manually wound to retract. Just interested to know if the service mode thing works well.
      03-08-2024, 01:17 PM   #2
Opie55
1195
Drives: '15 650i Convertible
It works fine, but there are multiple posts saying that it gives a message that it didn't work. Some sort of software glitch. That happened to me, too. But you know it worked because you can hear it.
Wgosma806.00
      03-09-2024, 07:20 AM   #3
HPR
HPR's Avatar
Drives: 2015 X3 35i M Sport
I've used it and it worked just fine. No error messages or anomalies.
Pat
2015 F25 X3 35i M Sport - Carbon Black
Wgosma806.00
      03-09-2024, 03:14 PM   #4
BIG_KID
BIG_KID's Avatar
68
Drives: 2011 X3 28i
When doing brakes I always loosen the bleeder screws then push the piston back. This gets all the nasty fluid out and don’t take a chance in rolling a seal or something in the ABS unit. Then just gravity bleed the brakes to get new fluid through. Just my $.02
      03-09-2024, 03:15 PM   #5
Wgosma
...I usually do the same, thanks!
      03-20-2024, 01:58 PM   #6
Wgosma
Worked great, but did get the error message. Nice not having to remove the caliper motors 👍
      03-20-2024, 02:21 PM   #7
bmwPower99
19
Drives: bmw f25 X3 35d
Did my rear breaks a few days ago. It worked but got the error message. On a separate note I noticed the rear inner and outer pads are different.
Wgosma806.00
      03-20-2024, 07:44 PM   #8
HPR
HPR's Avatar
Nice being able to do your own work and not be held hostage to outrageous pricing.
Pat
      03-20-2024, 08:52 PM   #9
Wgosma
Well yes, but at age 73 I’m losing interest in getting dirty and working at ground level, ugh!
      03-21-2024, 09:43 AM   #10
Wgosma
Looked at my used pads.....does seem there is bit of difference in thickness comparing inner to outer pad, not huge but clearly noticeable.
      03-21-2024, 10:08 AM   #11
bmwPower99
19
Thickness should be the same but you can see below the shape and other dimensions. The backing plate on the outer pad has 2 metal raised dots that would not interface nicely with the piston. My pagid pads came with a note explaining the fitment.
http://https://www.gsfcarparts.com/m...bppad2162.webp
Wgosma806.00
xbimmers
