The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > E Series NBT Evo Retrofit Development Thread
      01-05-2019, 06:14 PM   #45
Gray335i
21
Drives: 2008 335
i just did a voltage check from my nbt evo 2016 from unit to cid cable/ it is 12Vdc
      01-05-2019, 07:50 PM   #46
Nickco43
Nickco43's Avatar
1458
Drives: 08 E92 BMW M3
2008 BMW  [0.00]
My NBT next gave out 8.4 volts. Can you send the link to the parts you used for a voltage regulator?
      01-05-2019, 08:31 PM   #47
Gray335i
21
Drives: 2008 335
DZS Elec 2PCS LM2596 DC-DC Step Down Variable Volt Regulator Input 3.2V-40V Output 1.25V-35V Adjustable Buck Converter Electronic Voltage Stabilizer Power Supply Module
Just copy and paste in Google search it will show you link for amazon
      01-05-2019, 08:35 PM   #48
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
What size heat shrink will fit over the board?
      01-05-2019, 09:32 PM   #49
Gray335i
21
Drives: 2008 335
here is mine installed in enclosure. you can see size if heatsink.
      01-05-2019, 11:23 PM   #50
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
I am making it work. There are 5 vertical connectors and 4 horizontal ones. I am not sure what the 5th connector does.
      01-06-2019, 01:37 AM   #51
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
I hate when I am putting together a retrotfit. All day and night I am thinking of how to install all of this in the cleanest way possible. This is a large technical challenge.
      01-06-2019, 10:20 AM   #52
gamesfrager
198
Drives: 2011 328i
Just want to clarify one thing. You are installing this on the CIC dash inside the original second dash hump, right?
You are not doing an F30 style of iDrive screen? (really hope you say yes to this)
      01-06-2019, 10:33 AM   #53
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
I already have a NBT next into my double hoop dash. I will be using my nbt next moded cid for the nbt evo.
Anyone have part numbers for the 6 pin connectors?
      01-06-2019, 08:49 PM   #54
gamesfrager
198
Drives: 2011 328i
Just came across this by accident while searching for something else.
Looks like this fits the white 6 pin port?
http://www.realoem.com/bmw/enUS/show...diagId=61_4710
I'll see if I can find the black one
Edit:
I think #6 would fit for the black port?!
http://www.realoem.com/bmw/enUS/show...diagId=61_1280
      01-06-2019, 09:03 PM   #55
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
Edit:
I think I am going to order them both and I will make them fit if needed.
      01-07-2019, 04:03 AM   #56
vilord
Drives: E91, Tundra, TT, SV650
Nick is going for E series double hoop style.
I'm going to start with F style idrive, with an 8 or 10 inch display cut into the dash since I'm going from a professional radio to Evo, and because I thought it was okay in the F loaner I had.
If it looks like crap or I hate it, I'll buy a double hoop dash and swap over to match Nick's install.
      01-07-2019, 09:21 AM   #57
gamesfrager
198
Drives: 2011 328i
Hummm... is there really no other way to get the F30 style without cutting?
As for the EVO radio, would it be possible to get one and install it without getting a full iDrive system?
And what about the fitment? would it fit in place of the Pro radio unit without modifications?? That would be great, since that would solve the E9x lcd pixellation.
Sorry, too many things going through my head.
      01-07-2019, 09:56 AM   #58
vilord
The F professional radio is at least a couple of inches wider than the E radio, so it definitely won't fit without significant changes to the dash.
What we're doing is installing the F evo iDrive 5/6 head unit behind an E CIC control panel.
Installing an evo iDrive head unit without iDrive wouldn't work because there would be no display at all.
      01-07-2019, 09:59 AM   #59
gamesfrager
198
Drives: 2011 328i
I see. Thank you for the clarification.
Time for an F30 full dash retrofit then hahahah
      01-07-2019, 10:25 AM   #60
vilord
Gray335i What do you have sending wakeup to the NBT for desk testing? Is it an arduino with a can shield, or have you been able to do it from a laptop?
      01-07-2019, 12:38 PM   #61
Gray335i
21
Drives: 2008 335
0x12F 37 7C 8A DD D4 05 33 06
should be sufficient for 500K .
i am using arduino board with ta1050 , still waiting on screen to arrive.
also you can try : 0x130 45 40 22 8F FE (power on, curr running, e.,t,c)
      01-07-2019, 12:59 PM   #62
vilord
I was sending the 130 code every 100ms, and it seemed to power on the lights on the idrive wheel, but that's it. it also seemed to stop listening every 800ms or so, and then turn off, then start listening again, and start back up.
Maybe I need to add a resistor as well... not sure if the enbt adapter has resistors on either of the kcan buses...
      01-07-2019, 01:06 PM   #63
Gray335i
21
Drives: 2008 335
0x21A 3 05 12 F7 Lighting Status
add this as well/
I am not using 120 ohm resistor.
      01-07-2019, 01:08 PM   #64
Gray335i
21
Drives: 2008 335
did you try adding 0x12F 37 7C 8A DD D4 05 33 06
      01-07-2019, 01:21 PM   #65
Gray335i
21
Drives: 2008 335
my 6.6 screen is here from 2014 320.
looks like is dead. good old ebay.
vilord, as you can see in picture, my nbt evo is staying awake then whole time when is send thoise messages.
      01-07-2019, 01:27 PM   #66
vilord
Will the evo work with a 6.6 screen? Did you drop the output resolution and turn off widescreen mode?
