TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Classifieds Section > E92 BMW 330d M Sport Coupe Atlantis Blue Mettalic Individual Model
      06-24-2017, 07:59 AM   #1
Jamie330d
Drives: 2012 E92 335D Sport PLUS
2008 231HP model.
111,000 miles – just ticked over to this.
FBMWSH - fully up to date. Both remote keys. Full Original book pack/Manuals.
Full Warranty History print out from BMW to show all below warranty work.
MOT - March 2018.
Taxed.
Plate NOT included under any circumstance. Will go back on original plates
HPi CLEAR – full gold report included when I bought it.
The car has had a full BMW original excess free warranty all its life and this came to an end recently due to mileage. The amount of warranty work it's had done is phenomenal, I have a print out from bmw for it all. It's only just come back bmw having had an entire new passenger side headlamp under warranty due to moisture. I have done 21k miles in this car without fault, it's never let me down. I do a lot of miles to work and back and this is always on the motorway where its up to temperature and generally I never do town miles so the DPF is functioning perfectly. You can start a new warranty with BMW with is reduced due to the cars history and the fact the warranty has only just ended, BMW stop the excess free warranty at 100k miles you then must take on an excess based one.
The wheels were refurbished the beginning of the year in BMW Ferric Grey Metallic by RIMTEC, Kent and have four matching continental sport contact 6 tyres that were new last year fitted by me. The car is utterly pampered by me and all previous owners, this really is a special example and there is nothing like this for sale with the amount of work and history it has especially FBMWSH on a car this age.
The car requires zero maintenance doing and is not due anything. The bodywork on this car is very nice, there’s no dents, scratches, scuffs down the sides or on bumper corners etc. The front end has a couple of chips only and as stated is not peppered. The paint shines up perfectly and looks like it does in the pics, when the sun hits it, it really stands out and goes a stunning lighter Blue. The interior is in very good condition for the miles, the rear bench looks barely sat in, the passenger seat still has a matt finish, the driver seat only has minimal use signs on the bolster and is very nice indeed. The steering wheel has signs of wear, with the lower trim peeling which is an issue on all these, I may get around to having this re-done as it will need wrapping in matt black. The same peeling exists on the driver side grab handle as that is covered in the same material. It would appear E46 and E9X interior trims react to sweat and start lifting. The boot is in nice condition with storage compartments and Genuine BMW Battery still present. All tools are there along with unused first aid kit. The turbo charger works as it should and boosts well with a nice whistle which is addictive. Electric windows work perfectly with zero issues. The car starts perfectly from cold, warm or whatever else is thrown at it and runs utterly perfect from ice cold start, the gearbox is smooth from cold or hot with no stickiness.
The Chassis on this vehicle is outstanding, all bushes are in perfect condition as on the recent MOT I had them go over this with a magnifying glass as I fully expected to have to replace something due to the mileage, to my amazement their all perfect, I can only put this down to previous replacement and/or doing motorway mileage and generally never going over speed humps. You are welcome to pay for a ramp to inspect also. The shock absorbers work perfectly and have zero leaks, they make the correct gas noise going over bumps which is noticeable at low speed with the windows down, it handles as it should, no knocks or bangs. The only thing I can note is when you get in the car something at the rear squeaks, I have had this looked at and nothing can be found wrong with any component.
Most Recent Maintenance:
12/1/16 – Front discs/pads/sensors @ BMW Ilford (87K) - £780.
12/7/16 – Full Hunter Alignment done
14/7/16 – Rear discs/pads/sensors (ATE)
14/7/16 – New Tyres front + rear, Continental Contisport Contact 6’s (225/35/19 + 255/30/19 - £700 (discounted)
1/8/16 – New Genuine BMW Side Repeaters, originals had gone cloudy and spoiled the car.
3/11/16 – Genuine Bosch Wipers Replaced.
10/1/17 – New Genuine BMW Thermostat + EGR Valve
27/6/17 – Full Hunter Alignment – Being done Tuesday.
