Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > Budget friendly / Cheap CIC retrofit!!!
      10-28-2019, 11:30 AM   #23
ccraig13
ccraig13's Avatar
54
Drives: '07 E92 328xi 6MT
UPDATE
Looks like my Indy BMW shop (who said it was my amp) and the Dealership (Who said it was my CCC) were wrong. I got the "MOST fiber optic optical loop bypass Female adapter" off Amazon and used it take the SAT DLP module out of the connection loop and now things are fine. So the $10 fixed worked this time.
I did have to modify the adapter because although it fits the TCU perfectly, it does not fit the AMP or SAT DLP. So I not so gracefully used some pliers to rip the plastic apart in small chunks
You'll see in my images what the final result looks like. Once I was satisfied, I super glued it and then wrapped it in duct tape (not shown).
Adapter: https://www.amazon.com/gp/product/B01FREU5F8
2007 328xi E92 6MT Jet Black/Coral Red | Tracks: NJMP
      10-28-2019, 01:46 PM   #24
FaxData
98
Drives: 2017 330e (F30)
Yeah, that’s common... usually water damage. Make sure to inspect for and clean out all the drainage channels or you risk losing your other trunk modules and/or your battery.
      10-30-2019, 01:56 PM   #25
ccraig13
ccraig13's Avatar
54
One more thing. I was going to buy a CIC Retrofit from a guy on eBay, but he walked me through diagnosing my system instead. I offered to pay him for his time, but he asked if I'd just share his kit instead.
So here's the kit I was going to buy: https://www.ebay.com/itm/264501019873 (No pics, but said he would text them. That's the only sketchy part ha!). He's been very responsive. Usually replies within minutes.
He'll even install it for you if you want to drive to NY.
      10-30-2019, 04:51 PM   #26
Nickco43
Nickco43's Avatar
1458
Drives: 08 E92 BMW M3
2008 BMW  [0.00]
I am friends with him. He is a good dude. I am not sure if he is making kits anymore as he got bogged down with work.
      10-30-2019, 06:11 PM   #27
mizta insane
Drives: 2007 335i
Hey man thanks glad you got it sorted!
      11-06-2019, 09:14 PM   #28
roadkillrob
Drives: 08 335i,22 X3M, 2012 C63 Black
I bought a kit from mizta insane and it was top notch. He built and shipped within a day, kit was great everything included, pre-coded 2020 maps all worked perfectly. I also have an older kit from another vendor in my E93 with an emulator and he coded that setup remotely to my vin so I could toss the emulator.
He has a few kits left get one while you can as the standard vendors are a lot more money.
Thanks for the setup, very happy!!
2022 X3M Brooklyn Grey
2008 E93 335i FBO
2012 Mercedes C63 Black Series Alanite Grey
      11-07-2019, 06:51 AM   #29
Kevink15
Drives: BMW 330XI
Dumb question. When you buy these kits where they ask for your VIN to pre-code, does that essentially mean it is now plug and play and no further coding is required? Also do they update the CIC unit to the latest? I'm looking into CIC retrofit and combox.
      11-07-2019, 10:18 AM   #30
nicky dj
Chelsea Football Club
nicky dj's Avatar
Drives: E92 N54
They come pre-coded if I recall. When I did mine, the seller in this case did a remote session to my laptop to adjust any further issues and coding needed.
      11-07-2019, 08:05 PM   #31
roadkillrob
Yep, at least the kit I got, updated to latest firmware C1A, precoded to VIN with all FSC codes generated and installed and latest 2020 maps loaded. Comes with everything you need, just plug it in all works and he remotely connected to fix some coding for me being an early 2006 had to make a few changes for what shows up in for maint items in CIC as some of the older items CIC doesn't display so shows a blank line.
2008 E93 335i FBO
      11-13-2019, 10:27 AM   #32
mizta insane
Drives: 2007 335i
Hey Rob, you're welcome. Any issue you got my number.
Kevink15 Let me know if you still looking to go to CIC.
I got a kit ready to ship. just need VIN and shipping address lol.
Kit will include all parts needed.
      11-18-2019, 03:30 PM   #33
iankee13
Drives: Bmw e93/e46/e36 m3, e30 325es
I’m interested to get the CIC retrofit. Nick I sent you an email but I hope you get better soon!
Mizta do you still have any available?
Thank you!
      11-26-2019, 11:49 AM   #34
benspeed83
Drives: 2008 BMW M3
I am interested in your kit if still available.
      11-28-2019, 05:59 AM   #35
shgpt
30
Drives: G16 850i, F87 M2c, E92 335is
Originally Posted by Nickco43 View Post
I have 2/3s of a kit in my basement. If anyone wants one last kit I will make one more.
pm'd you - would love to buy!
      12-03-2019, 09:50 AM   #36
748adam
45
Drives: 2007 E92 335i
Hey guys,
I have just bought a pre-coded CIC and combox set up. I have installed my CIC and got it working well I believe. I have run the wires for the Combox microphone etc but where do I plug the optic cables in?
I had no TCU/ULF and no bluetooth prep,
I did have CCC business nav and a aux input (no usb) in the arm rest.
any help greatfully received
2007 E92 335i, JB4 + custom back end flash, DCI, Downpipes, FMIC, Silicone inlets, Pure Stage 2 High Flow Turbos, Spec Stage 3+ Clutch and Single Mass Flywheel,
      12-03-2019, 10:32 PM   #37
nicky dj
nicky dj's Avatar
Drives: E92 N54
Originally Posted by 748adam View Post
Hey guys,
If I vaguely remember you have to loop the fiber optic cable by purchasing some harness.
      07-05-2020, 03:16 AM   #38
Johan_Gamino
Drives: 2008 bmw m3
hey, by any chance are you making these kits still? Nickco43
      07-05-2020, 06:33 AM   #39
pavel_ionut
Drives: BMW E92
Hello,
I purchased the display cable from Amazon, is OEM, very pleased with it.
https://www.amazon.co.uk/Adapter-Con...3948786&sr=8-4
      07-07-2020, 11:46 PM   #40
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
For now I still make kits.
      07-09-2020, 08:32 AM   #41
B1MMM3R
Drives: e36 e70 e90
Good dude and makes awesome kits. Great customer service, highly recommend buying from him. The upgrade is wellll welll welll worth it from ccc to cic also.
Supercharged s50 e36 318is*E90 328i*F15 x5
      07-23-2020, 02:57 PM   #42
thomth
Drives: BMW E92 325i
when I upgrade my ccc to cic, is my service history transferred to the new unit?
      07-25-2020, 09:19 AM   #43
keastburn
Drives: 2014 BMW 328I XDrive
I believe I am going to need a kit to unmuck my constant rebooting issue. Are you still making them? I appreciate your time, Nick.
Kimberly
      07-31-2020, 11:22 PM   #44
mtandre21
Drives: 06 330xi
I am in the process of retrofitting cic and logic 7 to a non nav car. Do i just take the whole harness from one car to the other? Are the aftermarket navigations any better?
