TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > N54 MHI Turbo Data
      04-29-2009, 03:39 PM   #23
OpenFlash
Drives: A Lot
Originally Posted by TTurboBullett View Post
those #'s are only part of the equation you need to know vehicle displacement - volumetric efficiency and redline to know exactly where the turbos are beeing run at any point in the compressor map
+1. Not to mention the effects of the turbine housing/wheel. It can only make things worse.
Shiv
      04-29-2009, 03:49 PM   #24
TurboBullett@Ambient Thermal Management
TurboBullett@Ambient Thermal Management's Avatar
80
Drives: 2012 Abarth 500
Shiv
the best things these turbine sides have going for them is the BIG wastegates, which is a blessing in regards to pushing high power levels if you can run a turbo you dont have to push to hell, and a curse in regards to keeping them shut at high turbine backpressures. can u say CATCH 22?
      04-29-2009, 03:53 PM   #25
Bubbles
Bubbles's Avatar
Cayman Islands
2753
Drives: Green Bastard
Originally Posted by JesusFrEAk View Post
TTurboBullett so are you saying people can run the stock turbos at 18psi producing 480rwp and be save for what 1 yr, 2 yrs ??? how long???
He won't know, he just stated it's out of spec range at that psi. It could be all or nothing.
      04-29-2009, 04:01 PM   #26
80
exactly I know guys with Evos and SRT-4s that run waaaay out of the compressor map for 50-60k miles and some peoples turbos blow up after a few WOT runs. when youre dealing with a piece of metal spinning 100,000+ revolutions a minute and putting a load on each end of the shaft you are literally playing russian roulette
      04-29-2009, 04:02 PM   #27
JesusFrEAk
18
Drives: 2008 335i
I see. I was just trying to determine based on the data and TTurboBullett's translation, if these turbo's can reliably push that much power for a few years. As I am thinking of getting all the bolt-ons and it would be nice to know they will last a while vs. winging it and hoping they don't go at any given time.
      04-29-2009, 04:03 PM   #28
80
the closer to the center and bottom of the compressor map you stay, theoretically the longer the turbos will last.
      04-29-2009, 04:09 PM   #29
JesusFrEAk
18
Drives: 2008 335i
so theoretically these turbos with all bolt ons should last a long time if power stays around 380whp??
Edit: sorry edited the 480hp number to 380hp
      04-29-2009, 04:10 PM   #30
scottp999
Drives: 4runner SR5
2007 BMW 335  [9.00]
so theoretically these turbos with all bolt ons should last a long time if power stays around 480whp??
I would guess (my technical contribution) more like 380whp
      04-29-2009, 04:10 PM   #31
smdandb2
this space left intentionally blank
smdandb2's Avatar
15
Drives: Blue One
Yeah, and if you blow up a turbo on a Neon or an Evo you're out a few hours of labor and a couple hundred getting it replaced. Maybe $1500 if you order one from the stealer.
I don't see that being the case right now in the BMW world.
The roundel just about guarantees a price premium over other makes and models.
      04-29-2009, 05:51 PM   #32
DMETune
Drives: E92 335
according to the posted data the OP said that the turbos were good for 42.25lb airflow 1 lb airflow is good for approx 10hp SO 42.25x10= 422.5hp
peak boost is shown in the middle of the map as 2.7bar (2.7 x 14.6psi = 39 - 14.6(atmospheric pressure) = 24.8 MAX PSI)
max boost at max flow/choke point is 2.2 bar (2.2 x 14.6 = 32 psi -14.6(atmospheric pressure) = 17.52 PSI BOOST at choke point)
once someone translates the map to either CFM or Lb/min and puts some efficiency % to the islands I can get as TECH as you want
Anything missing?
Two things:
- Firstly, I was the OP.
- We may be saying the same things here, but the key correction that's missing is efficiency. It may create 24.8psi of pressure, it's important to consider how much of that pressure is heat and how much is actual density gain. Also, we cannot dismiss the pressure drop across the intercooler.
