05-07-2009, 01:46 PM | #68 |
Rep 30
Wheels: Dotz Mugello
Front: 18x8" (can't remember offset...) Spacer: none Rear: 18x9" offset 35 Spacer: none Tires: Front Bridgestone Potenza RE050 225/40 Rear Bridgestone Potenza RE050 225/40 Suspension/Fender Mods/Camber: none Notes: Tried with 255's at back and they rubbed. Heard even 245's rub with these rims so I changed to 225's at back too. Result: much less noise, and ride feels great now. Very agile and neutral handling, I can recommend all 225 setup except maybe for the 135i which might smoke them . Lookswise I like the form of the spokes a lot but the chrome/black contrast is a bit too harsh for my liking (can't see it well from the pic but the inside of the rim and the sides of the spokes are black) ... maybe paint the center with body color and leave the lip shiny. Any suggestions? Also, the BMW-centercaps make a huge difference I think
123d ///M-Sport Coupé (& e21 318) Alpine White: Because originality is overrated. |
05-26-2009, 06:32 PM | #72 |
20
Rep 219
05-27-2009, 03:45 AM | #73 |
sport pilot
Rep 65
Hi,
I just mounted OZ in my 135i: Wheels: OZ Ultraleggera Front: 18x8 +40 Spacer: none Rear: 18x9 +40 Spacer: none Tires: Front Bridgestone Potenza RE-11 225/40 R18 Rear Bridgestone Potenza RE-11 255/35 R18 Suspension: - Bilstein PSS10 kit + sway bar rear H&R 20mm - Camber plates Vorshlag: 2 deg neg camber front and rear Without modify the fender, rubbed too much rear. It's Ok front. I have to modify rear fender... |
06-01-2009, 10:37 PM | #74 |
Rep 35
OZ Alleggerita
Here is a link to photos of OZ Alleggerita, Anthracite on AW 135i
http://picasaweb.google.co.uk/blairp...64528201009058 All 4 corners the same. 17" x 8.5" ET 40, Nitto NT01 235/40/17 I am going to the Track Thursday. Hoping this will get rid of the EVIL, PUSH. |
06-03-2009, 12:45 PM | #75 |
Rep 769
Front: 18x8 +40 Spacer: none Rear: 18x9 +40 Spacer: none Tires: Front: Michelin Pilot Sport PS2 225/40/18 Rear: Michelin Pilot Sport PS2 255/35/18 Suspension/Fender Mods/Camber: Car is running KW Variant 3's at the lowest setting in the rears, almost lowest setting at front (level on the street) Had the rear fenders rolled a little when I got the wheels put on, no rolling on the front Notes: Rears rub on medium to large bumps at speed, also while in sweeping corners at high speed the rears rub. I can get the fronts to rub a tad if I brake hard while turning (stupid idea but I did it to test). Going to try raising my KW's a little. If that doesn't stop the rubbing, I'm going to have to roll the rears out more, and roll the fronts as well.
06-03-2009, 12:47 PM | #76 | |
Rep 1,973
Drives: 2009 e92 MR "Civic" ///M3
SICK!!! gotta check this out in person... congrats! looks awesome
|| DCT | ESS Tune | ACM Test-pipes | AA Green Filter | Swift Spec-R Springs | Stoptech ST-40 F || || My Youtube Channel ||
06-18-2009, 12:40 AM | #77 |
photographer
57
Rep 571
Wheels: Work VS-XX
Front: 19x8 +38 Spacer: none Rear: 19x9 +36 Spacer: none Tires: Front: Toyo Proxes T1R 225/40/19 Rear: Toyo Proxes T1R 245/35/19 Suspension/Fender Mods/Camber: KW V2, rolled and shaved rears....LOTS OF WORK, I don't recommend going with this aggressive of a rear unless you are willing to do lots of work and still rub. I'm running about 2.5 degrees of camber on the rears... Notes: Still rubs in the rear over certain bumps, fronts rub slightly because of height.
Jet Black 135i Coupe - 19" Work VS-XX - KW V2 - BMW Performance - Riss Racing - Burger Motorsports - Active Autowerke - 3DDesign |
06-18-2009, 01:44 AM | #79 |
Wanna Get MURDERED???
Rep 97
06-26-2009, 10:54 PM | #84 |
Rep 1,376
Drives: 1988 M3, 1990 M3, 1998 M3/4
Garage List 1998 BMW M3/4 [10.00]
2011 BMW M3 Sedan [9.28] 1988 BMW M3 [9.40] 1990 BMW M3 [10.00] 2008 BMW 135i - sold [0.00] 2003 BMW M3 - sold [0.00] |
Forgeline ZX3P wheels (white outer lip, satin black center)
-19x8.5 +45mm offset - 225/35/19 Goodyear F1 Asymmetric -19x9.5 +50mm offset - 255/30/19 Goodyear F1 Asymmetric Stock springs --- no rubbing anywhere. I'll update when I get the suspension on, but I'm crossing my fingers that I won't have to roll the fenders. I should note that these offsets are a bit different than what is on Turner's 128i.
1988 BMW M3 - Hennarot/Black
1990 BMW M3 racecar - Diamond Schwarz/Black 1998 BMW M3 - Alpine White/Mulberry 2011 BMW 328i racecar - LeMans Blue/Black |
06-26-2009, 11:04 PM | #85 |
122
Rep 2,040
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
Nice Justin! I'm pretty sure you'll have to do a little fender work if you lower, even with good offsets like that, but maybe I'll be wrong.
07-02-2009, 01:50 AM | #86 |
E30 Addict
38
Rep 590
His fronts should be fine, but I agree with you. I imagine the rear would need a bit of work. et+55 would of been awesome
07-04-2009, 07:19 AM | #87 |
Enthusiast
Rep 272
Wheels: BMW 18" Performance
Front: 18 x 7.5 Spacer: none Rear: 18 x 8.5 Spacer: none Tires: Bridgestone RE-11 Front: 225/40/18 Rear 255/35/18 Suspension/Fender Mods/Camber: Stock Notes: No Rubbing
Titanium Silver, Coral Red, Aluminum
07-06-2009, 10:33 AM | #88 |
UMADBRO?
Rep 188
