      06-14-2014, 06:56 PM   #89
1MOz
1MOz's Avatar
Australia
193
Drives: BMW 1M AW & F15X5 40d & M2C HS
Originally Posted by scotth944 View Post
For some reason I received a 25110434219 performance shift lever which looks to be for the E90 130i instead of the 25110434217 performance shift lever for the 135i. Does anyone know if first part # will still work in the 1M; it looks to have very slight knee (bend) with a minor tilt back instead of the z bend between the ball and handle I saw in the posted pics?
No it will not.
      06-15-2014, 02:50 PM   #90
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
@scotth944 IDK the answer. But I suspect it might work. You might have to modify your new shift lever. Years ago I bought a Z3M shifter for my e36. I also had to bend the lever arm using a vise and two long sockets. This website helped me figgure out how to bend the lever. I think I would first install your lever to see how it works. ?
http://www.understeer.com/shiftlever.shtml
http://www.unofficialbmw.com/e36/dri...ift_lever.html
http://www.bimmerforums.co.uk/forum/...guide-t111157/
      06-16-2014, 05:14 PM   #91
scotth944
Drives: 86' 944, 12' Gulf R
Thanks for the link info David, I ended up driving up to the store today (nice day for a drive in the M) to get the incorrect part swapped out. I think the other part might have fit but the geometry of the bends is defiantly different between the two. The 135 version has bends both front/back and to one side while the other was just bent in one direction.
Too bad I couldn't get the correct shifter until today, I would have enjoyed watching the Le Mans race in the garage while working on the M .
      06-21-2014, 10:45 PM   #92
scotth944
I went to install the BMW SSK lever today and was surprised by how much difference there was in the angle of the handle when compared to the stock 1M lever. Luckily Dackelone had posted a installation link that inspired me to make my own lever "recalibration tool" so that I could make the end of the lever line up to where the stock one would be. It just so happen that the jack handle I had was a perfect fit to the lever cylinder so I could use it to bend the lever end without too much trouble. I also had to use the drill bit you see to keep the shaft lined up correctly while bending the shaft since it kept wanting to twist around on me during the process.
I also did the N55 mid pipe swap while I was at it and it probable took me less than 2 hours to do all the part swaps in my garage and another 4 hours making the necessary tooling I needed to modify the lever. Thanks to 1 Addicts for hints I needed to make this an easy and fun project to work on today. I did find this car to be a pleasure to work on with how it was put together especially given that this is not my first time working on "German" made automobiles.
After taking the car out for a drive, I found that I would have preferred a little less reduction in throw say 25-50% than what the BMW part offered. I'll have to see if I just need to get use to it to be satisfied with the setup, I will say that the mod I did to the lever worked out great and my hand and arm position feels very natural with the new setup. The N55 mid also made a noticeable difference for me in pickup and go.
      07-05-2014, 11:41 PM   #93
SNOOPY11
10
Drives: Coupe
ohhh wait a minute... so your car is a N54 and the bottom of the shift lever arm is physically contacting the driveshaft. I'd say thats a problem. This might be why the Perf SSK comes with a new shifter lever saddle.
I don't know IF I have seen someone only install the shift lever on a N54. These other guys have a 1M which has the N55 trans. You might need to buy that other part(see #7 bellow) of the Perf SSK to make things right/work.
see #7...
http://realoem.com/bmw/showparts.do?...80&hg=25&fg=95
Dackel
Excellent info here, I am also about to make the plunge. Just to make sure #7 part is not needed for the 1M?
tia!
      07-06-2014, 08:18 AM   #94
scotth944
I purchased parts 4-6, part 5 is the only required part and the other two are optional for a 1M installation.
Getting the two plastic bushing tabs to twist to the fully released point without damaging it was the only tricky part I ran into. I used two small flat blade screw drivers to spin it around in the mount.
      07-06-2014, 12:14 PM   #95
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
tia!
Correct! #7 is NOT needed for 1M's or on N55's. Only for N54's do you need #7.
Have a few extra c-clips on hand bc they will fly off never to be seen again. They are cheap insurance to a hassle free DIY job!
Here are a few pics from an e36 shifter. Its really the same thing. I agree with Scott, getting that shifter bushing to rotate and off, is a bitch. Also... don't punch yourself in the eye when you pull UP on the shifter knob/boot. You laugh but people do knock themselves out when trying to remove that leather shift lever!
e36 shifter...
