BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > 330i Rear Diff Swap with AT 3.64 diff questions (Updated video)
      02-03-2015, 12:25 PM   #1
Volasko
Volasko's Avatar
705
Drives: 06 330i E90, 18 530xe G30
This thread goes out to any members who have completed the above rear diff swap from their MT 330i. I am really interested in doing this but I am hesitant about the nearly 15% increase in RPM's from a daily driver perspective. How much do the added revs affect the day-to-day livability of the car. I do a lot of hwy driving and fear the higher cruise rpm will cause exhaust drone (just a PE). Also did anyone notice a big drop in fuel economy especially at highway speeds? So for those who did it how much am I over thinking this. Are there any dif swaps that are plug and play (ie. no modifications to the input and output shafts)
Edit: See video on 2nd page of acceleration with new diff!
      02-03-2015, 10:13 PM   #2
dragonsi
66
Drives: 2008 M3
I have a 2006 330i MT with the automatic 2006 330i differential, coupled with an M factory LSD. The automatic 2006 330i differential is a direct swap.
As far as MPG, before I would get about 22 mpg on average, now I get roughly 21.5-21.8 mpg. It is the lowest its been at right now which I would attribute to the winter gas.
I was afraid of the highway cruising speed as well since I like to cruise around 75-80 mph,in Mexico. It's hard to describe the difference, yes you do feel the car operating at a higher rpm, but it's really the nature of the car that has changed. Now the car feels like it's begging you to go faster.
I highly recommend this to anyone looking to add more "sport" to their car, it is certainly worth it for how much it costs. If you can afford it, definitely get an M factory LSD to go with it. Like others have said, the car should of came from the factory like this.
Appreciate 3
Volasko705.00
lab_rat394.50
dwashy64.50
      02-04-2015, 08:37 AM   #3
Volasko
Volasko's Avatar
705
Thanks for the reply. I'm glad your sentiment about the swap follows what others have said with respect to how much you like it. I'm not interested in the LSD at this point (too much $) as aside from the diff swap I am planning on refreshing all diff, tranny and engine bushing/mounts at the time of the swap. Probably need to do a clutch refresh while I am at it.
      02-04-2015, 09:00 AM   #4
mbanks21
1268
Drives: 2015 335i MSport
I've been researching this for a while as well and have sourced a few auto diffs around my area for $250-300 so even if I don't like it it's not a huge loss. Everyone I've seen that's done it is happy. I also don't do a LOT of highway driving so I'm not too concerned about higher RPMs.
      02-04-2015, 01:40 PM   #5
F30RiK
Drives: 13' 335 xdrive M-sport 6 Speed
Worth every penny, do it
      02-05-2015, 08:35 PM   #6
Volasko
Volasko's Avatar
705
I have yet to see ANY video of a N52 stock or modified running the through the first 3 gears with this modification! Please someone make an easy video with your phone and youtube that!
      02-06-2015, 03:15 PM   #7
F30RiK
Ill do it soon
      02-08-2015, 11:38 AM   #8
driverman
Drives: 2008 328i 6MT - SOLD
I've been considering doing this for my 2008 328i MT. It is easy to swap the auto diff (3.73) for my MT diff (3.23) on the 2007-2008 models like it is for the 2006 models? Can i use the diff from an auto 335i (3.46)?
The thought of having 15% more torque applied to the rear wheels is very appealing but I too am concerned about the increased revs on the highway. To get a feel for what it would be like, I downshifted from 6th to 5th gear while going 70 mph. There's about a 15% difference between those gears. I don't think I want the higher revs because I spend a lot of time on the highway.
      02-08-2015, 12:08 PM   #9
hassmaschine
Drives: "NBO" 330i
You could use the 3.64 from a 330i automatic.
      02-11-2015, 12:49 PM   #10
Volasko
Volasko's Avatar
705
Just bought 330i AT rear diff from a wreckers yard for $240 after tax! Car is winter stored now, anyone attempt to DIY this swap? Doesn't look too hard and I am in no rush?
Edit: I have the loose diff in the my basement and when I turn one of the output flanges', while holding the input flange, it to makes a clicking noise. When just turning the input shaft it is smooth as butter. See this quick vid for a reference, is this normal??
Update: It is normal. I removed my original diff and it also made the same noise.
      02-12-2015, 07:33 PM   #11
Volasko
Volasko's Avatar
705
troubleshooting help bump!
      02-19-2015, 09:21 PM   #12
mbanks21
1268
No idea if that's normal but I just swapped my 3.15 for a 3.64 and couldn't be happier. Rpm is only 3-500 higher than normal but every gear feels like a turbo kicks in. Found one with 51k miles.
      02-19-2015, 09:25 PM   #13
PureE92
90
Drives: E92
I wonder if you could swap a 3.64 from a 330i into a 328i? Or a 3.91/3.73 from an auto 328i to a manual 328i? And if it would be a direct fit.
      02-20-2015, 12:58 AM   #14
approximate
Bavarian Idiot
Germany
29
Drives: 2007 E92 325i 6MT
does fit directly!
      03-11-2015, 06:35 AM   #15
DRiiFTAHOLiiK_e90
DRiiFTAHOLiiK_e90's Avatar
Drives: e90
when you had the lsd put in did you have the bearings inside the diff replaced? currently right now i have my 3.64 diff in hand and a after market lsd and im trying to find bearing specs so i can replace them with new ones
      03-11-2015, 08:24 AM   #16
chris82
chris82's Avatar
Drives: 128i
2009 BMW 128i  [9.80]
Can one of you guys put a video up of the acceleration?
      03-15-2015, 11:40 PM   #17
dragonsi
66
Drives: 2008 M3
I had M factory do the install for me and I think that they did replace the bearings inside as well. Try asking them, they're a board sponsor.
      03-16-2015, 12:01 PM   #18
neoduffer
Fast In, Slow Out
Drives: 06 E90 330i
2006 330i  [0.00]
MFactory has bearings and other parts available for the rebuild.
http://www.e90post.com/forums/showthread.php?t=1097995
: Ken
      03-16-2015, 02:30 PM   #19
GTKrockeTT
22
Drives:
i went with a 3.38 out of a 328xi MT. had to get the input flange swapped out though. my 07 328i MT was a four bolt, whereas the sourced 07 328xi MT assembly had a 3 bolt.
      05-26-2015, 08:41 PM   #20
Volasko
Volasko's Avatar
705
I finally got my car back on the road after my winter rear suspension rebuild. I just gotta say how happy I am with the new final drive ratio. I haven't had enough time on the road to properly comment about the fuel economy, but the new found acceleration is making me fall in love with the car all over again. This really is the final drive ratio BMW should have put in the car to begin with. I am super happy with this mod and recommend it to anyone with a 330i.
      05-26-2015, 09:35 PM   #21
mbanks21
1268
I have a 3.73 auto diff from an 09 328i if someone with a manual wants to upgrade. PM me!
      05-27-2015, 01:33 PM   #22
Jashley73
80
Drives: '06 330i 6-M/T
So obviously, this will require some software tuning, to correct the speedometer, correct? Any idea what this would cost to have done? Not interested in a performance tune, so I'm guessing this would need to be done at a dealer or Indy shop?
I'm getting slightly more interested in this diff swap...
