BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > M4 Rims (437M) on F30 FINALLY!!!!! added more pics to pg3
Extreme Powerhouse
      12-12-2016, 01:14 PM   #89
FeelinBlessed
FeelinBlessed's Avatar
227
Drives: 2017 340i AW MPPSK/Track
2017 BMW  [0.00]
Originally Posted by blisstik View Post
This looks like the proper tire setup for 437m. Just enough thickness (that's what she said LOL) on the sidewalls.
BTW: What are you lowered on?
AC Schnitzer
///MPPSK///MP FRONT SPLITTER///MP KIDNEY GRILLS///CF MIRRORS///CF SPOILER///CF TIPS///HUPER OPTIK 20%///NBT///AC SCHNITZER///M4 437M///ZMP///ZTR///iND///
d_a_m92.50
      12-19-2016, 06:29 PM   #90
rhdh1049
rhdh1049's Avatar
16
Drives: 13 328i xDrive Sedan
Will 225/40/19 Tires work on 19x8.5 +35 wheels... 328i F30 xDrive Sedan
      12-20-2016, 01:14 AM   #91
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Yes, 225/40 will fit.
But the tires will be stretched.
      01-08-2017, 03:15 PM   #92
Bimmer_tech1023
Drives: F30
Originally Posted by FeelinBlessed View Post
I got mine done this past Saturday. Couldn't be happier
225/255 works fine for me. I actually like this look!
OEM m4 437m's
Just bought some 437m myself for my f30. I'm thinking about swapping my 403m tires to the m. How's the ride? Btw, I'm lowered on Dinan springs.
      01-08-2017, 04:01 PM   #93
FeelinBlessed
227
2017 BMW  [0.00]
OEM m4 437m's
No complaints on the ride. Couldn't be any happier with the result!!!
      01-08-2017, 05:21 PM   #94
sicmadek
Drives: 2013 335i sportline
Originally Posted by SLOWER View Post
Got mine mounted today. Absolutely love them. I really stressed out about the aggressiveness and the "poke" on these. Had some pretty serious buyers remorse when I test fit the rear wheel without a tire. Once they were on that is a non issue. They look like they are custom made for this car.
400M vs 437M
This is the angle that's deceiving. If you set your eye on the same plane as the flat part of the fender, right above the tire, there is only the slightest bulge of the sidewall proud of the fender. Difficult to photograph with a phone.
Where did you buy the wheels from?
      01-20-2017, 11:00 PM   #95
Winsalot
Drives: 2014 335i xDrive M-Sport
Originally Posted by oguz kuruca View Post
stock tires from the 437M will rub (even though some people claim they don't I tested in person and they did rub)
stock tires from 403M are fine on 437M
When you tested it in person was it with stock xdrive suspension?
      01-22-2017, 02:31 PM   #96
CPT Smuggs
CPT Smuggs's Avatar
98
Drives: F87
Great thread!
2019 F87 M2C - DCT / 10mm spacers w 246/265 / RW lip / Suvneer skirts / PSM spoiler / BMW diffuser / 3M gloss black
      01-25-2017, 12:05 PM   #97
oguz kuruca
Drives: F83 BMW M4
It's been a while I don't remember but I think it was dropped on H&R springs only.
      01-25-2017, 12:10 PM   #98
oguz kuruca
Drives: F83 BMW M4
UPDATE: I live in east coast, weather dropped down to 15-20 F lately. my front tire is leaking air, (it happened last year too). front tires are stretched so they leak every winter. it gets stupid annoying after few visits to the tire shop. It's fine from April to November. So I purchased some oem style 192s and installed them for the winter (required spacers in the front). BTW I don't do much driving in the winter but with the winter tires and all wheel drive, car drives great even in snow!
      01-26-2017, 07:05 AM   #99
bill_f31
114
Drives: BMW F31 M Sport
My OEM 437M rims are finally on...
Also ditched the Runflats and although the diametre increase from 18'' (400M) to 19'' (437M) wheels, the ride is better.
225/40/19 - 255/35/19 tyres, M sport suspension lowered with ACS springs, no rubbing so far.
Appreciate 3
CQVD33051.50
TBN54426.50
cdwalls702.00
      01-26-2017, 07:09 AM   #100
sicmadek
437m reps 235/35-19 & 275/30-19 h&r super sport springs
      01-26-2017, 05:02 PM   #101
F31-340i
F31-340i's Avatar
156
Drives: BMW 340i Touring
Looks really good. Is it a 340i?
Any shots from along the side to see how much it sticks out?
Do the 225 look very stretched on 9J rim - likewise for the 255 on 10J?
Did you consider fitting the RFTs (though I realise it seems you were moving up from 18" - I'm thinking of moving to 437M from 19" 442M with RFTs).
340i F31
      01-26-2017, 08:11 PM   #102
CPT Smuggs
CPT Smuggs's Avatar
98
Drives: F87
I am interested in a bunch of OEM side shots with measurements from the fenders as well, especially the front.
I'm on the fence between OEM and REP for a F30, but leaning towards the REPs because of my calculated poke past the fenders. Currently I have 18x8.5ET35 front (about 5mm inside fender) and 18x9.5 ET33 rear which measures 27mm. That looks just fine, but I think the perfect look is 12mm front and 21mm rear which gives an aggressive tire look outside both fenders without being too much or looking unbalanced.
