07-14-2014, 11:46 PM | #67 | |
Rep 1,089
Thanks I passed along to try the OS Gikken oil.
F80 M3 HRE FF04 275/305.
07-15-2014, 02:18 AM | #68 |
469
Rep 280
Drives: M2 F87, M3 E92 & E46, C63, 911
Garage List 2018 BMW M2 F87 [0.00]
2008 BMW M3 E92 [0.00] 2003 BMW M3 E46 [0.00] 2012 BMW M3 E92 [0.00] 2011 Merc C63 AMG [9.00] |
this will not change the whining noise! they need to set it up properly.
DrFerry6731.50 |
08-06-2014, 05:56 PM | #69 |
Rep 1,089
So are you saying that setup properly there will be no noise and it will sound identical to the stock LSD setup? Note I didn't change gearing, just LSD. Do you happen to have the backlash specs so I can check? Can I check same without removing it from the car or unbolting anything? I have a dial indicator with a mount so I can check the backlash say of the input shaft and side output flange hole. Thanks! It isn't that noisy now with the diff bushing removed but I can still hear it, especially under deceleration and downhill. Thanks. Otherwise, I do have to say that it is a huge improvement over the stock wasted diff!
08-07-2014, 03:17 AM | #70 |
Rep 5
hi driftflo,
you've mentioned that draxler LSD is the one used in gt4, am i right to say that draxler LSD is inside the gt4 final drive unit (bmw motorsport part # 8321819)? and also just in case you may know - can i replace stock e90 m3 final drive with the gt4 unit mentioned above? is it plug and play? many thanks |
08-07-2014, 04:59 PM | #71 | |
469
Rep 280
if you have a 6MT this is the weapon of choice... if you have an auto it will also fit straight in but the ratio (i=4.10) is too short! is the 8321819 still available from bmw ms? i thought they ran out of stock :-( |
DrFerry6731.50 |
08-07-2014, 05:04 PM | #72 | |
469
Rep 280
backlash is measured like this: should be around 0,10mm! |
DrFerry6731.50 |
08-08-2014, 12:10 PM | #73 | |
732
Rep 3,735
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
08-08-2014, 12:31 PM | #74 | ||
Rep 1,681
08-08-2014, 05:40 PM | #75 |
469
Rep 280
depends on the usecase of the car? concerning performance reasons i would go with a 3.62 final drive and a properly configured clutch-type LSD. of course i think my custom unit and setup is the best (this is why i do set it up like this) but it also depends on individual driver preferences on how the car should react and handle.
DrFerry6731.50 |
08-09-2014, 12:08 AM | #76 | |
Rep 1,681
08-09-2014, 12:32 AM | #77 | |
Rep 447
Thanks again Driftlow for the great community info and product offering!
DCT. Custom Cantrell MS cage. Fire, SCCA, dedicated track. Diffs-online 3.62, diff cooler, MCS 2-ways, SPL arms, TMS solid SF/Diff bushings, RD sway, DO88 Coolers (DCT, RAD, PS, OIL) Akra catless GT4, BPM tune, Hans Recaro, AP Pro 5000R, Cobalt XR2/4 race pads, BBS E88's, Yoko A005 slicks, RKP GT4 Splitter, GT4 canards, APR GT250 Wing, CFK Hood, Flossman CFK fenders, BW carbon doors, Dinan R toe links, Mini battery.
08-11-2014, 07:30 AM | #78 |
Rep 5
hey driftflo,
thank you very much for your input, going to replace my almost dead stock final drive with #8321819 then my local shop claimed to deliver it in about a month (so i assume they are out of stock but can still can be produced) |
09-10-2014, 03:06 PM | #79 |
469
Rep 280
so finally i found some time to disassemble, check and rebuild my new bacci lsd unit that i bought a few months ago when we collected a friends C63 gearbox at their factory in italy.
the internal design is pretty much like the zf/drexler units that i like the most anyway... but it had quite much preload and the shallow 30° ramps activated. both options i dont like that much. so i changed the setup to what i expect to handle better or at least better suits my taste. i removed the preload springs, added a clutchpack on each side, switched to own specially manufactured clutches and rotated the axles to the steeper ramps. now i have to throw it in one of the rear axles laying around in my shop. and then i need to find time to fit it in the car. so i guess it'll take a while until i can tell you first hand how it actually feels like. although i dont expect too much surprises as all relevant parts are well know to me already. anyway i'll keep you updated here... by the way: it is the lightest of all units a had so far (9.6kg)... and the second most expensive short after the GT4 unit (eur 2.300,- incl. custom side axles). Last edited by driftflo; 09-10-2014 at 03:17 PM.. |
DrFerry6731.50 |
09-10-2014, 08:22 PM | #80 | |
Rep 1,665
09-11-2014, 03:20 PM | #81 |
469
Rep 280
i do not use kits. i have several thousands of clutches from different sources or produced to my own specifications. so i use the parts that i think are the best for the certain application.
the clutchpacks i put in the bacci lsd are completely self-designed and produced to my specs. thicker moly coating with better surface finishing, harder steel... |
DrFerry6731.50 |
09-11-2014, 05:48 PM | #82 | |
Rep 1,665
09-11-2014, 06:51 PM | #83 |
Rep 3,742
A little off topic, but I have some diff whine in my OEM diff since switching to solid subframe and delrin differential mounts. Not a huge deal, but I'm hoping to reduce it as much as possible. I'm going to give Redline Lightweight Shockproof gear oil a try. I'll try to report back with results. Might be something to consider for those of you with diff whine.
09-12-2014, 02:29 AM | #84 |
469
Rep 280
i have all kinds of oe bearings (koyo, ***) in stock. as well as spacer discs for the lsd and pinion (custom made as no more available at bmw). i have them lasercut and shaved to the right sizes. shaft seals are still available from bmw.
DrFerry6731.50 |
09-12-2014, 04:05 AM | #85 |
Rep 1,665
Could you please pm me a price on the bearings and what ever else I would need to rebuild my diff?
09-12-2014, 05:11 AM | #86 |
469
Rep 280
to rebuild the diff you need a lot of special tools. buying them to rebuild one diff does not make sense.
i'll pn you the prices for a set of bearings. if you need certain spacers you can have them from me as well... but you need to measure and tell me the size you need first. buying the complete sets would set you back some 100 $ :-( |
DrFerry6731.50 |
11-09-2014, 06:32 AM | #87 | |
Rep 3,360
I'm curious about the stock E39 M5 diff also. Do you have the specs on it? I know it is a "weak" LSD from 12 years of personal experience with it including wearing out the discs (and stupidly replacing it with another OEM unit...but I got a price on a new unit that was too good to pass up). Does it have any locking on deceleration, or is it open? Ramp angles? Thanks, Chuck
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 |
11-09-2014, 10:21 AM | #88 |
469
Rep 280
yes i have some m5 e39 units here. they come with only 2 clutchpacks and a 2-way setup which does 25% lockup on both, accel and decel.
and it has pretty much preload. i developed a rebuild kit that fits plug and play with the double amount of clutches. so it locks 45% in both directions. clutches are higher quality than standard, too. if you want preload and/or even more lockup you need some exchange parts like different pressure rings, modified topcaps... so the basic unit itself is a great basis but it comes as standard with a pretty low locking setup and wears out quickly. |
DrFerry6731.50 |
