04-26-2024, 09:02 PM | #1 |
135
Rep 205
AA EL Mid and VRSF rattle.
Hello all, Ive been running my Dinan rear section with my AA Equal Length resonated midpipe and stock downpipes for about a month now and do belive that it is the best setup for this car. But me being the car crazy guy I am I decided to throw on VRSF downpipes to see how it sounds. The issue is it threw off the exhausts alignment so much that no matter what I did it rubs on the center brace. I decided to go back to my comp muffler to see if that does anything but of course it doesnt. Anyone have fitment issues with the AA el mid and downpipes? I should have just left the exhaust alone when I liked it.
04-26-2024, 09:18 PM | #3 |
135
Rep 205
04-26-2024, 09:36 PM | #5 |
135
Rep 205
04-26-2024, 09:45 PM | #6 |
Rep 1,065
There's a known resonance issue at ~2K RPM using catless DPs with either EL. Has been known for awhile. No solution to date.
Where are you in LA? I got the AA Single with Dinan rear if you wanna compare Last edited by louielouie; 04-26-2024 at 10:47 PM.. |
04-27-2024, 12:39 AM | #7 |
135
Rep 205
04-27-2024, 08:34 AM | #8 |
110
Rep 345
louielouie is correct. If you hear the buzz (sort of like wacking a bee hive) around 2k rpm, it is pretty much unavoidable unless you go back to stock downpipes (even catted will do it).
I've ran Remus, AA EL Res, Catted and catless dp. I went to single bc of this issue |
04-27-2024, 04:32 PM | #10 | |
135
Rep 205
04-28-2024, 04:16 PM | #11 | |
Rep 1,065
They both went through multiple iterations to try and fix it. It's catless paired with the EL. Can't be fixed as of right now |
04-28-2024, 08:33 PM | #12 | |
135
Rep 205
I ordered the single mid to try the resonated version. It sounds decent with the EL but very raspy. |
05-01-2024, 06:12 PM | #13 | |
Rep 559
Drives: F82 M4 BSM
Catless DP + AA Single Res + MPE is what Im running and by far one of the best that I've heard
17' F82 BSM - Current Built Motor/PS2+
16' F82 Silverstone - Totaled FBO |
