02-06-2012, 11:45 AM | #221 | ||
Rep 5,012
The secret of not dripping a single drop is to allow the filter cap to 'gulp' air from the back (facing the engine, which sits higher) for a few seconds. That allows the oil to flow down the sump. If you pull the cap too soon, that's when you make a mess. And it's not easy to clean freaking oil from the belt pulleys. And yes, I learned the hard way too . |
02-06-2012, 01:03 PM | #222 | |
Lurker
78
Rep 812
Maybe now that I've got it figured out I'll spend more time on the next change to look around at the other stuff under the car... for example, I've discovered that my front "felt" things are still intact despite a few steep driveways.
02-15-2012, 08:39 AM | #223 |
Rep 733
Yes these plugs should stick under the protective shield. The rear plug does slightly protrude, however if something big enough strikes this plug you have other issues as well as a CRACKED oil pan. The front plug fits rather nice. To each his own, I got tired of fucking with the allen wrench.
02-15-2012, 10:17 AM | #224 | |
Lurker
78
Rep 812
Here's the right way to do it: http://www.sears.com/shc/s/p_10153_12605_00942676000P
02-15-2012, 10:50 AM | #225 | |
Commander-In-Chief
2194
Rep 8,944
Drives: 2023 M2 Coupe, 2020 GLE 450
Hex bits for oil change
http://buy1.snapon.com/catalog/item....re&dir=catalog
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
03-08-2012, 07:00 PM | #226 |
Professional Semi-Truck Driver
Rep 14
GregW,what kind of syphon pump are you using and where does hose/tube get inserted?...I ran into a guy at the dealer buying oil and parts, but he was in a hurry and didn't give any specifics on the DIY oil change.
03-09-2012, 10:05 AM | #227 |
Commander-In-Chief
2194
Rep 8,944
Post #15. MityVac or turkey baster is only used to empty filter housing. Pan draining must be done via the two drain holes.
05-06-2012, 04:37 PM | #229 |
Rep 49
Drives: 2008 BMW M3 e90
Does anyone know any websites that have a good step by step oil change or video for the m3? I havnt done it yet on the car and am not used to this engine setup yet and don't wannabe to screw up.
05-06-2012, 05:37 PM | #230 | |
So Kewl Guy
49
Rep 619
http://www.billswebspace.com/bmwm3.htm ENJOY!
2010 E93 M3 / MS Catless X-Pipe / AA Catback / Vorsteiner Vented Hood and Bootlid E93 Trunk / ADV1 7.1 Wheels GB / LS3 LED Lights / Harrop Supercharger
06-01-2012, 04:25 PM | #231 |
Rep 1,376
Drives: 1988 M3, 1990 M3, 1998 M3/4
Garage List 1998 BMW M3/4 [10.00]
2011 BMW M3 Sedan [9.28] 1988 BMW M3 [9.40] 1990 BMW M3 [10.00] 2008 BMW 135i - sold [0.00] 2003 BMW M3 - sold [0.00] |
Took my car to the dealer today to get my 15k mile change before taking it to Heartland Park next weekend. James Clay suggested to me that I use some ZDDP at each oil change for protection on the bearings. Well, the dealer wouldn't put it in there so they left it a quart low for me to add. I added it and the level was still low. Added oil and was one notch from the top arrow. I decided to add a bit more and now it says >max. I figure I'm 1/4 quart overfilled. How to you guys suggest I fix this without draining everything and starting over?
1988 BMW M3 - Hennarot/Black
1990 BMW M3 racecar - Diamond Schwarz/Black 1998 BMW M3 - Alpine White/Mulberry 2011 BMW 328i racecar - LeMans Blue/Black |
06-01-2012, 04:52 PM | #232 | |
Commander-In-Chief
2194
Rep 8,944
06-01-2012, 04:55 PM | #233 | |
Commander-In-Chief
2194
Rep 8,944
Electronic level reading sucks.
