BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Looking for new wheels for F32
GetBMWParts
      03-20-2022, 11:27 PM   #23
badninja99
badninja99's Avatar
Drives: BMW 440i XDrive
Originally Posted by alohasurftoad View Post
snapperrocks blue with bronze shoes looks epic!
eibach pro-kit with F80 bumpstops will really enhance final appearance
for tire pressure, i'd prolly run 34 front, 37 rear and see how that feels
I was gonna do the springs but wanted to wait to see how the wheels would look. I noticed there is slight rubbing when the wheel is turned all the way to the right, more noticeable on the inside of the wheel well on behind the bumper.
1. With that in mind, would you still reminded the springs?
2. Why Eibach?
3. Is there a benefit of going with the KW kit you mentioned?
4. Which is better for a comfortable ride?
      03-21-2022, 12:17 AM   #24
alohasurftoad
Drives: 440i gran coupe w/mppsk
2. Why Eibach?
usually lowering will eliminate the slight rub you have. this is usually due to slight negative camber added and the point of contact where rubbing occurs moving to a higher point in the fenderwell. only a few mm is the difference.
Eibach lowers the least, fixes reverse rake because the front lowers more than rear and has the most comfortable spring rate.
you can do KW DDC EDC "adaptive" replacement coilovers but they're quite expensive and i'm not sure on the "coding" and stuff.
Eibach pro-kit springs with your OEM adaptive will have the most comfort, moreso than most coilovers, even set to the softest setting(except for KW Street Comfort?). here's a link to one of more than a few threads on Eibach Pro-Kit.
https://f30.bimmerpost.com/forums/sh....php?t=1901058
the suspension sub-forum has tons of info on the topic for further guidance
      03-21-2022, 02:26 AM   #25
johnung
2. Why Eibach?
New wheels look great! Eibach springs are only about 10% stiffer than stock so you get lowering with more control. While other springs like H&R's can be more harsh because they are 30% stiffer. Eibachs are the way to go with your Adaptive/EDC dampers.
KW are the most comfortable coilovers but wouldn't be as comfortable as the Eibach setup because the KW spring rates are higher. KW Street Comfort spring rates are still higher than Eibach.
      03-21-2022, 09:30 AM   #26
djgreg1200
Drives: 2018 330i Xdrive
2018 BMW 330i  [0.00]
alohasurftoad johnung
Thank you for helping me decide on what to get, I got the HRE's installed a few days ago and I'm in love with them. The ride is better than in expected, small bumps and lines on the road are softer thanks to the non-runflat tires but the larger bumps are a bit harsher.
What tire pressure do you recommend?
Here are a few pictures...
Attachment 2839982
Attachment 2839983
Love the look!!!
      03-21-2022, 09:58 AM   #27
badninja99
badninja99's Avatar
alohasurftoad
Are these the Bump stops that you are talking about?
Front:
https://www.turnermotorsport.com/p-2...uine-bmw-part/
Rear:
https://www.turnermotorsport.com/p-1...uine-bmw-part/
Are these the correct springs?
https://www.ecstuning.com/b-eibach-p...-20-031-18-22/
I'll place the order once I know they are the correct part.
johnung
I saw you mentioned swaybars in another post, what are the advantages of getting aftermarket ones? How is the handling with the Eibach springs?
      03-21-2022, 11:28 AM   #28
alohasurftoad
alohasurftoad
Front:
Rear:
you appear to have the correct parts, please double and triple check.
here is how the F80 bumpstops came about... https://f30.bimmerpost.com/forums/sh....php?t=1621134
      03-21-2022, 12:25 PM   #29
MTTH
MTTH's Avatar
233
Drives: '11 328xi |'18 440xi GranCoupe
  [0.00]
alohasurftoad
Front:
Rear:
johnung
E10-20-031-05-22 is the part number recommended for our xDrive F36 440is by Eibach. E10-20-031-02-22 is the RWD variant which drops the car even lower. I have seen people run both and be fine, it all depends on how low you want your car to be.
Here is a link to a thread with pictures of both: https://f30.bimmerpost.com/forums/sh....php?t=1785193
      03-21-2022, 12:59 PM   #30
johnung
alohasurftoad
Front:
Rear:
johnung
Eibach springs handle great without being overly stiff like H&R and Dinan.
Sway bars control excessive body roll during turns. It's important to do any spring and damper upgrades first and afterwards only change front or rear sway bars if necessary. The labor is expensive on F3x's because a lot of parts need to be removed to access them. I would avoid any hollow bars because they are known to snap.
      03-21-2022, 01:10 PM   #31
alohasurftoad
OP car is F32 x-drive. while i'm not disagreeing 5-22 or 2-22 would work, i am not sure of the axle loading differences and whatnot and since eibach/US seems to have some discrepencies, i've been using what www.eibachshop.com "spits" out, instead.
18-22 doesn't lower much, 20mm(0.8") front, 10mm(0.4") rear, however some of the gap has been already been reduced by taller tires so this amount of lowering should work out. plus there will be the less stress on x-drive half shafts and minimal to no affect on OEM adaptive damper longevity.
if the OP decides he wants it lower than 18-22, there's more research and query necessary to determine the exact alternate kit, imo.
Appreciate 3
MTTH232.50
johnung4531.00
      03-21-2022, 01:31 PM   #32
MTTH
MTTH's Avatar
233
  [0.00]
My apologies, I confused OP's car with another car from a similar thread. That being said, I agree, the 18-22 kit might suit his needs better.
I use the german eibach parts catalogue recommended by johnung and it recommends the 18-22 kit as well.
