BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > DIY: e90 Base Stereo Upgrade Project - Detailed installation instructions with photos
      09-25-2014, 10:33 AM   #23
Rockyz
Rockyz's Avatar
Egypt
Drives: E90 LCI
Originally Posted by Technic View Post
Excellent write up...
What is your impression of the new Stereo harness (longer extension cables, longer Quadralock harness, extension cables fully wrapped in OEM cloth tape)? Did it meet your expectations?
Hello Technic,
Actually your stereo harness is simply an OEM grade, i like the quadralock extension and long cables running to the trunk. I also like the OEM close wrapping and terminal legend printings were so impressive
Thanks for this product, you rocks
      09-25-2014, 12:16 PM   #24
Hopeful
45
Drives: BMW X3 G01 30d 2018
Originally Posted by Rockyz View Post
Hello Technic,
I wondered why you didn't seem to have much trouble getting the HU back in! I had to cut part of the cage away because the Quadralock extension was too short. Good upgrade Technic.
      09-25-2014, 02:29 PM   #25
Rockyz
Rockyz's Avatar
Egypt
Drives: E90 LCI
The quadralock is comming between the factory harness and the HU, so actually you have longer cable! Please let describe better how u find it short?
      09-25-2014, 05:01 PM   #26
taibanl
taibanl's Avatar
281
Drives: BMW
My only question is why didn't I get one of those
Have you started making them twisted pair?
      09-25-2014, 06:30 PM   #27
Technic
Technic's Avatar
2288
Drives: 2021 i3S, 2024 i4 M50
This is the new Stereo harness started from this August-on.
Twisted pair is only available when the RCA-termination option is selected.
      09-26-2014, 07:19 AM   #28
Hopeful
45
I was talking about the 5 inches or so of cable between the new HU Quadralock and the Quadralock receptacle which connects to the vehicle's Quadralock connector. If that had been longer it would have made it a lot easier to attach to the HU after tucking the connected Quadralocks out of the way.
While we're at it, I had to extend the underseat cables you supplied too with amp mounted in OEM position.
      09-26-2014, 09:30 AM   #29
Rockyz
Rockyz's Avatar
Egypt
Drives: E90 LCI
Ah, i see. Yes the quadralock extension is about 1 inch shorter than the OEM cable howver i had no problem attaching it to the HU before putting it back in position. Maybe u put the connected quadralock away further than mine.
And in regards to underseat cables, there werw long enough for me to route them to the OEM amp position, i had to cut part of both cables though.
Did you use the route shown in my guide?
      09-26-2014, 09:57 AM   #30
Hopeful
45
No, I used the route recommended by Technic
I went along the centre transmission tunnel - I can't see much difference in distance between the two though.
      09-26-2014, 01:00 PM   #31
Rockyz
Rockyz's Avatar
Egypt
Drives: E90 LCI
Yes, actually no much difference. I might have received longer cables from Technic.
      09-27-2014, 08:52 AM   #32
birdcatcher
Drives: '13 X5 35ixDrive E70
Hey Technic... I had PM'd you... still waiting for a revert...
      09-27-2014, 02:29 PM   #33
Rockyz
Rockyz's Avatar
Egypt
Drives: E90 LCI
OK, after living with the new sound system, i am really happy with the results but still hungry for deep bass
Looking for the best affordable solution for the the trunk woofer, i found this website http://www.wickedcas.com/product.php...&cat=10&page=1 they seems to sell the trunk housing with many options to chose from like sub size and model also.
1. Does anyone has experience to advice me what is best options to choose from?
2. Also, as as i am having the JL XD600/6 and all channels are used, can i connect both SWS8s (2 Ohms each) in serial and attach them to channel 5 (so, load is 4Ohms) and keep channel 6 for the woofer? is that technically possible?
Thanks in advance.
      09-29-2014, 12:04 PM   #34
Rockyz
Rockyz's Avatar
Egypt
Drives: E90 LCI
Thanks in advance.
Any idea?
      09-29-2014, 01:56 PM   #35
kaigoss69
kaigoss69's Avatar
Drives: '08 335i
Looking for the best affordable solution for the the trunk woofer, i found this website http://www.wickedcas.com/product.php...&cat=10&page=1" rel="" target="_blank">http://<a href="http://www.wickedcas...=10&page=1</a> they seems to sell the trunk housing with many options to chose from like sub size and model also.
Thanks in advance.
