04-26-2018, 05:46 PM | #23 |
Joint Chiefs of Staff
24210
Rep 190,807
Awesome review OP
houtan707.00 |
04-30-2018, 02:54 PM | #24 |
Chief Warrant Officer
1025
Rep 1,638
Fantastic write up.
I'm nowhere near ready to do this, but when my turbo eventually starts wearing out I can't see any reason to replace it with a stock unit and will be looking at Pure.
"Prius" is Latin for Eunuch.
"Hrothgar": 2012 135i: 6MT M-Sport, BSM/Blk; Nav, Premium, Convenience, HK Dinan Stage 2 +PPK /// BMW PE /// VRSF CP /// K&N /// Koni Sports /// RSFB Inserts /// MPS4S 225/255 /// Other Stuff |
houtan707.00 |
05-02-2018, 11:37 AM | #26 | |
225
Rep 376
Past: 1979 RX-7, 1980 Civic, 1989 B2200 lowrider, 1990 Golf GT, 1995 Civic Si Turbo, 2000 Civic SiR, 2000 328i, 2003 540i M-Sport, 2008 Rabbit, 2014 Pilot, 2002 A4 1.8T, 2009 A4 2.0T Quattro, 2017 CR-V Touring 2020 CR-V Touring
Current: 2012 135i, 2015 228i x-Drive, 2023 CR-V Touring Hybrid |
05-02-2018, 02:58 PM | #27 | |
707
Rep 2,448
I wonder if something electronic under the hood is overheating. I remember when it happened to me, my oil and coolant temps were completely normal. My alternator voltage spiked, my rail pressure just dropped, and car wouldn't restart until I let it sit for thirty minutes. So to me that sounds like something electronic is getting hot. I wonder if it's the EKPM or whatever the module is for the fuel pump that is over heating. Please post back if you find a solution or have any updates. I know of at least one other person that this has happened to during half mile events.
06-01-2018, 01:09 PM | #28 |
27
Rep 255
I think I am going to get this turbo and get it tuned on 91 octane. I don't want to bother with meth injection and I don't have ethanol close to where I live. Currently I have an upgraded inter cooler and catless downpipe. What kind of WHP could I expect on just 91 octane?
06-01-2018, 02:13 PM | #29 | |
707
Rep 2,448
06-01-2018, 06:12 PM | #30 | |
102
Rep 313
Car is FBO with all supporting mods. Here are the results. https://datazap.me/u/xer0-449/91-v14...42-43-44-45-46
linux n' boost
06-04-2018, 03:56 PM | #31 | |
707
Rep 2,448
06-04-2018, 07:33 PM | #32 |
102
Rep 313
Seriously? FBO PS2 making <400whp. I wasn't thrilled with the numbers.
Either way, I just ordered this bad boy so I can actually wake the terbski up!
linux n' boost
06-05-2018, 02:44 PM | #34 | |
102
Rep 313
He recommends E50 with a PS2 until they released their LPFP solution, so that's what I'll run with until then. Hoping to pick up some good gains...
linux n' boost
06-05-2018, 08:35 PM | #35 | |
707
Rep 2,448
06-07-2018, 11:52 AM | #36 |
102
Rep 313
I will actually reach out to Gabe @ TTFS and reference this thread/try to get him in here.
linux n' boost
06-22-2018, 02:00 PM | #37 |
Rep 1,850
Dude that is shit even on a conservative dyno. I would be beyond pissed if I'd spent all that money on ps2 turbo. And 91 is not much different from 93 the standard performance pump gas in the usa. He should be making more.
06-25-2018, 09:21 AM | #38 | |
707
Rep 2,448
You are grossly underestimating how bad 91ACN (Arizona, California, Nevada) is, which is worse than regular 91. I am running E30, which is about 94 octane, and with that small difference, I am able to run 20psi and 11 degrees of timing. So yes, 91 ACN is much different than 93. If you haven't logged 91ACN, I wouldn't comment on how bad it is. With 93 octane, I could run the same boost and timing i am running on E30. On 91 ACN i couldn't even come close.
06-25-2018, 12:50 PM | #39 |
102
Rep 313
Just assume that 91ACN is actually 87-89 octane in the rest of the country.
They take shit fuel and add detergents to it to bring the octane rating up to 91, but the knock resistance does not increase. |
07-26-2018, 02:08 PM | #41 |
707
Rep 2,448
Sorry I am not much help there. I really don't keep track. I can tell you it's not cheap, but, I am doing it to have fun so I never really started a list of costs. You could easily price out most of the mods to get an idea of HW costs. I do not have any labor costs since I do all of the work (so far). Tuning cost is whatever MHD costs; the actual tuning did myself.
07-28-2018, 03:59 PM | #42 |
Rep 653
If you are looking to haul ass in a straight line it’s actually pretty simple and cost effective to get 450whp TO REDLINE. a DP,intake PS2 turbo and inlet will do it easy on stock fuel system e30 fuel... $4k including MHD if you do the labor youself
Xer0449101.50 |
12-24-2018, 10:50 AM | #43 |
Father of Frankenfold
299
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
Another install note regarding the oil supply line and GFB DV+:
Make sure you install the oil supply line onto the turbo before putting the turbo in the engine bay. It's pretty much unreachable once it's bolted onto the motor. If you did your install yourself, I'm sure you already realized that when removing the turbo. If using the GFB DV+, preinstall it on the turbo, hang the turbofold with just a couple of nuts on the flange, barely screwed on enough to hold it, like a 5 threads or so. Front top and bottom rear are easiest to access. While it's like that, insert the oil supply line into the block and bolt it down. It's much easier to reach with normal tool setups with the turbo having some wiggle room. Once the line is installed in the block, you can proceed with bolting down the turbofold, working slowly across all the bolts from inside out, top to bottom, to seat it evenly and not damage the gaskets.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
12-26-2018, 05:26 PM | #44 | |
3441
Rep 79,211
Drives: C6 Z06, 09 335i, 10 335xi
n55, ps2, pure turbos, wedge |
