Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > N54 Public XDF Repository
      01-12-2016, 09:31 AM   #45
techlogik
Drives: 2020 M340i Dravit Grey
Any IKB0S support coming?
2020 M340i: Dravit Grey Mettalic. Loaded.
      01-12-2016, 09:24 PM   #46
WedgePerformance
WedgePerformance's Avatar
Drives: Slot Machines.. Keep Taking $
No, it's an old rom version. Upgrade to IKM0S.
      01-13-2016, 11:19 AM   #47
techlogik
^Roger that. Will backup that one first though before flashing/upgrading.
Thx
      07-24-2016, 10:11 AM   #48
AndyW
Supreme Galactic Commander (one galaxy over...)
AndyW's Avatar
Drives: '08 E93, '12 E82, '13 E93 M3
How does one upgrade their ROM version? Is that a dealer only thing? I'm on IA80S but don't know if there is any reason to upgrade or not. thx.
Best,
Andy
'12 E82-PS2,Stoptechs,Clubsports+M3 bits,Accusump,Wagner DP+EVO III FMIC,ERCP,BMS Intake,Mason Strut Bar,Wedge Tune
      07-24-2016, 12:40 PM   #49
WedgePerformance
I8A0S is the latest ROM version for MSD80. The MSD81 supports IJE0S for most cars and IKM0S on the 1M, and INA0S for 335is and Z4's. The only way you'll be able to run IJE0S is to replace the DME to an MSD81. I have an MSD81 in my '07.
      07-24-2016, 08:20 PM   #50
AndyW
AndyW's Avatar
Mines an 08...did you backfit? And , if so, what was the driver to do so?
Best,
Andy
      07-24-2016, 11:26 PM   #51
WedgePerformance
I purchased a new MSD81 from the dealership for $1005 and reprogrammed the car using Autologic.
      07-30-2016, 06:57 AM   #52
AndyW
AndyW's Avatar
What is the practical effect of the upgrade? Is it worth $1000 to upgrade if the 80 is working?
      07-30-2016, 06:23 PM   #53
WedgePerformance
Other than the fact I can flash it in just over 1 min... there really is no benefit that is worth mentioning. It was a good learning experience.
Another option would be to virginize a used ECU. Talk to Bryce at BimmerScan for pricing. There are a lot of MSD81's that can be picked up for cheap.
http://www.bimmerscan.com/
AndyW672.00
      08-12-2016, 05:54 AM   #54
marconi118
Drives: 06/07 e93 335i
BUG in I8A0S XDF
the aggression throttle table is badly defined
you should replace 73BBE with 73BDE
then the table is fulli defined
it was correct in an old wedge XFD I could compare with
      08-12-2016, 12:35 PM   #55
WedgePerformance
I'm looking at Throttle Angle Aggression in Overload and Row is defind 0x73B9E and Columns 0x73BAE. The general address hex is 0x73BBE which is correct. If I change it as you indicated, it throws the table off. If you feel there is truly an issue, send me a copy of the XDF to WedgePerformance@gmail.com and I will review the XDF you have indicated is correct.
      08-26-2016, 09:52 AM   #56
marconi118
it is on the MSD80 XDF
      08-26-2016, 10:47 AM   #57
MHD Tuning
Germany
1978
Drives: M3F80#M5F90#340iF31#SupraA90
That's actually the reverse. There was previously an error, corrected for some time now but some residual BINs are wrong.
      08-26-2016, 10:51 AM   #58
jyamona
177
Drives: 2010 135i
Hey guys, long time coming for this update! Lots going on right now and XDF updates got pushed to the back burner a bit. Anyway, here's what got pushed today (20 new tables):
Engine Cooling
- Coolant Temp Threshold (enable warning)
- Coolant Temp Threshold (yellow warning)
- Coolant Temp Threshold (red warning)
- Oil Temp Threshold (enable warning)
- Oil Temp Threshold (yellow warning)
- Oil Temp Threshold (red warning)
- Oil Temp Threshold (upshift warning)
- Temp Threshold for End of Warm-up
- Ambient Temp Threshold for High Mode
- Ambient Temp Threshold for High+KFT Mode
- Coolant Setpoint (Normal Mode)
- Coolant Setpoint (High Mode)
- Coolant Setpoint (High+KFT Mode)
- Radiator Fan Duty Cycle (ECT Target Diff)
Exhaust Flap (credit to MHD Tuning for these and reversing the logic!)
- Maximum Speed for Static Exhaust Flap
- Static Exhaust Flap Position
- Torque Request % for Exhaust Flap Actuation (AT)
- Torque Request % for Exhaust Flap Actuation (MT)
- Torque Request % for Exhaust Flap Actuation (AT - Convertible)
- Torque Request % for Exhaust Flap Actuation (MT - Convertible)
The table names for these are pretty self explanatory, but if you run into trouble let me know. If been running High / High+KFT ambient triggers lower than stock (23 / 28 *C), and a tad lower coolant setpoints for awhile now and it works GREAT. Seriously. It even keeps oil temps a good bit lower =)
As usual, you can find the latest XDF's at the public github. Enjoy!
Enjoying the new tables discovered and the XDF progress made? if you'd like. Every bit is appreciated!
Appreciate 5
      08-28-2016, 07:17 AM   #59
2007BMW335i
2007BMW335i's Avatar
Drives: 2007 335i
Wedge,
Is your 2007 manual or automatic. I would entertain an upgrade to 81 but I don't think the 6HP19 is compatible.
      08-28-2016, 05:46 PM   #60
WedgePerformance
Originally Posted by 2007BMW335i View Post
Wedge,
I have an 07/07 E92 Sport AT with an upgrade from MSD80 to MSD81 which was married to the car with AutoLogic.
      08-29-2016, 05:34 AM   #61
marconi118
Comparing 2 bins for the same car from wedge: the V2.1 and V3 I have some undefined differences with the new XDF, but maybe wrongly defined in the old bugged XDF
it is from address 73C3E to 73C5C
is this a continuation of table throttle angle aggression? or another table?
it is undefined in the last XDF of 5 days ago on github
      09-08-2016, 06:00 AM   #62
marconi118
bump
      09-08-2016, 09:23 AM   #63
WedgePerformance
Please use only the newest version of the XDF.
      09-09-2016, 07:46 PM   #64
Ilma
184
Drives: 2008 135i
Engine Cooling
V
What is High mode and High + KFT mode?
      09-11-2016, 01:36 PM   #65
2007BMW335i
Drives: 2007 335i
Does anyone know how I could find the address(hex) for codes 2C9E and 2C9F? I would like to eliminate my rear oxygen sensors and disable the codes from turning on the service engine soon light. If I knew the addresses I could add the parameter to my I8A0S XDF
149,000+ miles, MHD, VRSF 5" FMIC, Aluminum charge pipe. E50 tune by Wedge Performance. 3" Catless DP's. Secondary Cat Delete. DCI cold side w/silicone Inlets. N20 TMAP, "Stage 2" Walbro 450 LPFP. xHP Stage 3. 1/4 mile 12.079sec @ 118.79mph. (2.03 60')Before xHP flash and rear cat delete.
      09-15-2016, 08:51 AM   #66
CarAbuser
CarAbuser's Avatar
469
Drives: Z4 35i DCT / E92 335i DCT
Will the tables for enabling exhaust burble be added into the XDFs?
So I can change duration without using the flash time options in MHD.
