01-12-2017, 01:21 AM | #1 |
Rep 1,912
What Have You Done To Your BMW Lately?
Washed it, took it to the stealers for its annual inspection on the rear bumper i had fitted last year(thanks to the female who nudged me), cleaned out the cobwebs in the exhaust system on the way back.
Happy Motoring
Evdok |
01-12-2017, 06:05 AM | #2 |
Rep 3,209
I looked at it. Will probably drive it this weekend.
arvi60461.00 Day Laborer1747.50 |
01-12-2017, 08:02 AM | #3 |
Rep 487
01-12-2017, 08:44 AM | #5 |
Rep 5,577
I pulled out the cabin filter to knock out any debris: leaves, twigs. But after being replaced 4 months ago and parking near trees and shrubs, it was almost perfect.
01-12-2017, 11:13 AM | #7 |
Rep 6,089
Detailed the interior, something I do pretty regularly. Cleaning is once a month, full detail every 3-4 months.
Took it one some twisties at speeds I shall not name. Floored it in manual shift mode when entering the freeway. No turn signals cause BMW. |
01-12-2017, 12:05 PM | #8 |
Rep 515
Swapped out front pads for a new set of EBC yellows in my BBK. Did the wife's GTI as well, she also runs the same pads in her BBK. It was 30f with fog/rain so decided to leave the bedding in for another day.
01-12-2017, 02:21 PM | #11 |
Rep 5,776
So you do have a BMW? You have put evidence out there.
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
01-13-2017, 07:54 AM | #12 | |
Rep 36
As a side note, back when I bought the car, I had to remove the air vent cowl (total PIA) and dig out a about a 1/4 of a bucket of leaves from inside the fresh air intake for the vents. Even that drain pipe was stuck like house gutters and I had to dig it out with a hanger. Previous owner said "Garage kept"
2007 Z4 Coupe 3.0si w/sport package
01-13-2017, 08:32 AM | #13 |
Rep 912
Finally put on the aftermarket steering wheel, works and looks great but the airbag light is on. Still waiting for the software to fix that.
Took the engine cover off, but ran out of energy and decided I'd do the spark plugs a different night. So she's napping. |
01-13-2017, 04:31 PM | #14 |
61
Rep 155
Replaced the Grand Touring RFTs the dealer threw on the car that had 80% tread left with Michelin Pilot Sport AS 3+ Ultra High Performance non RFTs. Couldn't be happier! What a transformation in the ride experience.
01-13-2017, 04:41 PM | #15 |
Rep 1,478
Individual M4 Convertible ED Sept 2014
01-13-2017, 04:48 PM | #16 | |
Rep 5,577
I also use a wet/dry vac to vacuum then blow debris from the trunk drainage areas and the engine compartment recesses near the firewall and hood hinge area, anywhere where rain and leaves can congregate. |
01-15-2017, 10:46 PM | #18 |
Rep 5,235
RKP Lip, MP Center Diffuser and Velos Stage 1.
CURRENT: 22' INDIVIDUAL M5| CHALK | TARTUFO | CCB | MPE | H&R | IND
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND LONG GONE: 09' E60 M5|02' E39 M5 |
01-17-2017, 06:50 PM | #20 |
Rep 14,121
Drives: G82 M4C X-Drive
Macht Schnell Sport Springs and Spacers. Haven't washed it since because of the rain.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
01-21-2017, 12:42 PM | #22 |
Rep 912
Sooooooooo I'm ecstatic...
...after much reservation and careful timing I programmed comfort mode on my Z4. What's that? Well I can now open my roof with my key!!! Ebay Software cost $40ish Long version of the story: So the wifey got me a Renown steering wheel for Christmas. While installing it, I had some issues around how to make sure I didn’t get an airbag light. Once you remove the airbag, you have to use resistors on where the connections were on the original steering wheel. If not done in the right order while the battery is disconnected your car will now have an airbag light on your dash. You cannot do much but take it to a dealer or shop to have it cleared. This in itself could cost a pretty penny. So I resorted to looking or software that might help me do this myself. I am by no means a computer or software expert, which made this all the more difficult. The software installed nicely, easy instructions and self installing. The use of google helped me find some useful sights with regards to instructions and code breakdown (because its all in german). I tried to change my home lights as a first try. I didn’t even know that I had home lights. I tried to change them from the low beams to the fog lights. I processed the software and I had been only half successful which tested my nerves to say the least. The low beams were no longer home lights, but the fogs weren’t either. So thankfully I was able to revert everything back to normal and it worked as it did originally. This gave me the courage to try and work on the GM5 module KOMFORT settings which allowed me to turn a feature that was not active to active. Held breath …wrote to the ECU…and VOILA!!! It worked. YAY!!! Last edited by 3GFX; 01-21-2017 at 01:11 PM.. |
