BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > **First Time Tuners** Start Here** Official Misfire Thread| Updated!
      03-22-2019, 02:05 PM   #331
Ayedum
Drives: BMW E90 N54
cant wait to order my cobb
      03-25-2019, 07:43 AM   #332
type-dRew
type-dRew's Avatar
641
Drives: 2009 335i xDrive
Don't do that.
lwgrenier117.00
      03-26-2019, 09:47 AM   #333
beetle6986
20
Drives: E90 335xi, E70 X5 50, 04 Cobra
Originally Posted by beetle6986 View Post
Removed the JB4. That didn’t help. I guess I’ll do O2 sensors next.
Replaced the O2 sensor in bank 1. Didn't help anything.
I'm starting to wonder if the car has a blown headgasket from overheating when the water pump went out the second time (almost a year ago). The car went into limp mode with reduced power. I drove it about another 5 miles on reduced power until I parked it as it wouldn't drive anymore under its own power due to the computer limiting. It was freezing outside when this happened. The next day I started the car and drove it home. It hardly started at first. Once it did start it smoked and misfired horribly for a few minutes. Turns out the water pump mechanics didn't fail. The housing actually cracked allowing all of the coolant to leak out. Possibly it had a minor gasket leak that has slowly gotten worse.
2008 335xi - JB5 ISO e50, VFSR catless DP, DCI, VFSR FMIC. Fuel it stage 1, VMR V710s. 407/446 rwhp/rwtq.
2004 Cobra - Basic bolt ons with a tune. 450rwhp/rwtq450. Port coming soon.
2013 X5 50i - muffler delete, xHP tune, ESS tune on the way.
2016 Mustang GT Roush Phase 2 with VMP 767 HP kit.
      03-29-2019, 08:08 PM   #334
beetle6986
20
Car passed blown head gasket test.
However, I think I had a break through today with some with something else. I pulled fuse 26 which disables the awd system. The car does not misfire with this fuse out. So I believe it isn’t actually a misfire. I think the issue is related to the transfer case or the 4x4 system. It just feels exactly like a misfire.
      04-01-2019, 06:19 AM   #335
kchalisuri
Drives: bmw e60 535xi
hello guys, i have e60 xdrive. i wrote post on 5 series forum, but 3 series owners make more tune then 5 series. can someone help
this is my post
https://e60.5post.com/forums/showthr...0#post24594490
      04-01-2019, 09:53 PM   #336
avityvan
Drives: 2006 bmw 325i
2006 BMW 325i
N52 code: Misfire on cylinder 2
I was driving one day and all suddenly my car loss some power and start idling very bad so I scan the car and it give me a misfire on cylinder 2. Did some research on the forum and I thought maybe is time to replaced this all these things anyway so I took out the 2 solenoids and clean them and I replaced all coils and spark plugs and cylinder 2 injector but nothing change. I did a scan again and is still read misfire cylinder 2.
After everything that I did the car still have the same issues.
Help!!! much appreciated.
      04-02-2019, 12:58 PM   #337
mweisdorfer
mweisdorfer's Avatar
Drives: 2007 Black/Black 335i e90
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
Originally Posted by avityvan View Post
2006 BMW 325i
What coils did you use? What sort of tune do you have on a 325? Injector might be the issue. From what I understand, you can only use 11 & 12 in the same bank..
So, if you had like 10 and below in the other 2, in the same bank, and put a new 12 in that would make sense. Also, most people would suggest Eldor coils when doing a tune.
      04-02-2019, 04:24 PM   #338
avityvan
I replaced all 6 coils with BMW Direct Ignition Coil - Bosch 0221504465 and also replaced injector 2 but is still have cylinder 2 misfire. I don't know what else can it be.
I don't understand what you mean 11 & 12 in the same bank.
Thanks for the help, much appreciated.
      04-02-2019, 06:17 PM   #339
rjahl
rjahl's Avatar
996
Drives: Z4 35is
2012 Z4 35is  [0.00]
Jump over to the Naturally Aspirated forums. Much more help for the N52 over there.
      04-02-2019, 07:58 PM   #340
mweisdorfer
2008 bmw x5  [0.00]
Bank 1 are cylinders 1-3, Bank 2 are cylinders 4-6.
1 - 11
2 - 12
3 - 9 = no good
1 - 11
2 - 11
3 - 12 = good
You can't go below 11 in a given bank
You can -
1 - 11
2 - 11
3 - 12
4 - 9
5 - 10
6 - 9 = no issues because they are separate banks
The numbers of course like 11, 12 etc are the index numbers of the individual injectors
      04-02-2019, 10:15 PM   #341
beetle6986
20
I figured I would give an update. I hate when people have problems and post it in a thread and then never give the final resolution. I changed the transfer case fluid and the differential fluid. The issue is now 90% better. I’m hoping as I drive it more with the new fluid the issue will go away completely. Otherwise, I will put in a replacement transfer case.