06-01-2012, 05:09 PM | #234 | |
Rep 1,376
06-05-2012, 11:13 AM | #235 |
Rep 521
You guys crack me up. This is far and away the easiest and cleanest car to change oil on I have experienced. NO special tools (i.e. filter wrench) are required, and BMW even designed the engine bay such that you don't need a funnel to pour bottles of oil in (there is an oil-bottle sized void!). The only part that was moderately annoying was pouring 9 quarts out of the pan back into the bottles.
For the allen wrench plugs, to avoid stripping, ensure your wrench completely bottoms in the plug. Also, I wouldn't bother with the little bit of oil left in the filter. You are basically diluting that oil ~50-100:1 with the refill. Starting the car immediately after the oil change (with no oil in the filter) will cause far more damage than that little bit of used oil ever will. |
06-05-2012, 11:26 AM | #236 | |
European Editor
10616
Rep 22,992
That is why I always "back fill" the oil filter housing with some fresh oil after sucking out the old black stuff. Then I put the new filter on and I am good to go! |
06-05-2012, 12:21 PM | #237 |
Commander-In-Chief
2194
Rep 8,944
I keep several gallon or large size jugs around for packaging the oil to recycle.
07-10-2012, 11:31 AM | #238 |
Rep 729
What's the minimum height by which the car needs to be raised to be able to access the drain bolts? Would 3" all around be enough? I know I'll need make sure the oil drain pan fits under there as well.
I was thinking about getting these (http://www.raceramps.com/trak-jax-with-stopper.aspx) so that I could just drive on and drain the oil, without the need to jack the car up. |
07-10-2012, 12:21 PM | #239 | |
Lurker
78
Rep 812
You want the car level or just slightly nose-down so all the oil will drain. You need height for your 12 quart drain pain plus room for an allen wrench, preferable a torque wrench... say a minimum 9 inches, and I think the pan is normally just 4 inches off the ground, depending on your suspension.
07-20-2012, 08:04 AM | #240 |
No military grade
58
Rep 619
Over here, the material is ~300€ and work is almost 200€ in the BMW shop. I have full service including parts for 5 years / 100.000km, but BMW changed the condition based service interval for oil change to 25.000km. I had done ~12.000km after the run-in service and the oil was black already with still another 13.000km to go before the next due oil change.
So, I just did the oil change myself, which saved me a lot of money: Oil, filter, service lift rental and disposal fee set me back ~140€. Great DIY, apart from one point: BMW instructions tell to change the oil filter first after warming up the car. Simply put: Don't! The oil filter housing will be full of oil that spills over the motor if you do not drain the oil from underneath before. Maybe everyone knows this already - I didn't. Also, in my car the was a kind of "plastic sleeve" over the oil filter housing, but that could just be pulled off. With 8.6 liters the bar read 1/3rd over minimum, so I poured in a full 9 liters even without cleaning out the 0,2l rest in the filter housing. However, I gave it half an hour to completely stop dripping.
07-31-2012, 12:19 PM | #241 |
Rep 58
Does anyone know of a retailer that ships oil change kits internationally? If you ask for that around here people look at you funny (I live in Switzerland).
Rrrrreally? Youw wawnt to chaaege ze oil your zelf? Yauw must be crazzzzzy..." Drives me insane... |
08-15-2012, 07:29 PM | #242 | |
Rep 729
I have also seen numerous posts indicating the torque for the filter cover to be 25 Nm. However, I printed out the procedure and torque specs from TIS and it states 40 Nm for the filter cover. My car is a very late 2011 so perhaps the filter housing cover was changed. Lastly, I vacuumed out the oil in the filter housing with a 100 cc plastic syringe (http://www.amazon.com/gp/product/B00...ls_o01_s00_i00). I then measured all of the oil that I had drained and came up with right around 8.8 liters. Prior to the change the oil level indicator read at 1/8 below max. After the change, it's reading 1/4 above min (this is after ~120 miles of driving since the oil change). I recall that after my prior oil change, the indicator read low but after a week or so, popped up to 1/8 below max. But I also recall that 9 liters had been poured in. I really hate this electronic dip stick! I'll give it till next week to see where it ends up. |
