      11-10-2015, 03:30 AM   #45
Nagata-San
Homyseed
Nagata-San's Avatar
Switzerland
69
Drives: '11 BMW 1M AW
TTT
What code allows to suppress the error about:
Since I got recaro poleposition and harness
- Airbag
- Belts
and also
- decat
Thanks !
NOW: '11 BMW 1M AW "Nabila"
PREVIOUS: '09 BMW 335i DKG (DCT) "never too big"
BEFORE:'09 BMW 135i F1 Sauber Edition 120/135
Team Homyseed
      11-10-2015, 05:27 AM   #46
Em/1
Em/1's Avatar
Drives: 2011 1M VO
2019 VW GTI SE  [0.00]
2020 Tesla M3P  [0.00]
2011 BMW 1M  [0.00]
Originally Posted by toni8284 View Post
Hi - couple of questions...
My car already closes/opens the windows via the remote (if I hold down the lock/unlock button). Does your first coding mean something different ?
Answer # did you code it already or your car comes with the close/open window via the remote? if you applied the code, it will close/open the window via the remote.
Second, I can configure the door unlock when ignition is turned off in the idrive settings (or am I confusing this with something else?)
Answer # For my car, i have comfort access, and if i turn off the car (push the start/stop button), before coding, it won't unlock the door for me. but after I change that, it will.
I like the idea of the mirrors folding/unfolding when the car is locked.
And what is the corner delete ?
Answer # if your car is in UK, you dont have to do that. it's only USA car.
Is there an independent garage that can do somet of this coding for me in the London/Surrey area ? [UK] ? I don't fancy having BMW extort more money out of me...
Some of us in the US want to know what the corner delete is? Is that the maneuver that MDORPHIN did to get rid of the cornering problem with the ESC?
      11-10-2015, 08:11 AM   #47
fjgregor
fjgregor's Avatar
42
Drives: 2012 E92 M3 Laguna Seca Blue
Its when you turn off your amber turn signals completely off, giving you the angel eyes only. Turn signals will only light up with hazard lights and when you engage the switch in the steering wheel to turn.
2009 135i e82 Alpine White N54 DNF
2012 M3 E92 Laguna Seca Blue S65
Toa Alta, Puerto Rico
      11-10-2015, 08:18 AM   #48
eeghie
Kind of a big deal
300
Drives: an 1M not often enough
To get rid of that 'cornering problem': My personal suspicion is that setting the 1MDSC module parameter LAT_EBD to 'nicht_aktiv' will disable the CBC portion of the full ABS functionality. So far this is unconfirmed by me nor professionals.
      12-01-2015, 09:15 AM   #49
T1M
Australia
196
Drives: AW MY12 1M
Originally Posted by eeghie View Post
Yes, here we go, Mirror memory in Keyfob is stored in FRM (a module we all have), however this module will only be able to set the mirror if you have an advanced mirror version (in case of the US 1M this only comes with the premium package, this advanced mirror version is connected with a so called LIN bus/cable. The stripper mirror can only be heated).
The good news is that with a retrofit of these advanced mirrors you can get folding, dimming, keyfob memory and curb monitor all at once. This certainly the route I want to go.
One note on the curb monitor, I'm reading that many users consider it not helpful because the tilting is not far enough down to see the curb. For this an additional (not so standard) coding is possible. (see the BMW coding website for details)
I have a fully optioned 1M, the mirror does indeed move far enough to see the curb. I can line up my rear wheel nicely with it.
      12-01-2015, 10:54 AM   #50
EldRick
Drives: 1M VO - #161 US
Does anyone have a way to default the display to Off?
99% of the time I find it distracting, and I've assigned one of the buttons as a one-press Display Off, but I'd sure like for it to turn off all by itself.
      09-10-2016, 02:49 AM   #51
jpet
Australia
Drives: M2 Competition
Hey guys, having issues with the ECU restoring default settings every time I make a change on NCS Expert to the CIC module.
I am able to read modules / change values/ create the required MAN file and upload it to ECU (SG_CODIEREN) (no errors) Once done I check the value changed and it has restored to default...is anyone else having this issue?
Running...
EDIABAS 7.3.0
NCS Expert 4.0.1
Integrated SP-DATEN v53.3
Values being changed:
Disable iDrive Disclaimer
CIC
LEGAL_DISCLAIMER_TIME
kein_ld
1.
CIC
VIDEO_NUR_MIT_HANDBREMSE
nicht_aktiv
2.
CIC
SPEEDLOCK_X_KMH_MAX_C0E
3_kmh
3.
CIC
SPEEDLOCK_X_KMH_MIN_C0E
3_kmh
Any help much appreciated.
      09-15-2016, 03:08 PM   #52
eeghie
Kind of a big deal
300
Check step 31
      09-23-2016, 12:43 AM   #53
jpet
Australia
Check step 31
Thanks buddy...all sorted
      12-23-2016, 03:24 AM   #54
Muppet
46
Drives: 2011 135i M Sport
Would it be possible to obtain from a 1M owner a copy of the trace files of the car's JBBF, CAS and NFRM ecus?
