TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > N54 Public XDF Repository
      05-24-2015, 09:18 PM   #23
WedgePerformance
WedgePerformance's Avatar
Drives: Slot Machines.. Keep Taking $
Originally Posted by Aerotest View Post
I found a small issue with the I8AOS XDF. Fuel Scalar (Bank 1) RPM Break Point is missing "704". I actually starts with "1500" and ends with "0". Bank 2 is fine.
RPM start point for Bank 1 scalar is 0x79196 and Bank 2 0x793DA. I have validated the values in our current master copy and our values are correct. I did however notice that the values for bank 2 were integer and not floating point which I updated.
I'm not sure who's version of XDF files you were using prior, but it looks as if the version you were using was not correct which is why you are now finding this issue.
      05-25-2015, 09:34 AM   #24
Aerotest
15
Drives: 2008 E90 335i 6MT
I was using my own XDF and the labels were coming from external manual just as you have them for some of the axis points. It looks to me like it may have been one address off the starting point as it started with 1500 (second label) and ended with a 0 after 7000 rpm?
      05-25-2015, 12:36 PM   #25
WedgePerformance
I don't want to discount your concern, but please remember the published XDFs have been reviewed by the team and the brake points in our XDFs are correct. Please do not just make comparison to your old XDFs and assume that the old XDF is correct. If you truly find something, provide proof that it's not accurate to include the HEX address if it's a table. I have personally corrected hundreds of mistakes in the old XDFs originally provided by VISHNU. Thanks for your input, please use PM or email me WedgePerformance@gmail.com if you still have concerns.
      05-25-2015, 05:24 PM   #26
Aerotest
15
Wow hundreds huh?
      05-26-2015, 05:57 AM   #27
bradsm87
Australia
596
Drives: F25 LCI xDrive30d
It's excellent that there are finally some verified good XDFs.
Can we get Metric versions?
      05-29-2015, 11:02 AM   #28
MHD Tuning
Germany
1978
Drives: M3F80#M5F90#340iF31#SupraA90
jyamona added several IJE0S tables related to knock sensitivity and I ported them to I8A/INA/IKM. The first new tables N54 added since a long time
That said, this is dangerous stuff so use with caution!
      05-29-2015, 11:32 AM   #29
jyamona
177
Drives: 2010 135i
+1. Modifying those tables without knowing exactly what you are doing is a risky move.
Other than that, more updates coming soon
      05-29-2015, 01:41 PM   #30
jippii ensio
Drives: 335i
Thanks guys for pushing the platform forward. Appreciated.
      06-30-2015, 09:41 AM   #31
MHD Tuning
Germany
1978
The cold start max duration has been added to the xdfs.
WedgePerformance
Please specify in the first post to download them from Githibas .zip, otherwise Tuner Pro cannot load them.
      06-30-2015, 09:50 AM   #32
BigHoncho
13
Drives: E90 335xi
Its typically 60s isn't it?
So if you set it to zero then there would be no cold start at all (raised rpm, ignition etc)?
      06-30-2015, 10:04 AM   #33
MHD Tuning
Germany
1978
65s, 60s on old software. I think the behavior is crystal clear.
      06-30-2015, 01:41 PM   #34
brusk
brusk's Avatar
33
Drives: 2008 135i Coupe
Is there a list of all the new tables that have been discovered and mapped? I haven't been watching that much as my Cobb does what was needed for the backend but looks like I'll have to switch soon with all the advancements.
2008 135i - MHD/JB4, MS DP's, AMS IC, UI CAI, CDV delete, M3 control arms/Links, RE Toe Link, ECS Trailing Arm, M3 rear SF & Trans bushings, SS brake lines, Michelin PSS.
      10-05-2015, 11:55 PM   #35
dh58
Australia
108
Drives: 135i
This is a question for everyone..
With PPK1 it's just a flash tune. Most people say that the best part of it is the sound. Is it possible for us to figure out what BMW has done with that PPK1 flash tune and apply it to these backend flashes if someone wants?
      10-06-2015, 01:29 AM   #36
BMWhoarder
Resisting mods
Australia
48
Drives: 135i
i have a copy of a PPK bin....
      10-06-2015, 02:03 AM   #37
dh58
Australia
108
Drives: 135i
Doesn't it just mean you could flash with the PPK bin? lol #save$500
      10-09-2015, 04:10 AM   #38
marconi118
Drives: 06/07 e93 335i
on 2 different bin for my MSD80 I8A0S I found with tunerpro differences between address 73C3E and 73C5D
These are undefined in the last XDF.
Could you tell me what it is? and add it to the XDF?
      10-13-2015, 08:21 AM   #39
MHD Tuning
Germany
1978
The xdfs cover like 5-10% of the map area. The rest is yet either unknown for now, or not needed for tuning purposes. There are many many OEM maps, 100+ just for i8a0s.
      11-02-2015, 12:52 AM   #40
trap
Australia
16
Drives: 135i AW '09
WedgePerformance MHD Tuning
+1 keen to know what's the difference and possibly get this added as an option in MHD
      11-02-2015, 12:30 PM   #41
WedgePerformance
I'll defer to Martial regarding this as it could be a conflict of interest doing a PPK option due to the fact it's a BMW product which is sold by the BMW dealerships.
I can tell you the stage 1 was loosely based on the PPK mapping with some minor changes to hold a few psi more in the upper RPM range.
The stage 1 FMIC is not based off the PPK.
      12-01-2015, 08:50 AM   #42
MHD Tuning
Germany
1978
The github repository has been updated mid November.
- WGDC decimals increased where needed
- New tables to play with:
* Trans
Gear Ratio Calculation (Mon.)
Rear Axle Ratio
* Shift bog
Max Duration of Torque Reduction During Gear Shift
Min Load Decrease Fast Fuel Cut-off
Max Time Clutch Switch Observation Fast Fuel Cut-off
Max Time Gear Shift Observation Fast Fuel Cut-off
Min Coolant Temperature Fast Fuel Cut-off
Min Speed Fuel Cut-off 1
Min Speed Fuel Cut-off 2
Engine Speed - Load Threshold for Fast Fuel Cut-off
* WIP - testing
Torque Monitor (Customer Specific)
Max Torque per Gear (AT)
Max Torque per Gear (MT)
Max Torque at Clutch (DCT)
Max Torque at Clutch (DCT, Limp Mode?)
Max Torque at Clutch (AT)
Max Torque at Clutch (AT, Limp Mode?)
DTC Master
Misfire Detection Max RPM (AT)
Misfire Detection Max RPM (MT)
Misfire Detection Min RPM
* Anti lag
Max Permissible IAT Gradient
Max IAT Sensor Voltage 1
Max IAT Sensor Voltage 2
Min IAT Sensor Voltage 1
Min IAT Sensor Voltage 2
IAT Conversion 1
IAT Conversion 2
      01-06-2016, 03:04 PM   #43
cstmx_ryder
cstmx_ryder's Avatar
Drives: A metal box with a roundel
So what do these tables do? Are they car specific (depending on MY and model)?
Sounds like these are the tables we can add/delete features in our ECU, such as making the cold start ups last shorter amount of time?
TIA
'08 AW E90 335i
PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10
      01-07-2016, 06:52 AM   #44
MHD Tuning
Germany
1978
TIA
All cars are covered through the 4 ROMs. Knock tables allow you to adjust the timing corrections. Yes you can adjust the cold start amount of time from the default 65 seconds.
