07-12-2012, 02:23 PM | #23 |
Rep 17
07-12-2012, 04:00 PM | #24 |
Rep 81
Add me to the wipers auto on by default list. Annoying to have to set it each time. Ditto for not remembering which setting the car was in for Comfort, Sport or Sport+.
07-12-2012, 08:26 PM | #25 |
Rep 1,511
Great thanks.
2013, AW, xDrive35i, M Sport Package, Technology Package, Dynamic Comfort Package, Premium Package, 3M Clear Bra, Euro foglight switch, a few coded fixes
07-13-2012, 08:37 AM | #26 |
16
Rep 69
I see there is a newer version of the psdzdata files (46.6) available. I need to download the software now to start coding. Will the new version work with a 2012 X3 35i or should I download the older version (46.3)? Thanks.
07-13-2012, 10:46 AM | #27 | |
Love All
170
Rep 740
I'm too downloading the 46.6 and will analyze for the changes and release new Setup file if needed. |
07-14-2012, 07:09 PM | #29 | |
Love All
170
Rep 740
So no need to change any coding steps or the data at the moment. |
07-15-2012, 02:07 PM | #31 |
Love All
170
Rep 740
07-15-2012, 02:13 PM | #33 |
Love All
170
Rep 740
Thanks. My estimates in the step by step procedures were based on data residing on external USB flash drive and an old laptop Thanks for the info, I will reword my instructions now.
07-15-2012, 02:16 PM | #34 |
Rep 449
Anyone know how to turn of the stupid notice to tell you that to engage reverse you have to press the button on the gear lever.
The notice is ok, but requires you to click Ok on I drive to make it go away even though on second attempt you are now in reverse ... Except with your top view obstructed with the stupid message that still needs acknowledgement!
F25 X3 xDrive 35d M Sport Alpine White, Black Nevada Leather, Speed limit info, TV, Prof. Nav & Speakers, HUD, M Sport steering wheel, Sport gearbox, BMW Apps, Internet, VDC, Comfort with Powered boot, Hi-speed synch, VSS, Top View, Electric tow-bar, Heated steering, Storage, DAB, Heated electric seats, Moonroof, Adaptive High beam assist Xenons, Servotronic, Performance control, etc.
07-15-2012, 02:16 PM | #35 | |
General
10446
Rep 40,802
---------------------------------------------- cafd_000000ae.caf.005_004_000 249,837 cafd_000000f9.caf.007_003_009 2,955,507 cafd_00000bce.caf.005_012_000 721,717 cafd_0000007e.caf.002_003_007 44,945 cafd_000007a1.caf.005_018_028 2,014,103 cafd_000009ef.caf.000_016_003 1,180,127 cafd_000014a8.caf.100_000_001 21,185 cafd_0000068d.caf.001_006_003 58,585 cafd_00000163.caf.007_001_006 1,344,995 cafd_00000171.caf.002_002_001 37,729 cafd_00000223.caf.013_006_006 1,986,099 cafd_00000794.caf.002_020_029 6,060,497 cafd_00000985.caf.003_001_111 88,591 ---------------------------------------------- The actual PSdZdata version though remains unclear to me as the F10 Integration Level remains unchanged. It is quite conceivable this is v.46.6 and still I-Level F010_12_03_512, but if that is the case, since we are seeing new F10's having even newer CAFD files (e.g. CIC CAFD file cafd_000000f9.caf.007_002_157) than what is in this new release (e.g. CIC CAFD file cafd_000000f9.caf.007_002_006), it would indicate that there exists a version somewhere, perhaps in Munich only, that is higher than this release, maybe the rumored v.47.x.
07-15-2012, 02:17 PM | #36 |
Rep 449
Oh yes ... And if anyone finds out how to enable forward warning on a car with speed limit info ... Would love to know!
07-15-2012, 02:24 PM | #37 | |
Love All
170
Rep 740
We will wait and watch before we reflect changes into our step by step procedures. |
07-15-2012, 02:39 PM | #38 | |
Rep 3,855
F25 xDrive20d SE __ professional multimedia package | dynamic package | climate package | 309s | xline | xenons | electric seats | folding mirrors | business speakers |
07-16-2012, 02:49 AM | #39 |
Rep 81
Has anyone activated the Internet feature using E-Sys?
Another thing I'm curious about is if I were to add the code 6NR in the FA-Editor of E-Sys and code it to my car, would it put the ConnectedDrive option in my menu? I'm not sure I'm brave enough to try as my car doesn't have the necessary hardware to support 6NR Last edited by BMWLVX; 07-16-2012 at 06:11 AM.. |
07-17-2012, 09:08 AM | #40 |
10
Rep 40
Parking Ventilation
I read the F25 cheat sheet codes and didn't see one for setting the Parking Ventilation. As of now the option is greyed out and can't be selected. Maybe Am I just ignorant? I can set the two timers. Thanks.
07-17-2012, 01:34 PM | #42 |
10
Rep 40
Are you sure?
I just re-read the owners manual and on the settings screen for climate there are three check boxes. The first on says "activate parking ventilation". This one is greyed out and won't let me select it. The other two are, "activate timer 1", and , "activate timer 2". These I can select which checks the box and allows me to enter a time. The owners manual states that you can either switch it on using the first selection, or use the timers. I can only use the timers. Anybody else have the situation that I have? I'd actaully like to try out the feature to see if the car stays any cooler while parked in the sun. Thanks in advance.
07-17-2012, 02:16 PM | #43 |
*Bimmerpost Plasti Dip Guru*
83
Rep 1,174
Drives: E53, E46-M3, E70, F25-X3
Not to be negative but,
I think this coding will be a problem if you are planning to upgrade to next year's Navigation for the f25. |
07-17-2012, 02:30 PM | #44 |
Love All
170
Rep 740
