07-12-2018, 09:27 AM | #67 |
3769
Rep 2,912
Drives: 2011 E93 M3
I can't remember exactly. I think those were showing between the .002/.003 marks. Plastigage is more of a guideline to make sure nothing is seriously wrong than a way to determine with absolute accuracy.
07-12-2018, 10:03 AM | #68 |
Rep 7,129
Thanks man, I'll try a reach out to ACL to see what they have to say about HX vs a possible mix with STD. Heading of to the shop next week.
07-12-2018, 01:13 PM | #71 |
50
Rep 357
Thanks, I saw the other thread but kinda went over my head. Was the clearance on the STD the same as BE's offering? Because the HX is the one that's supposed to be "extra" with the 0.001" on par with BE.
07-12-2018, 02:39 PM | #72 | |
25
Rep 69
Engine sounds quieter. So, this earlier comment was in relation to ACL bearings not offering increased clearance to BE, I'm assuming based on the standard H model, but also now people are saying the HX has too much clearance? What is the downside to that? |
07-12-2018, 02:43 PM | #73 |
3769
Rep 2,912
Drives: 2011 E93 M3
Not sure yet what practical consequences might be in an S65 with slightly too much clearance. Probably nothing to worry about with 10w60. With something like 0-40 the oil pump may not be capable of the volume to maintain pressure.
07-12-2018, 02:47 PM | #74 |
Rep 1,543
I am about to buy a set and torn between going with which type. If I am planning to supercharge in near future, would extra clearance (HX) would be better or would you think STD is better choice?
07-12-2018, 02:52 PM | #75 | |
25
Rep 69
The issue here is "STD" is misleading. The part numbers in question for those with OEM crank (not machined down) is either 8B1580H-STD or 8B1580HX-STD. |
07-12-2018, 03:49 PM | #76 | |
17
Rep 102
The Nominal Clearance size for the H-STD (according to Wiki) is 0.0508mm (BE is 0.0610mm), the BMW OEM 702/703 are 0.0432mm - so this actually means the H-STD bearings already offers additional clearance vs OEM? HX-STD has thinner size walls which mean additional clearance, on top of H-STD (+0.0125mm each or +0.025mm per pair) so I guess if I match a H-STD and HX-STD as a pair that should bring me closer to BE’s: 0.0508mm + 0.0125mm = 0.0633mm? Any downsides of running a mixed set? I reckon it’s fine as long as they been installed correctly? My feel is a pure HX-STD set might offer too much clearance too as that would be 0.0508mm + 0.025mm = 0.0733mm (vs BE’s 0.0610mm). That said, 0.0508mm is the measurement for a H-STD (none been measured for HX-STD so far). Last edited by wingzee; 07-12-2018 at 04:08 PM.. |
07-12-2018, 08:21 PM | #78 | |
1446
Rep 1,614
07-12-2018, 08:53 PM | #79 |
25
Rep 69
Bummer... surely I can't be the only one who is running the higher clearance HX bearings right? This recommendation/consensus of mixing the shells is so recent that I have missed the boat it seems...
I think there's some misleading info over nominal clearance; yes someone measured the ACL 8B1580H-STD and came up with 0.0508mm. I don't believe however this is ACL's "design nominal clearance". According to the tech data/PDF they sent me before I decided, their 8B1580H-STD nominal clearance is 0.0355 mm and their 8B1580HX-STD nominal clearance is 0.0615mm. I understand if there's some difference between their intended/targeted nominal clearance vs the actual resulting product's measured nominal clearance (albeit a sample size of only 1 set, and using 1 person's measuring equipment), but from a design perspective ACL aren't targeting 0.0508mm with their 8B1580H, and therefore not targeting 0.0758mm with their 8B1580HX. |
07-13-2018, 01:34 AM | #80 | |
17
Rep 102
Problem is ACL don’t specifically measure their RBs before shipping out unlike BEs hence numbers could vary vs BE who does. Last edited by wingzee; 07-13-2018 at 01:41 AM.. |
Assimilator1595.50 |
07-13-2018, 04:09 AM | #81 | |
Rep 7,129
In my communication they however state the STD shell was targeted around the OEM 702/703. With the housing and shaft tolerances (they use hsg 56.000-56.013, shaft 51.975-51.991, haven’t double checked BE’s numbers), it according to them result in a possible clearance range of 0.013-0.058mm where 0.0508 is ending up towards the top of the range. The assumptions and methods to measure seems different between the vendors which is puzzling but hey, at least we learn a little something along the way. Chatting with my shop in parallel: They state that even a 0.0758 clearance is nothing strange for an high power engine, and even advantageous for our Nordic climate using 10W60. These guys are engine builders since many years so their opinion counts in my book. Next week I'm off to get HX in, and I feel good about it. PS. No you are not the first putting in the HX shells - look further up in the thread - so you don't need to feel alone... Last edited by Helmsman; 07-13-2018 at 04:34 AM.. |
07-13-2018, 07:57 AM | #82 | |
Rep 1,543
07-13-2018, 08:09 AM | #83 | |
Rep 7,129
FWIW the ACL S65 shells are designed for 10W60 like most others so personally would stick to that oil regardless. |
07-13-2018, 08:11 AM | #84 |
3769
Rep 2,912
Drives: 2011 E93 M3
07-13-2018, 04:20 PM | #85 |
17
Rep 102
07-14-2018, 07:49 PM | #86 |
Rep 1,543
07-15-2018, 03:26 AM | #87 |
17
Rep 102
07-15-2018, 11:09 AM | #88 |
3769
Rep 2,912
Drives: 2011 E93 M3
Thicker shells (H-STD) on the top, thinner (HX-STD) in the cap... You should make sure this combination measures out OK before slapping it into an engine.