I wish to compare them with that of a N55 135i.
Cheers.
      01-11-2018, 05:59 AM   #55
gmx
Drives: VO 1M
Anybody identified if 1M module(s) have these:
Brake Fading Compensation (FBS)
Code:
STOCK:
C0F_FBS
        wert_01
Coded Off?:
C0F_FBS
	wert_00
Engine Power Reduction to Prevent Brake Disc Overheating (FLR)
Code:
STOCK:
C0F_FLR
          wert_01
Coded Off?:
C0F_FLR
	  wert_00
	  wert_02
      01-24-2018, 07:09 PM   #56
Eagle01
Drives: BMW 1M white
Hi,
I just got my car on 10/27.
And I already coded all the stuffs I needed.
So I would like to share that info for the others before I forget:
Function
Module
Field
Value
Close Windows/Roof with CA
CAS
KOMFORTSCHLIESSUNG_PA
aktiv
Close Windows/Roof with Fob
CAS
KOMFORTSCHLIESSUNG_FB
aktiv
Unlock Doors when turn off the car
CAS
ER_KEYOUT_AUTOVR
aktiv
Corner Delete Mod
NFRM
SIDEMARKER_US_MIT_FRA_V
nicht_aktiv
using your remote to open and close Mirror
NFRM
ASP_KOMFORT_EINKLAPP
aktiv
this is for the CIC (with iDrive)
NOTE: make sure you update it with the daten v43.
CIC
kein_ld
for video in motion ( you required all 4)
1.
CIC
nicht_aktiv
2.
CIC
3_kmh
3.
CIC
3_kmh
4. The most important
I found out for my car, it used CIC.C1A file.
Happy Coding!!!
Can you please help with the steps needed for the video in motion ?
Thanks.
      01-25-2018, 03:40 PM   #57
JP-1M
JP-1M's Avatar
Japan
171
Drives: Alpine White 1M
Hi,
Function
Module
Field
Value
CAS
aktiv
CAS
aktiv
CAS
ER_KEYOUT_AUTOVR
aktiv
Corner Delete Mod
NFRM
nicht_aktiv
NFRM
aktiv
CIC
kein_ld
1.
CIC
nicht_aktiv
2.
CIC
3_kmh
3.
CIC
3_kmh
Happy Coding!!!
Thanks.
You need hardware and software to change the "codes" currently configured in your cars memory. You can find various options in the forums, I use Carly.
http://support.mycarly.com/knowledge...t-is-possible/
Relevant excerpt:
Video in motion 1/2
? on
? off
Enable video and DVD while driving. This is only possible if the car supports watching TV or playing DVDs while standing. In order to enable this option, activate 'Video in motion 2/2' as well. (codable in CIC)
Video in motion 2/2
? on
? off
Only change this function with 'Video in motion 1/2'. This is only possible if the car supports watching TV or playing DVDs while standing. (codable in CIC)
Video in motion
? during driving
? only walking pace
? only when handbrake pulled
? not active
Enable video and DVD while driving. This is only possible if the car supports watching TV or playing DVDs while standing. (codable in CCC)
Disclaimer: I in no way receive money from Carly. I just find their documentation very helpful.
American driving an Italian market German car in Japan.
      01-25-2018, 06:45 PM   #58
Eagle01
I appreciate your help. I’ll try to go that route.
Thanks.
      04-17-2018, 06:15 AM   #59
henry2012
Drives: 2011 1m
coding
much appreciate the codes you shared ill have to try them out
      09-26-2018, 12:36 PM   #60
Pete.J
Pete.J's Avatar
Australia
322
Drives: BMW M4 DCT (F82)
Anyone tried this?
I want to get rid of CBC (Corner Braking Control), and I am not sure which parameter to turn off.
Thanks in advance!
Current: F82 Mineral White M4 7DCT
Gone but never forgotten: E92 Sparking Graphite 335i (N54) 6MT build thread.
      01-23-2019, 01:08 PM   #61
M3 Adjuster
Albania
7906
Drives: 1M, X1 M Sport, E46 325ic
I just got a Carly device since I have 3 BMWs that it can work on. I had my 1M coded remotely several years ago... nice to be able to make updates on my own.
      05-18-2020, 04:29 PM   #62
Traf
Traf's Avatar
France
95
Drives: E82 135i
Can anyone share the stock DSC trace file please ?
      07-30-2020, 10:25 AM   #63
dee0007
39
Drives: BMW 1M, BMW X5 G05
Hi,
Function
Module
Field
Value
CAS
aktiv
CAS
aktiv
CAS
ER_KEYOUT_AUTOVR
aktiv
Corner Delete Mod
NFRM
nicht_aktiv
NFRM
aktiv
CIC
kein_ld
1.
CIC
nicht_aktiv
2.
CIC
3_kmh
3.
CIC
3_kmh
Happy Coding!!!
Im new to this. How do you code? any instructions? what do you use? apps etc?I have the MHD module btw.
      11-01-2021, 04:16 PM   #64
Dazo
Drives: Bmw m140i
Codes
Thanks for the codes