      04-23-2019, 12:55 PM   #342
XxPotHeadxX420
Drives: BMW 335i E90
This helped my newbie butt out alot. #NewMember
      05-09-2019, 05:26 PM   #343
Budi
Drives: 2007 Bmw 335is
Great info
      05-19-2019, 12:17 AM   #344
Chrisred
Chrisred's Avatar
63
Drives: BMW 335xi coupe
Hi, I keep getting ALL cylinder misfires on WOT only above 5000rpm.
Have RB turbos on 100% meth, FBO, upgraded LPFP.
Tried NGK 2 step and 1 step colder plugs and stock plugs. No change
New coils. Bimmerlife.
Injectors are index 12. Have replaced cylinders 1-2-3. Same results . Doesn't seem like I have issue there as no morning misfires due to leaks. And misfires are always on different cylinders or in ALL cylinders. Coded well and decouplers in place.
Carbon cleaning done as well.
Logged HPFP & LPFP with Trebila and everything is perfect. Logs are perfect until misfires.
Have stage 3+ spec clutch and flywheel.
No other codes. Just the misfires on several/All cylinders.
O2 sensors fairly new.
Any ideas.?? Anyone??
JB4 Trebila tuned cp-e IC AMS exhaust BMS DCI AR DP's METH RB TURBO
19" VMR VB3 Stoptech BBK TC KLINE VORSHLAG SPEC STG 3 OSS design
      06-09-2019, 04:40 AM   #345
335xirookie
335xirookie's Avatar
Drives: 08 335xi E92
Help
Spark plug gap maybe? prob should be 18-20...Or maybe time for Bimmer life coils...
      06-13-2019, 12:27 PM   #346
Chrisred
Chrisred's Avatar
63
I currently have new stock plugs. Believe they're not gappable. But either way my mechanic had gapped all my plugs correctly in the past.
      06-23-2019, 12:57 PM   #347
jasonytl1
jasonytl1's Avatar
Hong Kong
Drives: E90 335i
Hi, I am from Hong Kong, I have did a lot of review before try to flash my car with MHD, and I finally decide to flash it today, but my flash didn’t went well and my car can’t turn on anymore, this is the process of my flash, hope that you can help me.
First, I have my battery connected to my car, then I pug in the K+DCAN cable, it connect successfully, I purchases the flasher module and stage 1 map, then I go backup my ECU and start flash the map. Firstly it go well, but then it stuck at (15%, 31min) left. I wait for more than 1 hour but it still stuck at 15%, so I have choices to unplug the cable, then I restart the phone and ofcause my car can’t start anymore.
After my phone restarted, I try to flash my car back to stage 0, the MHD app go well and start flash back to stock, later on, it stuck at (89% 2min) left again, after half hours, I have no Choice to unplug the cable again. Finally, the MHD app no longer connects to the ECU, I try with the same cable that I have used and it said no cable detected. That is all the process of my flash, hope that you can give me some help, thanks.
      10-30-2019, 04:56 AM   #348
Sherbakoff
Sherbakoff's Avatar
10
Drives: 335i RWD
Can JB4 be used only as meth controller?
No need to use different JB4 maps because I have custom ECU program.
      11-07-2019, 06:09 PM   #349
CheesecakeInjection
16
Drives: ‘10 e90 335xi
2010 335xi  [0.00]
JB4 compatible meth kits come with a little FSB module. when it has FSB it can control it and have its meth failsafes connected.
if it doesnt have FSB it'd be tricky to rig up.
      06-27-2023, 06:41 PM   #350
rwphillips7
Drives: BMW 335i
Single Misfire
I own a 2008 335i, I'm experiencing a single misfire on cylinder #2. Replaced spark plugs, swapped coil pack and fuel injector but fault didn't follow. Cylinder 2 still misfires. I've been working on this problem for awhile...not sure what else to do. Ideas?
      06-27-2023, 06:45 PM   #351
alexwhittemore
Drives: 2009 Crimson 328i
The one thought that jumps to mind is: what if the wiring to your cyl2 coil is broken? Maybe the plug and coil are fine but it's as if the coil isn't plugged in.
I'm not sure how to easily verify that though.
      06-27-2023, 11:16 PM   #352
whyzee125
Drives: Dinan stage 2 335i
Has it ever been carbon cleaned? Can you clear the misfire? How soon does it come back? Can you feel it/is it shutting a cylinder down or it's minor enough that it drives ~normally? How many miles on the car?