From the standpoint of maximum output for the least amount of money, I recommend an empty 12" enclosure and an Alpine Type R 12. That sub is also regarded by many to be in the SQL category, so sound quality and SPL in one. If you want a better SQL sub, go for an IDMax 10 or for pure SQ a Morel SC 10. In either case you will need a separate amp with at least 500w output.
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
      09-29-2014, 02:42 PM   #36
Wongway
Drives: 328i xdrive
I know you just put that together, but if you're truly looking to go the trunk sub route, get rid of the Earthquakes and put something like the Jehnert XE200 8" woofers under there.
Performance characteristics for two different types of subs in the car might make for some strange sound tuning issues.
      09-29-2014, 07:28 PM   #37
Rockyz
Rockyz's Avatar
Egypt
Drives: E90 LCI
Thank you very much.
Since i am looking for a lower budget, and definitely 500w of bass in my trunk is too much .
Do you think JL XD300/1v2 300w Amp: http://www.amazon.com/XD300-Audio-Mo...ds=XD300%2F1v2
and 12W1V3-2 - JL Audio 12" Single 2-Ohm: http://www.amazon.com/JL-Audio-12W1v...words=12W1V3-2
Do you think these will do good for me?
      09-29-2014, 07:33 PM   #38
Rockyz
Rockyz's Avatar
Egypt
Drives: E90 LCI
Thats so unfortunate
As you said, it might make some tuning issues. So i think i will have to try and see how it goes, and hope things will work will together. If not, i will have to look for the replacement
      09-30-2014, 01:13 AM   #39
Wongway
Drives: 328i xdrive
Yeah, ideally, you'd want the tweeters and mids playing from 20k-300ish hz or so. The 8" woofer below the seats for 300hz to about 80hz, and the trunk sub from 80hz on down past 30hz.
The big problem I see is you may end up with a strange hole in your sound.
The Earthquakes reportedly don't sound very good past 120hz.
It takes some really high end 4" mids to play down to 120hz or so.
A good subwoofer should ideally only be playing from 80hz on down.
So I'm going to guess things will sound rather empty from 300hz to about 120hz.
      09-30-2014, 07:38 AM   #40
kaigoss69
kaigoss69's Avatar
Drives: '08 335i
You would be surprised how much of the sub's output will be swallowed by the trunk. 500W is the minimum, better 600W-1000W. I used to run a JL W6 with 500W in a corner enclosure and it was underwhelming. Amp watts are cheap, and so is the Alpine Type R, about the same price as the JL W1, and MUCH more sub for the money. The XD600 is more money, but better spend it now rather than getting the XD300 and then later ending up upgrading anyway. Of course, there are other amps that make the same or more power, at a fraction of the price of the XD.
      09-30-2014, 11:19 AM   #41
Rockyz
Rockyz's Avatar
Egypt
Drives: E90 LCI
I completely agree with you that the SWS8s are terrible beyond the 120Hz.
I am currently running the SWS8 at 110Hz and the fronts down to 110Hz as well, and they perform well to me.
Putting the new sub at 80Hz and down, and keeping the above configuration will not result in that hole in the spectrum. What do you think?
      09-30-2014, 11:21 AM   #42
Rockyz
Rockyz's Avatar
Egypt
Drives: E90 LCI
That was so helpful, i will definitely consider 500w or higher. Thanks a lot for saving me the money
      09-30-2014, 11:32 AM   #43
kaigoss69
kaigoss69's Avatar
Drives: '08 335i
No problem. I've been down this road a few times myself. Just trying to help other people make better decisions than me!
      09-30-2014, 12:24 PM   #44
Wongway
Drives: 328i xdrive
I've never heard your speakers myself, but I have a hard time believing your mids will play to 110hz without straining.
I'm hoping for the best that they do!
Outside of that, I think your biggest headache might be getting the SWS and your trunk sub to play nice with each other. Phasing issues might cause one set to cancel the output of the other. You'll also be fighting the fact that the trunk naturally cancels out some of the trunk sub as well. I think when checking output, you'll need to selectively turn off the SWS and make sure the trunk sub is tuned well before turning them back on to see if the SWS aren't cancelling the trunk subs. And once you do that, vice versa.
I doubt people will reference this thread well, but I think the best advice anyone can give to someone looking to add low end to the E90 is:
If you aren't willing to go the trunk sub route, stick with it. If you're open to the trunk sub route, any compromises you made for having bass in the cabin will screw with your trunk sub install.
audio, base stereo, diy, installation, upgrade
