BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Has anyone ran APEX ARC-8 18x8.5 ET45 18x9.5 ET58?
ARMA SPEED
      02-27-2024, 12:19 PM   #1
mprotacio
Drives: 2017 440i xdrive
The tire size is 225/40/18 and 255/35/18. Was wondering if anyone has any pics or opinions on this setup? Eventually I’ll be lowering on coilovers. Thank you!
      02-27-2024, 12:43 PM   #2
alohasurftoad
Drives: 440i gran coupe w/mppsk
even if you are lowered, those 2-series spec rims+tires will have huge fenderwell gaps because of the 25"+ tire diameters and look super tucked/sunken in, due to it's high offset. the rear offset is so high, the inner tire may contact and you'd need 12.5mm spacer to get it near to F3/4 OEM rear offset.
if you get those wheels, the tire size combo should be changed to:
225/45/18+255/40/18 or
235/45/18+265/40/18 or
245/40/18+275/35/18
with 12.5mm front+15mm rear spacers
      02-27-2024, 12:47 PM   #3
mprotacio
Originally Posted by alohasurftoad View Post
even if you are lowered, those 2-series spec rims+tires will have huge fenderwell gaps because of the tire diameter and look super tucked/sunken in, due to it's high offset. the rear offset is so high, the inner tire may contact and you'd need 12.5mm spacer to get it near to F3/4 OEM rear offset.
if you get those wheels, the tire sizes should be changed to 225/45/18+255/40/18 with 12.5mm front+15mm rear spacers
Ahh thanks Mr toad! The owner used 20mm spacers in front and 15 in the back haha
