      04-13-2022, 09:44 PM   #67
PRTSB1M
Drives: AW3 1M
Originally Posted by CarJunkie View Post
How did that happen to the axle?
      04-15-2022, 11:22 AM   #68
Six Pot
Six Pot's Avatar
Drives: 1M
2008 135i  [0.00]
2007 BMW M5  [0.00]
Was so seized that it started to bend when pressing it out 😐. Fixed!
2011 BMW VO 1M (Currently in pieces for New Build!)
==OLD SETUP==
ViE 3884 | PR | JB4 | EOS Billet Fuel / Manifold | Seibon Hood | Spec Twin | 900IC | Slek Lip / Diffuser | EC7 Wheels | KW HAS | Maddad + GTHaus | P3 | ViE Can
      04-15-2022, 01:06 PM   #69
SAMM3Y
SAMM3Y's Avatar
3085
Drives: 2008 m3
Glad you found one! When I looked recently for love nor $ were they available.
9ers
      04-15-2022, 01:38 PM   #70
PRTSB1M
Drives: AW3 1M
Great fish story
Leave the axle nut on and use a deadblow next time… maybe a little heat.
      04-15-2022, 01:41 PM   #71
Six Pot
Six Pot's Avatar
Drives: 1M
2008 135i  [0.00]
2007 BMW M5  [0.00]
Great fish story
Not sure what is meant by fish story. I had a shop press them out after I tried that method 😑
==OLD SETUP==
      04-15-2022, 08:22 PM   #72
PRTSB1M
Drives: AW3 1M
The end of that axle is pretty well destroyed… you clearly left out some details for a better carnage story. I’ve not actually heard someone say they had to press an axle out before. I probably would’ve tried pulling the hub instead. Glad you got it fixed, but they definitely doubled the price on axles a while back.
      04-26-2022, 10:07 PM   #73
Six Pot
Six Pot's Avatar
Drives: 1M
2008 135i  [0.00]
2007 BMW M5  [0.00]
Very close to start up, chasing a MRS ignition error that is blocking injectors
For those who were wondering about cooling here is the final solution. The M3 crash bar , oil cooler brackets , and M3 structure support are fused together. We drilled out the 4 rivets and then used the 1M structure , M3 cooler brackets and M3 CF crash bar! We were also able to retain the ducting channel for the air to extract out of the bottom Mporium plate :-)
==OLD SETUP==
      04-27-2022, 03:15 AM   #74
WrathOTM
WrathOTM's Avatar
543
Drives: BMW 128i
well damn, that is looking pretty nice now that you are almost there. Good luck with the injector issues.
Mods to date: The list grows...
      04-27-2022, 04:15 PM   #75
Snertz
H O O N
Snertz's Avatar
Drives: ein M!
Any idea what the weight difference is between the 1M crash bar and the M3 CF bar?
The M3 bar drops right in?
U WOT M8?
      04-27-2022, 08:41 PM   #76
Six Pot
Six Pot's Avatar
Drives: 1M
2008 135i  [0.00]
2007 BMW M5  [0.00]
Feels like there is maybe a couple pounds in savings, may weight tomorrow. The biggest win for me was the cooler , ducts, and horn mounts.
It fits fine minus the ducts as the M3 ducts are slightly narrower and wider than the 1M ducts. Hurts to dremel my CF ducts but must be done.
==OLD SETUP==
      04-28-2022, 07:28 AM   #77
PRTSB1M
Drives: AW3 1M
The best part about watching these builds is the brave moments when expensive parts are cut in the name of fitment
      04-28-2022, 10:01 PM   #78
Six Pot
Six Pot's Avatar
Drives: 1M
2008 135i  [0.00]
2007 BMW M5  [0.00]
She lives!
==OLD SETUP==
Appreciate 4
mtl8852.00
SAMM3Y3085.00
      04-29-2022, 05:37 AM   #79
Morangers7
Morangers7's Avatar
Drives: 2022 BMW X3MC
She lives!
This was the video I was hoping to see when I woke up! Can't wait to see the finished product
      05-04-2022, 11:36 PM   #80
Six Pot
Six Pot's Avatar
Drives: 1M
2008 135i  [0.00]
2007 BMW M5  [0.00]
Think we are close. All cooling systems ready to go, lines bleed to validate M3 line merge was solid as it all had to be relocated.
Investigating a small sensor issue… I think 🤔. It seems I didn't tighten the oil filter pipes tight enough and saw a small drip but no other leaky bits.
Pardon the brake shield, hoping to get all alignment work done next week. They are going to hate me lol.
==OLD SETUP==
Appreciate 4
      05-09-2022, 06:46 PM   #81
Six Pot
Six Pot's Avatar
Drives: 1M
2008 135i  [0.00]
2007 BMW M5  [0.00]
All small issues sorted. All modules in place and all the RPMs on tap!
==OLD SETUP==
Appreciate 3
CarJunkie2616.50
      05-09-2022, 08:00 PM   #82
CarJunkie
CarJunkie's Avatar
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
Damn!!!
1M track toy mods: BMS chargepipe, BMS OCC, ADE FMIC, ADE motor mounts, MadDad/Lightweight Ti exhaust, ADE custom oil thermostat/cooler, custom MHD tune, F10 550i clutch, Ohlins R+T, Vorschlag camber plates, M3 'vert FSB with Turner endlinks, Stoptech Trophy BBK.
      05-12-2022, 03:13 AM   #83
WrathOTM
WrathOTM's Avatar
543
Drives: BMW 128i
hell yeah, that sounds sweet!
      05-12-2022, 02:45 PM   #84
Tut4u2
235
Drives: 1M3 Conversion
What's the plan to mount the front bumper with the M3 crash bar? I couldn't get mine to fit with my swap.
Looks and sounds great!
      05-12-2022, 03:21 PM   #85
amg6975
amg6975's Avatar
500
Drives: '12 M1.5, '05 ZHP, '98 M3/4/5
It doesn't fit. You need to cut up the carbon unit, the weight savings is negligible, and the tow hook bung doesn't line up. I tried really hard, unsuccessfully, to get it to work.
      05-12-2022, 05:09 PM   #86
Tut4u2
235
Yep..same experience as me.
      05-12-2022, 06:21 PM   #87
Six Pot
Six Pot's Avatar
Drives: 1M
2008 135i  [0.00]
2007 BMW M5  [0.00]
From what I can tell is if we don't use the foam and trim the ducts it seems it will clear. Guess I'll find out soon enough 😂
==OLD SETUP==
      05-21-2022, 04:00 PM   #88
Six Pot
Six Pot's Avatar
Drives: 1M
2008 135i  [0.00]
2007 BMW M5  [0.00]
For those who think you can't use the M3 crash bar, you can easily fit it minus a little trimming. Tow hook placement works just fine!
==OLD SETUP==
Appreciate 3
Snertz85.50
Yeineken1300.50