In short, this information is not suggesting that these turbos should be running at 24psi peak and 17 by redline. Peak efficiency is well below these figures.
      04-29-2009, 06:23 PM   #33
80
Originally Posted by DMETune View Post
Two things:
I think we are definitely stating the SAME things here. I stated we need efficiency information and to use the engines displacement, rpm and volumetric efficiency to plot where end users are pushing these turbos. If someone can get the efficiency percentages I can do all of the other calcs. Lastly all the data I posted was compressor outlet pressures NOT intake manifold pressure.
      04-29-2009, 06:56 PM   #34
Prince ///M
Drives:
I think that you will never have VE of the engine... but adiabatic efficiency of the compressor is already in the table of the first post.
      04-29-2009, 09:00 PM   #35
A418t81
Drives: Ever changing fleet
2013 335is  [0.00]
VE plays into the the PR required for the amount of flow. That takes into account all the turbine wheel restrictions, etc. I'd say that it's been proven that ~17 psi is around 420 whp with the right octane. Falls right into line, right in the region of maximum flow for given PR.
Also, the rpm this compressor needs to make a nice amount of boost is lower than I expected for it's size. These things can be pushed way beyond the 310-320 whp that the flash tuners keep harping on as the max of the hardware. I'd say that is absolutely not the case with the data presented.
23 iX M60, 24 GT3 RS Weissach, 22 Rivian R1T, 23 RS3, 13 E92 M3 Competition: Akra Evo, KW V3, etc
      04-29-2009, 10:52 PM   #36
smdandb2
smdandb2's Avatar
15
Drives: Blue One
Here is the map cleaned up a bit. I was able to interpolate the data to get the efficiency islands made with a good amount of certaintly.
I know you need to know the VE of the N54 amongst other things to get really correct calculations, but if you just work on a VE of 90% you can see some of the PRs obtained with the tunes that the turbo is going WAY outside the map. Shaft speeds must go thru the roof when trying to hit higher boost levels in the upper RPMs. No wonder power tapers of so much on the dynos you see.
      04-29-2009, 11:09 PM   #37
DMETune
Drives: E92 335
Well done! I'll put this up in the OP.
      04-30-2009, 01:51 AM   #38
pronacyk3
Drives: f
Great! It'd be neat to see some comparisons of stock vs tuned operating lines overlayed on this compressor map.
      04-30-2009, 07:12 AM   #39
1clean335i
Perf BMW mag issue 147, 159
1clean335i's Avatar
Vietnam
414
Drives: Project Estoril
Originally Posted by scalbert View Post
Good to finally see.
thanks for posting this info
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril
      04-30-2009, 07:53 AM   #40
Bubbles
Bubbles's Avatar
Cayman Islands
2753
Shouldn't you be working on more important stuff?
      04-30-2009, 09:21 AM   #41
Prince ///M
Drives:
Someone on another forum posted the superposition of opertating lines depending on rpm with the compressor map.
In red there is also the curve relative to Procede boost (as logged from stage 0 non DD)... and it seems to be a lot outside range at high rpm.
Could someone confirm this kind of behaviour?
      04-30-2009, 10:06 AM   #42
Ilma
184
Drives: 2008 135i
I know from your posts that you are not particularly fond of the Procede, but in all fairness, other tunes are running similar boost profiles and psi......so these conclusions wouldn't apply to just the Procede I would think.
      04-30-2009, 10:23 AM   #43
Prince ///M
Drives:
I'm not against Procede (I use it and I'm very satisfied, more than with JB3)... I'm trying to understand how our cars work and how to improve performances and reliability.
I'm also unsure about the graph I posted... so I hope that someone with better knowledge can replicate the same analysis.
      04-30-2009, 10:54 AM   #44
Ilma
184
Drives: 2008 135i
Ok....sorry for the comment.
I do agree with your premise.
