04-05-2018, 09:23 AM | #1 |
Rep 7
iPhone connection via USB
When I connect my iPhone 6 to the USB port in the armrest the phone goes into a flash mode where the screen flashes on/off once per second. I thought it was my iPhone 6 so I tried it with an 8 and same thing. Then I thought it may be an aftermarket cable so I switched out to authentic Apple. No improvement. Anyone know what is going on?
2015 435i Coupe Sport |
04-05-2018, 03:13 PM | #4 |
26
Rep 30
Same issue here. Took my 328 into the dealership and they could not replicate the issue. Happens on my iPhone 6 plus and 8. It is extremely annoying, I have hard connect to use my connected drive apps instead of the Bluetooth connection.
04-05-2018, 10:27 PM | #5 |
100
Rep 280
Try taking the brightness down on your phone, it might be drawing more current from the USB port than the car is able to deliver.
2017 430ix Gran Coupe
04-06-2018, 01:53 PM | #6 |
Rep 7
04-12-2018, 07:41 AM | #7 |
Rep 7
Problem solved. Although the strange path this took, the dealership figured it out. After replacing the USB port it was discovered that you MUST use an authentic Apple cable. I thought mine was but it was a knockoff that looked identical. I went to the Apple store and bought a new cable and, voila, all is cool!
04-12-2018, 07:55 AM | #8 |
Rep 766
04-12-2018, 11:29 AM | #9 |
Rep 21
It's not the cable. The USB port is only rated to power at a certain amperage. I don't remember what it is off-hand but after using a phone plugged into it for an hour or two with nav apps open it will start to draw more than the port is rated for and wonk out.
I confirmed this with a USB multimeter. It's also in the manual that you can't use the USB port for charging because it doesn't have the amperage. |
04-13-2018, 05:00 PM | #10 | |
Rep 14
BMW should be providing us with a recall for this issue, or should be compensating us for the lack of functionality given that we paid EXTRA for Enhanced USB. Period. |
connection, iphone, usb |