Ideal 12mm / 21mm (0mm / 0mm)
19x8.5 ET35 / 19x9.5 ET40 REPs calculate to 5.5mm / 20mm (-6.5mm / - 1mm)
REPs with 5mm front spacer calculate to 10.5mm / 20mm (-1.5mm / -1mm)
19x9.0 ET29 / 19x10 ET40 OEM calculate to 18mm / 26.5mm (+6mm / +5.5mm)
Will be using 235/40 and 265/35 tires if I buy replica wheels and use 255/25 and 265/35 if I buy OEM.
Anything smaller than 235 in the front looks stretched.
Anything larger than 255 in the front will rub.
Anything larger than 265 in the rear has a chance of rubbing. Many have run 275 without issue.
      01-26-2017, 08:39 PM   #103
CPT Smuggs
CPT Smuggs's Avatar
98
Drives: F87
In case anyone else can benefit from my research which pertains to a F30 M-Sport xDrive:
To calculate tire height: ie 245/40R19
Take the width of the tire (ie 245mm)
then convert to inches (divide by 25.4)
then multiply by the ratio (.40)
then multiply by 2 (tire on both sides of the wheel)
then add the wheel diameter (19").
eg: (((245mm / 25.4) * .40) * 2) + 19" = 26.72" tall
*Don't exceed +- 0.5" the stock tire height to maintain your suspension, speedometer, comfort, etc.
*Try to stay as close as possible to stock tire heights.
*The speedometer comes ~1% fast, meaning a 1% increase in tire height will give you a true speed.
Wheel-----Front Offset + Tire----------Rear Offset + Tire-----------Total Height Front / Rear---Pct Diff from OEM Front / Rear
18" 400M (18x8 ET34 225/45R18 / 18x8.5 ET47 255/40R18) = 25.97" / 26.03" (stock)
19" 437M (19x8.5 ET35 225/40R19 / 19x9.5 ET40 255/35R19) = 26.08" / 26.02" REP (same as stock)
19" 437M (19x8.5 ET35 235/40R19 / 19x9.5 ET40 265/35R19) = 26.40" / 26.30" REP (+1.6% / +1%)
19" 437M (19x9.0 ET29 235/35R19 / 19x10 ET40 265/30R19) = 25.47" / 25.25" OEM (-2% / -3%) - Very popular with ACS / HRSport kits
19" 437M (19x9.0 ET29 235/40R19 / 19x10 ET40 265/35R19) = 26.40" / 26.30" OEM (+1.6% / +1%)
19" 437M (19x9.0 ET29 245/35R19 / 19x10 ET40 265/35R19) = 25.75" / 26.30" OEM (<-1% / +1%)
19" 437M (19x9.0 ET29 255/35R19 / 19x10 ET40 265/35R19) = 26.02" / 26.30" OEM (0% / +1%)
19" 437M (19x9.0 ET29 255/35R19 / 19x10 ET40 275/35R19) = 26.02" / 26.57" OEM M3 *Possible Rubbing*
A 35 ratio tire is generally around 3.5" thick sidewall.
A 40 ratio tire is generally around 3.7" thick sidewall.
I personally like the thicker sidewall for comfort (at the cost of some handling) and to minimize wheel gap (I don't plan on dropping my car more than 0.75")
Appreciate 6
      01-27-2017, 03:28 AM   #104
bill_f31
114
I was afraid that the 225-255 tyres would look more stretched on 9J-10 rims, but I think that they look OK.
I never considered staying with the RFTs.
The original 437M forged wheels are lighter than my previous 400M wheels and, in combination with the also lighter non-RFT 19 tyres, give a flowing ride feeling, although you would expect harsher ride because of the 19'' setup.
Some random (wet) sideshots:
ELiTeNeSs196.50
cdwalls702.00
      01-27-2017, 08:13 PM   #105
CPT Smuggs
CPT Smuggs's Avatar
98
Drives: F87
That looks good Bill. I thought there were be a lot more poke as my current wheels have a ET33 offset vs ET29. Between the thicker wheel and a slightly stretched tire it doesn't appear to stick out as far as mine.
      01-27-2017, 11:57 PM   #106
Bimmer_Boy_22
Bimmer_Boy_22's Avatar
Drives: 2014 Bmw
Nice setup
      01-28-2017, 12:03 AM   #107
Bimmer_Boy_22
Drives: 2014 Bmw
19" 437M (19x9.0 ET29 255/35R19 / 19x10 ET40 275/35R19) = 26.02" / 26.57" OEM M3 *Rubs!*
Thank you
      01-28-2017, 03:11 AM   #108
Kabrich
Drives: '13 AH3 (335IH) 3F93 MSport
Interesting info.
Making sure there are no assumptions, exactly what is the first and second %?
Also, fwiw, there are forum members claiming they are running 275/35R19 and claim no rubbing, while others claim the ride is just too rough.
      01-28-2017, 05:33 AM   #109
bill_f31
114
Originally Posted by oovahe View Post
Nice setup
Thank you.
      01-28-2017, 05:51 AM   #110
Gr-Racing
Gr-Racing's Avatar
206
Drives: E46, F30 335i, 1986 K75
Running 235/35/19 and 265/30/19 and wishing more tire.
437m, f30, rims, wheels