Name:  shift lever bushing   IMAG0220.jpg
Here you can clearly see the notch where the shift lever bushing locks into that saddle carrier. You only need to rotate the bushing 90' counter clockwise to unlock it from the carrier.
Name:  shift lever bushing  pic28.jpg
Name:  shift lever bushing  removal-shifter.jpg
      07-06-2014, 01:05 PM   #96
scotth944
If you decide to go the extra step and remove the mid pipe to make getting the C-clips off easier, you will more than likely need 2 new gaskets for the down pipe/mid pipe connection. The rear seal should be reusable.
      07-06-2014, 02:31 PM   #97
SNOOPY11
10
Drives: Coupe
Thanks for the help gents. I did get some extra clips just in case..
I'll return with feedback..
      07-08-2014, 09:21 AM   #98
eeghie
Kind of a big deal
300
Drives: an 1M not often enough
Originally Posted by qdtjant View Post
The SSK is not able to order any longer. Tried to order in Sweden and through dealer in US. Same answer: not able to order it due to no longer in prodduction. What to order instead ?
/Janne
same in Belgium, Netherlands and Germany: part 25110434217 no longer available!
      07-08-2014, 03:02 PM   #99
scotth944
see if this will work for you overseas?
http://www.estore-central.com/part/25110434217
      07-08-2014, 05:47 PM   #100
SNOOPY11
10
Drives: Coupe
FYI, GetBMWParts reported that the BMW SSK parts (not sure about the actual kit) you would use for the 1M are in stock and ready to ship as of today.
This is where I ordered mine from. Thanks for the tip.
      07-09-2014, 07:05 AM   #101
eeghie
Kind of a big deal
300
So in the US there's still an active supply of 25110434217?
when did you order/receive?
      07-09-2014, 07:45 AM   #102
scotth944
GetBMWParts.com had them on the shelf when I dropped by last month, another dealership I inquired with was also willing to take the order, I don't know if they may still be available in the BMWUSA system but they seem to be in stock at some locations. I also saw that the BMW Performance web page no longer shows the SSK for the E82 135.
      07-09-2014, 01:46 PM   #103
SNOOPY11
10
Drives: Coupe
Ordered a few days ago, all parts needed- shipped $89.
      07-09-2014, 01:46 PM   #104
eeghie
Kind of a big deal
300
THX for the feedback, apparently you got the last ones; Tried to order today and as the part is discontinued by BMWUSA (source getBMWparts), order was rejected!
      07-09-2014, 05:52 PM   #105
SNOOPY11
10
Drives: Coupe
Just got an update email from GetBMWparts. The part is no longer available- order canceled. Back on the hunt...
      07-09-2014, 10:35 PM   #106
scotth944
Part # 25110434219 seems to still be active, it should work in a pinch and given that the 135 version was not an exact matchup in how the bends were made when I compared it to the stock one yet people we happy that installed it that way, I suspect it might be close enough. I think you will find the lever to point/sit a little closer to the dash from where the stock one now sits.
http://realoem.com/bmw/showparts.do?...=25&fg=95&hl=9
      08-04-2014, 07:18 AM   #107
1mGator
1mGator
1mGator's Avatar
Drives: Valencia 1M
Yipee
So, after looking high and low on the web (parts discontinued) it just so happened that I recently received a "service request" from the dealer and low and behold the dealer had all the parts necessary for the SSK in stock ..... happy 3rd Birthday to my baby. Shift is dramatically shorter and does not take much getting used too .... Thanks all for the valuable info ... You all rock!
      08-04-2014, 05:12 PM   #108
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Very cool!
You know @1mGator ... to this day, everytime I drive on the German narrow back roads and see one of the "Strassen Spiegels" - I think of your Avatar and your 1M ED writeup!! Even after all this time.
      08-04-2014, 08:25 PM   #109
SNOOPY11
10
Drives: Coupe
Did they have any extras? Doubt it but doesn't hurt to ask..
If anyone runs in to a source that has these, please let me know
BadakVT77.50
      08-04-2014, 09:55 PM   #110
1mGator
1mGator
1mGator's Avatar
Drives: Valencia 1M
It was Crown BMW in Greensboro North Carolina .......
