The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > What is best tune for n51?
      12-09-2016, 04:17 AM   #23
WhiteBeard
Drives: slowly
Ok last question before I pull trigger today for midpipes: does anyone know if they will fit without adjustments to xi and automatic? I've read some posts that they had to modify them for xi and some shops advertise midpipes for manual tranny only? I'm a bit confused
      12-09-2016, 05:55 AM   #24
Taskmaster
Japan
2465
Drives: M235i 6MT / E92 328 Msport 6MT
Super Sprint midpipes are on sale at Turner I believe, it's what I have. And yes, they fit all versions of the N52 E90.
      12-09-2016, 08:31 AM   #25
Taskmaster
Japan
2465
Originally Posted by GermanInCA View Post
TheAxiom can you describe the difference between BPC Stage I tune (I assume that's the only street-legal one from BPC) and AA tune?
I'm on AA myself right now, and curious just how much better (if at all) BPC is.
Well for one, it will absolutely make more power. And if you want to expand on it in the future, I KNOW their header tune is superior.
      12-09-2016, 08:37 AM   #26
WhiteBeard
Drives: slowly
Do you know if they are 2.25 or 2.5 diameter?
      12-09-2016, 09:11 AM   #27
Taskmaster
Japan
2465
Around 2.25, like 56-58mm I think?
      12-09-2016, 09:15 AM   #28
WhiteBeard
Drives: slowly
Thank you! I am debating if AFE midpipes will be better since they are 2.5' vs 2.25 SS midpipes? I'm only looking for best sound with my PE - that's all. Which one would you recommend to buy?
      12-09-2016, 09:23 AM   #29
Taskmaster
Japan
2465
Go with the SuperSprint. They are cheaper, they will flow as well. I believe the AFE pipes actually lost some exhaust velocity and caused torque to drop a bit.
      12-09-2016, 06:04 PM   #30
WhiteBeard
Drives: slowly
Ok, so I ordered SS mid pipes and 2 gaskets between SS and headers. However, I can't find bolts anywhere (I believe I'll need 4 bolts). Anyone has links? Thank you
tdavis42180.50
      12-09-2016, 06:27 PM   #31
tdavis42
tdavis42's Avatar
181
Drives: 08 E90 328i ZSP AT
2008 328i  [0.00]
Do you get the occasional backfire? I get some loud burbles and every once in awhile I get a low backfire(at least I think it's a backfire) when I let off the gas.
      12-09-2016, 06:28 PM   #32
tdavis42
tdavis42's Avatar
181
2008 328i  [0.00]
http://www.realoem.com/bmw/enUS/show...diagId=18_0587 bolts and nuts
      12-09-2016, 06:48 PM   #33
WhiteBeard
Drives: slowly
Originally Posted by tdavis42 View Post
tdavis, on this view http://www.realoem.com/bmw/enUS/show...88#18107549447 I was just wondering if I need parts # 4,6,7,12,13 - I guess I don't need them, I can just reuse old ones right? It's just that I think maybe your drone is due to one of these missing or not properly tightened, no?
      12-09-2016, 06:52 PM   #34
tdavis42
tdavis42's Avatar
181
2008 328i  [0.00]
I edited the original link to reflect the correct exploded view. Click the link again.
should be;
4 x #5
4 x #7
2 x #6
That's four bolts, four nuts, and two elastomer seals that will go between the headers and midpipes.
I think I found my slight rattle......it was the heat shield on the wire for an O2 sensor. I think
      12-10-2016, 08:32 AM   #35
STR8-6IX
536
Drives: RWD 528i N52
Ok, so I found out that primary cats are must have, but secondaries are not MUST haves to pass emission test in Ontario. So given that new (for me) info - I'm confused: does deleting secondary cats increase, decrease or do nothing in terms of power gain? Searched on forum and some say it steals away 5-10 hp, others say it adds 5-9hp and many say it basically does nothing in terms of gain since they are not at all restrictive (unlike primary cats). Not sure who is right. Educate me please guys?