Seems as if the difference between the F32 & F36 kits are the rear springs. They seem to be slightly longer and rated for a slightly heavier vehicle.
F32 440xi:
http://web2.carparts-cat.com/default...5&14=15&12=130
F36 440xi:
johnung4531.00
      03-21-2022, 03:09 PM   #33
Mr.Gee
56
Drives: 430D Coupe
I spent a LOT of time looking for wheels. Finally decided on another set of Work VSXX.
Appreciate 4
dmanb2b2124.50
MTTH232.50
      04-06-2022, 07:24 AM   #34
mrmack919
Fast learner
Drives: 14' 435xi
Wow that looks awesome! I’ve been looking around a lot and I may have just been pushed over the edge on a wheel selection!! Thanks!
      04-06-2022, 07:52 AM   #35
badninja99
badninja99's Avatar
Few more pictures after getting it ceramic coated. The wheels look a bit more bronze now.
Appreciate 3
      06-13-2022, 09:39 AM   #36
badninja99
badninja99's Avatar
alohasurftoad & johnung
Thank you for all the advice. I got the springs installed and I really like the look. Barely any body roll but I find the car bounces a lot, especially on the highway and over bumps. Is there anything I can do to reduce that. Will the Koni dampers help or am I wasting my time?
      06-13-2022, 11:03 AM   #37
alohasurftoad
Eibach is 10% firmer than m-sport springs and even more(%diff) from base springs, since base springs are even softer.
I suspect you are now over sprung, high spring rate with OEM base dampers(slow compression/rebound), causing bounciness.
Koni would eliminate the bounce because its comp/reb is more appropriately matched with a higher spring rate. You should have a firm but compliant ride overall, without the bounce.
Koni Sport yellow are firmer and rebound adjustable, more performance oriented. Special Active red are non adjustable, slightly cheaper and sporty/street oriented. Either choice is fine and will improve the bouncy ride you have now.
Last I checked Koni are 20% off
johnung4531.00
      06-13-2022, 11:23 AM   #38
badninja99
badninja99's Avatar
alohasurftoad
https://www.koni-na.com/en-US/NorthA...=555&mk=6&mt=1
I see there are a few options, Is there a one that's compatible with M-Adaptive suspension? Or would I have to get rid of that function?
      06-13-2022, 11:50 AM   #39
alohasurftoad
ahh...since you have adaptive, 1st option is consider Dinan Shockware. it electronically enhances/alters the compression and rebound in your OEM adaptive. it basically firms up the adaptive shock which will reduce the bounciness. relatively inexpensive, i recommend you try this 1st. https://www.dinancars.com/products/s...arts/D906-3001
2nd option to consider is Bilstein Damptronic which are high performance (adaptive) replacement for your OEM adaptive dampers. this option is not cheap, add labor for install and alignment Koni does not offer an EDC replacement.
3rd option is to replace everything you have now(incl Eibach) with KW EDC coilovers. this is most expensive
Edit...4th, as you thought, you can get Koni and code out Adaptive, a few people have done this but most want to try and retain adaptive.
      06-13-2022, 01:27 PM   #40
BeFitty8_F32
Melbourne Red F32 B58
BeFitty8_F32's Avatar
Drives: 2017 440ixm
I am using KW Street Comforts with EDC. I have the height set at its highest setting which lowers the height from stock around 1inch. I have been warned that going lower will induce stress on the sway bar end links. I have purchased adjustable end links just in case this happens.
As far as dampening, I dont feel a difference between the stock suspension and the KWs. Comfort is still cushy and bouncy. Sport stiffens up, but not enough for my liking (xDrive makes a girl fat! lol). Hoping to get under there some time and see if I can make it a little stiffer.
I did have these professionally installed by a local shop.
Real drivers use 3 pedals. Its about connection.
      06-14-2022, 01:28 PM   #41
johnung
I've had friends with factory Adaptive dampers install Eibach springs and they worked great. Based on your symptoms I wonder if you are hitting your stock bump stops? Trimming off some of the bump stops may solve the issue.
I would research and try the Dinan Shockware to see if you like it as Alohasurftoad suggested
Also check that none of your Adaptive dampers are shot. They typically leak fluid when they are bad- at anywhere from 40k to 95k miles. They have to be replaced in pairs. Bilstein B4-Damptronic are close to stock. Bilstein B6-Damptronic are stiffer.
Another option is KW EDC coilovers. KW makes excellent coilovers that have well matched springs and dampers
Hope this helps
      04-13-2023, 09:43 PM   #42
badninja99
badninja99's Avatar
Hope this helps
I decided to go with the KW DDC kit, I'll post my thoughts once they are installed.
johnung4531.00
      06-03-2023, 06:25 AM   #43
J_Stam_ATL
J_Stam_ATL's Avatar
14
Drives: 2018 F32 440i Coupe
Did you get these installed? Thoughts? I have taken a similar path in wheels, tires, lowering springs and the KW DDC kit looks appealing long term. Also, good to see another ATL forum member here!
      06-20-2023, 12:13 PM   #44
badninja99
badninja99's Avatar
Hey J_Stam_ATL
I've had a chance to install them. I was waiting for the car to set before posting the review. The first thing I noticed was the how soft the ride was in confort. I glides over most cracks and bumps on the road. There is still a bit of body roll in comfort. As soon as you put in sport that all changes. It stiffer and the body roll is gone. I prefer sport on the highway and and comfort on the local roads. I'm planning on getting VAC Monoball control arms to improve the steering feel. I will update this thread once I install and test them.
Let me know if you want any details on the install or the ride.
