2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Turbo Inlet Pipe
      04-01-2024, 01:34 PM   #1
bryceforeman13
bryceforeman13's Avatar
Drives: 2016 BMW 535i
Turbo Inlet Pipe
I need help finding a turbo inlet pipe. I have searched all over the internet and the best I get is no ETA on shipping etc. I have already upgraded my intercooler, charge pipe, and air intake. I have a blow valve ready to be installed but wanted to tackle the turbo inlet pipe at the same time. Any suggestions?
      04-01-2024, 03:29 PM   #2
poverty.f10
DIY Mechanic
poverty.f10's Avatar
Drives: 2012 BMW 535i xDrive
What engine do you have?
You can live in a car but you can’t race a house.
      04-01-2024, 04:55 PM   #3
bryceforeman13
N55
      04-01-2024, 04:59 PM   #4
bryceforeman13
Turbo Inlet
Also trying to find a decent down pipe that will not make it crazy loud. I wanted to do both before getting it tuned.
      04-02-2024, 12:26 PM   #5
smokinu454
Drives: 2016 535i
I'm running this one. Internal diameter was 2.036" compared to the factory plastic one that measured 1.88" or 1.83" if i remember correctly. Looking at logs, I cant say for certain that I can tell a difference.
https://www.ecstuning.com/b-ecs-part...0757ecs09~ecs/
2016 BMW 535i, MHD stage 2+, XHP stage 3, VRSF charge pipe, VRSF down pipe, VRSF intercooler, ECS turbo inlet pipe
      04-02-2024, 02:48 PM   #6
bryceforeman13
Ok I'm looking for a turbo inlet pipe, this says intake pipe upgrade. I don't think that those are the same things. What do you think?
      04-02-2024, 03:11 PM   #7
bryceforeman13
I have a blow valve that needs to be installed and since they have to go under the car to do that they mentioned getting the turbo inlet pipe. It has been hard as hell to find.
      04-02-2024, 03:12 PM   #8
bryceforeman13
It has been almost impossible to find. I see intake pipes and charge pipes all over but a turbo inlet is completely different from those.
      04-02-2024, 05:46 PM   #9
smokinu454
Drives: 2016 535i
The one I linked above is the turbo inlet pipe. It goes from the air intake, into the turbo. It’s not under boost so it technically is part of the intake.
      04-03-2024, 05:55 AM   #10
poverty.f10
DIY Mechanic
FTP sells one.
https://x-ph.com/ftp-f1x-535i-intake...xoCH7YQAvD_BwE
Appreciate 3
      04-07-2024, 03:32 PM   #11
wesamjaber2004@gmail.com
wesamjaber2004@gmail.com's Avatar
102
Drives: Bmw 535i
Bro I can barely find one too for my n55. Also any thoughts on what intake to use ?
      04-07-2024, 05:01 PM   #12
poverty.f10
DIY Mechanic
Stock with a drop in filter and an inlet will be fine in stock turbo.
      04-07-2024, 06:44 PM   #13
smokinu454
Drives: 2016 535i
This is what I did, Ecs turbo inlet pipe and afe dry drop in filter.
      04-08-2024, 08:38 AM   #14
poverty.f10
DIY Mechanic
Did the sound change at all? Or did you feel any gains?
      04-08-2024, 12:08 PM   #15
bryceforeman13
I put the VRSF intercooler, and K&N cold air intake, and VRSF charge pipe. Those upgrades yes make a difference especially in sport + mode. I ordered the intake pipe listed above from ECS and also have a blow valve to go with that. After those I will get a downpipe and get it tuned.
      04-08-2024, 01:47 PM   #16
smokinu454
Drives: 2016 535i
Nope seems to sound and run the same. I just did them as supporting mods after I had already done a downpipe, chargepipe, FMIC, and stage 2+ mhd tune. The only thing I did notice is the wgdc% is lower which tells me they did help the turbo breath a little easier. Making 3rd gear pulls I used to regularly see wgdc% hit 95% now it stays closer to 87-88% at its peak.
      04-08-2024, 04:33 PM   #17
poverty.f10
DIY Mechanic
That’s great information. I guess if someone was to go aftermarket turbo then an intake would be a priority.
      04-12-2024, 08:20 PM   #18
ChiltiCoatl89
ChiltiCoatl89's Avatar
Now if they only made Silicon hose kits for our engines, would be so awesome I would buy it instantly, for this thread, There are so few companies that make piping, all do pretty much the same, ECS Tuning does make a good kit that is on my sights, anyone with a video or photos of the plumbing would really make this even better to read for all those to see.
      04-15-2024, 09:00 PM   #19
Houranimd49
Houranimd49's Avatar
Drives: F10 535i xDrive, F25 xDrive35i
I have the one from ECS also. I didn’t notice much of difference in sound, throttle response, etc. then again the only other modification I have is a charge pipe, nothing crazy.
5post