Service History – Fully Stamped:
10/1/2008 – BMW THORNE Distribution Centre Pre-Delivery Check
BMW Luton - 22/09/2009 –18,353 Miles - Engine Oil, Microfilter
BMW Luton - 09/12/2009 – 21,899 Miles – Brake Fluid
BMW Luton - 23/12/2010 – 37,514 Miles – Engine Oil, Microfilter, Vehicle Check
BMW Wollaston - 04/01/2012 – 51,919 Miles – Engine Oil, Microfilter, Rear Discs/Pads/Sensors, Brake Fluid, Air Cleaner Element, Fuel Filter
BMW Wollaston - 07/12/2013 – 67,546 Miles – Engine Oil, Front Discs/Pads/Sensors, Microfilter, Brake Fluid, Air Cleaner Element
BMW Wollaston - 08/12/2014 – 73,312 Miles – Engine Oil, Microfilter, Vehicle Check, Brake Fluid
BMW Chigwell - 13/01/2016 – 87,588 Miles – Engine Oil, Microfilter, Fuel Filter, Air Cleaner Element, Front Discs/Pads/Sensors
BMW Stephen James Ruxley – 19/12/2016 – 100,734 Miles - Brake Fluid
BMW Stephen James Ruxley – 17/02/2017 – 104,614 Miles – Engine Oil, Microfilter
Warranty Work Completed –
BMW Stevenage – Front Bumper/Trim Replaced + Painted due to paint flaking – 18,732 miles, 23/09/2009
BMW Luton – Front Headlamp Cleaning System Replaced Fully due to not functioning properly – 22,268 Miles, 05/01/2010
BMW Luton – Front Headlamp Cleaning System Replaced Fully Again, due to still not functioning – 24,506 Miles, 16/02/2010
BMW Wollaston – Brake Light Fault, bulbs replaced + tail lights checked for faults – 28,804 Miles – 24/05/2010
BMW Wollaston – Brake Light Fault again, bulbs replaced + checked – 29,177 Miles – 03/06/2010
BMW Wollaston – X1 Alloy Replaced due to vibration – 46,063 Miles – 26/07/2011
BMW Leicester – Seat Belt Extender Failure RIGHT side, replaced – 69,130 Miles, 26/04/2014
BMW Leicester – Software Update – 69,130 Miles – 26/04/2014
BMW Chigwell – Full Car Communication Computer (CCC IDrive Unit) Replaced inc Computer Module, Audio Amplifier etc – 84,015 Miles, 21/09/2015
BMW Chigwell – Crankcase Oil Separator Leaking, all gaskets replaced + ventilation system, breather etc Levelling Sensor Replaced, Right Rear Tail Light Bulb Holder Replaced with bulbs, vehicle test, battery charge, Glow Plug Module Replaced, ALL Glow Plugs Replaced, Pre-Heating Module Replaced, Pre-Heating Module Replaced, Ride Height Levelling Sensor Replaced due to xenon light failure – 87,638 Miles, 18/01/2016
BMW Chigwell – Passenger Side Headlamp Replaced, Battery Charge, Blower Output Fault – Blower Unit + Regulator Replaced. 91,846 Miles, 06/06/2016
BMW Chigwell – Passenger Side Headlamp Replaced again due to moisture build up, 109,000 Miles, 31/05/2017
Options -
Full Alpine Speaker and Amp set up, fitted by BMW Wollaston a few years back – The Stereo is SUPERB, Better than Logic 7.
Atlantis Blue Metallic Individual Package
Full iDrive, Sat Nav, Bluetooth Mobile Calling, Radio etc
Heated + Electric Black Dakota Leather
6 Speed Auto box with Paddle shift
Gloss Black exterior trim package (Shiny Black Plastics)
Electric folding mirrors - works off the key.
Privacy Glass package (tinted rear end, front windscreen with tint)
Folding rear seats, rear centre armrest with cup holders.
The car has not been modified other than the wheel colour and some 12mm rear spacers that I'll likely remove and fit to my track car. It's not peppered in chips like most of these and is generally in very, very nice condition. I have recently been to view many of these with a friend to get him one, I know the state of these cars out there priced low and high and they made mine look impeccable, there is NOTHING I have seen to rival mine with all the above work and parts replaced.
I personally wanted a 330d when I bought this. Most reviews always state these are the much better buy and the one to go for, they’re not wrong. I'm only selling up as taking delivery of a new 335d x drive 7th July and will use that for work a lot more, I will then buy something cheaper to use on the odd days the mrs doesn't need the bigger car, I'm finding this is sitting about a lot more now as we have an M135 that I'm using more so seems silly to let this sit around being such a stunning car. I have seen a little 123d coupe I like.
Running costs -
Full tank of diesel - £70 from empty @ 1.18p.
500-550 miles a tank minimum.
Insurance - FC - 32 years, full ncb - £490.
Servicing at the dealers is fixed price these days and a full big service is around £465. Or an oil and micro filter at £199, brake fluid at £71. I have kept it with the dealers as they have looked after this car well having the warranty from new - there's never an argument if something has been needed. I'll leave the decision whether to keep up the history or not. I will include some spare oil I have for between top ups, it takes 0w30 as per BMW. Test drives will be with me driving it, unless you have the full amount in cash and fully comp insurance with my car on the document. I am happy to provide any pictures of any particular areas or anything you want.
No part ex or swaps thanks.
£9,499.
      06-24-2017, 08:17 AM   #2
Jamie330d
      06-24-2017, 08:35 AM   #3
Andy Bev
Drives: E93 325i
Lovely car mate, I've just sold me E39 in Atlantis Blue it's a fantastic colour GLWTS
      06-24-2017, 02:20 PM   #4
Jamie330d
Thanks mate! It is a lovely colour, nothing like it out there, certainly draws attention!
      05-09-2024, 05:11 AM   #5
Porticed
Porticed's Avatar
Drives: BMW e 36
¡Tengo una noticia emocionante para compartir! Recientemente tuve una noche increíble en el casino y logré ganar una suma significativa reglas poker . Con mis ganancias, decidí darle un capricho a mi querida BMW E36 y comprarle unos nuevos y relucientes discos.
Después de una sesión exitosa en el casino, no puedo evitar sentirme emocionado de poder mejorar mi automóvil con estos nuevos accesorios. Además de disfrutar del póker, también soy un apasionado de los coches, así que esta compra es el resultado perfecto de dos de mis pasiones favoritas.
Estoy ansioso por llevar mi BMW E36 a la carretera y disfrutar del paseo con estas nuevas discotecas. ¡Gracias al poker y a mi buena suerte en el casino, ahora puedo presumir de un automóvil aún más impresionante!Aquí tenéis fotos de las nuevas ruedas y de cómo quedan en el coche: https://nimb.ws/8qByzwg
https://nimb.ws/iIWt8vB
https://nimb.ws/d4gEBjo
      05-09-2024, 05:15 AM   #6
Porticed
Porticed's Avatar
Drives: BMW e 36
Si te interesa te puedo enviar más fotos.