The secondaries are somewhat restrictive. while its no primary cat - type restriction, they are fairly close to the motor and do rob power. I noticed a roughly 4-5HP increase and maybe 2-3 FT/LB of torque along with better throttle response. Engine sounds alot more "Racey" and performance like - lots of deep exhaust sound coming from underneath the driver. from 4000rpm onwards to redline, top end pull has noticeably improved. there ARE gains to be had from deleting secondaries and its often the first step to be considering when looking into exhaust modifications.
      12-10-2016, 08:34 AM   #36
STR8-6IX
536
If I remove secondaries, how loud will PE become? I'm just afraid it to get too loud or drone, no? And what is best to weld in instead of secondaries - I mean any straight pipe of same diameter at any local muffler shop or should i order some brand pipes? Thank you
Exhaust note wouldnt be that much different - just a tad deeper. you will get more engine sound and it WILL NOT drone. Mid pipes are a waste of money, just get it done at any half-reputable exhaust shop.
      12-10-2016, 08:46 AM   #37
Mike.
Mike: Everyone's Pal
Mike.'s Avatar
2044
Drives: F80 M3
2013 BMW 335xi  [10.00]
strange my secondary cat delete with PE drones at like 3K
Alpine MSS Stage 2+ E30 tune|MST Intakes|VRSF Single Mid Pipe|Agency Power Intercooler|VTT Full solution crank hub fix
      12-10-2016, 12:03 PM   #38
3002 tii
3002 tii's Avatar
2286
Drives: Z4 M, X5, GX460
Turner notes the SS section 1 can work with oe exhaust but requires trimming the SS pipes, anyone know how much need to be cut off? And any reason you can't just cut the oe pipes do fit SS instead of other way around?
Fitment note: this Supersprint section 1 is longer than the section 1 of the stock exhaust. By cutting some of the pipe from the Supersprint you may be able to mount this to the stock exhaust. The factory BMW sleeve clamp (or similar 55mm clamp) must be used (BMW # 18307560778).
Follow for latest mods
      12-10-2016, 02:45 PM   #39
STR8-6IX
536
thats what the performance exhaust does. its likely due to the fact you dont have your resonator. if you want good exhaust flow without drone, upgrade the muffler and remove seconaries. retaining your resonators WILL NOT cause any drone.
      12-10-2016, 03:22 PM   #40
sprp85
Drives: S54/N52
2006 E46 M3  [0.00]
2007 E91 328i  [0.00]
http://www.e90post.com/forums/showthread.php?p=17652907
Dug up old FS thread stating it required trimming of about 3 inches.
Just get both sections
SS1 and SS2.
      12-13-2016, 04:10 AM   #41
Rogue-OP
Rogue-OP's Avatar
58
Drives: to Drum & Bass
I'm also in a similar boat (looking to increase performance of my N51). Anyone got a link to the Bpc tune? I can't find it on their web store.
https://bimmer-performance-center.my...m/search?q=N51
      12-14-2016, 04:25 AM   #42
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Drives: F32 435ix MSport
Page 4 on their site...
https://bimmer-performance-center.my...e39-dme-tuning
N52=N51
Just let them know you have N51 with factory installed 3 stage
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      12-14-2016, 10:05 AM   #43
tdavis42
tdavis42's Avatar
181
2008 328i  [0.00]
I just installed the BPC tune and on an AT it feels great. Bob has been awesome with support. First gear is still way too short(no fault of BPC's) I'm just glad I can launch in second where the car feels more natural.
Ruddigger694.00
      12-14-2016, 10:57 AM   #44
Rogue-OP
Rogue-OP's Avatar
58
N52=N51
Thanks for the info and link!
I'm reading this on that page and am a bit confused as I live in California.
Not for sale or use on any pollution controlled vehicle in the state of California.
