BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > CEL when under load + boost
      03-26-2024, 06:23 AM   #1
mikelord7
mikelord7's Avatar
Drives: 2010 335XI 6MT
I just put in new spark plugs and a coil for a cylinder 2 misfire.
Car was running fine but now it’s throwing CEL every time i floor it and boost is 10+ psi w jb4 map5. I can feel a shake in the pedal for a few seconds and then the CEL pops on every time. Sometimes car runs hard after and sometimes it’s fine.
Any ideas? Could this be a map sensor issue? Something else?
2010 e90 335xi 6MT - JB4, DCI, Lux AEs
      03-26-2024, 09:42 AM   #2
oVeRdOsE.
oVeRdOsE.'s Avatar
2716
Drives: F25 E91 Audi Avnt E90 Cayenne
do you have bluetooth on your JB4 to get codes ?
by the steering wheel button, not the best.
If not, use a proper reader to see what code you have.
can be a lot of stuff, most common is missfire and this can be cause by many things.
      03-28-2024, 06:33 AM   #3
mikelord7
mikelord7's Avatar
Thanks. Just bought a real scanner so will see once delivered. I have a feeling is gonna be another cylinder 2 misfire which i just fixed with a new coil.
Anyone had issues w misfires only once boost is above stock? I won’t throw a CEL under full load unless the jb4 is warmed up. Stock is fine but i want the power!
      03-28-2024, 07:29 AM   #4
oVeRdOsE.
oVeRdOsE.'s Avatar
2716
often. And is was always something new.
- sparkplug, coil pack : those are easy to diagnostic since you can swap them.
- sparkplug gap and/or temperature rating
- sparkplug coated in oil : classic bmw
- injector : classic when you have index1 to 10
- fuel : hpfp early gen fail pretty fast
- carbon built (valve can't close properly because of carbon built.)
- tune
- I saw someone reported that O2 can cause this because a bad reading and bad a/f ratio
- piston ring
a scan tool (proper bmw one) will guide you.
