BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > N55 VANOS Bolt Failure Prevention
      03-02-2014, 08:37 AM   #67
Unklejoe
98
Drives: 335i
Originally Posted by Knobi View Post
Build date on mine is also April 2010. I had the vanos failure 7 months ago in August 2013, 3 bolt-heads sheared off @ 33K miles (i was stock at the time), luckily it was covered by the CPO warranty and both vanos units were replaced.
I assume they used the revised bolts when fixing it, but then again im afraid of this happening again when the warranty is over, does anyone have the part number for the revised bolts?
There's no part number for just the bolts, but the units were fixed so you are safe.
How did you notice the bolts were broken? Was there a check engine light?
      03-02-2014, 09:49 AM   #68
Sidnito
Sidnito's Avatar
Drives: 11 space 335i
Originally Posted by madmanhiker
hmmm I have an April 2010 build and I've been FBO+Meth for a while now. I was never aware of this........ very unsettling indeed.
when I pick up my car from being fixed I'll see. I can't believe this, I have to pay out of pocket cause the third party warranty company sees the bolts as hardware to the vanos.
      03-02-2014, 11:20 AM   #69
Knobi
Knobi's Avatar
Drives: 2015 YMB M3
Yeah, Check Engine Light came up, I drove about 4 miles to work and then another 3 to the dealership with reduced power.
2015 BMW M3 | DCT | Yas Marina Blue | Silverstone | Executive | Lightning | Driver Assistant | Carbon Ceramic Brakes
Instagram: @benrivasplata
      03-02-2014, 11:40 AM   #70
Knobi
Knobi's Avatar
Drives: 2015 YMB M3
I'm sorry to hear that man, i still believe you can fight it though, it's always helpful to mention a lawyer in some cases, hope everything works out for you.
These are the part numbers you need for the entire repair:
1 11367583208 Adjustment Unit, outlet
1 11367583207 Adjustment Unit, inlet
2 11367524954 Collar Screw
2 11367578877 Impulse Sending Wheel
1 11137600482 Profile Gasket
1 11132210959 Set of Aluminum Screws
1 11137559537 Torx Screw
1 11137582340 Torx Screw
1 11127587804 Profile Gasket
3 11127573439 Gasket
And here's a pic of the Repair Invoice explaining the work done, hope this helps you and the rest of the guys planning to do this on their own
-Ben
      03-03-2014, 08:15 AM   #71
JETmn
Drives: 2011 335i xDrive Msport
2011 335Xi  [0.00]
Lots of great info, thanks everyone! Just a note, the screws listed above are oil pan screws, so don't get your hopes up :P
      03-09-2014, 03:58 AM   #72
Andrewe92
enthusiast
Andrewe92's Avatar
Drives: 2011 e92 lci 335xi
I read more and more about n55 vanos problems in general , really hoping I don't run into any problems myself.
      03-09-2014, 10:25 PM   #73
dcaron9999
dcaron9999's Avatar
157
Drives: 2011 135i M package
Did anyone with early prod date N55 find a way to get this SIB work done as a preventive maintenance, or as a goodwill arrangement, even if the SIB situation below was not experienced?
SITUATION: A rattling noise can be heard from the engine compartment; the engine exhibits a loss of power; and the Service Engine Soon lamp is illuminated. One, or more of the following faults may be stored....
2011 X3 35i with M pack + 2011 135i w/6SPMT | 255 square tire setup | Quaife 3.46 LSD | Diff lock down bracket | Bilstein B8+Swift SpecR springs+H&R FSB | CDV delete | BMS Oil Tstat bypass | ER FMIC & CP | N54Tuning DP | GC Street Camber Plates | M3 FCA +guide rods+RSFB's+Tranny mounts | Manzo toe arms | Cobb Stg2 agressive tune | Hawk DTC70 brake pads | RB SS brake pistons | Goodridge SS brake lines | Custom brake cooling ducts
      03-10-2014, 02:45 AM   #74
Andrewe92
enthusiast
Andrewe92's Avatar
I'm getting a bit lost in this thread lol I forget but believe my car production day is in 2010 so I am affected by the possible bolt issue ? I am still under warranty until June should I do something about this ? As a precaution someone give some feedback to me
      03-10-2014, 08:10 AM   #75
JETmn
2011 335Xi  [0.00]
The dealer won't do anything as a precaution. They will only repair once the bolts have broken. That is why we have people interested in replacing the bolts as a preventative measure since it could potentially cause a lot of damage if the bolts do break.
      03-10-2014, 11:14 AM   #76
Sidnito
Sidnito's Avatar
when I talked with bmw na they were really helpful but when I complained to the manager of my dealership he was willing to work with me. the only issue I had was I have 85k so it's way outside the 50k warranty so he couldn't budge. I told him"so does bmw just wait until they break off and then fix them?" and he replied,"no but this SIB is a recommended way of fixing it, not saying it needs to be fixed." so I said,"this should of been addressed when I was within the warranty." manager replied,"well it's not a thing we can see without taking apart then engine."
from my experience I would take your car in with the SIB, it's a big deal that they should fix it and complain to them and how they operate. I payed $3700 two days ago for this crap, so frustrated but now it runs really well and smooth!
I also learned that a downpipe with the n55 creates idle issues.
      03-10-2014, 01:14 PM   #77
bk335ilci
Drives: 2011 335i Alpine White
I am impressed with the miles you have 85k. What other major issues have you had with your car?
      03-10-2014, 04:25 PM   #78
Sidnito
Sidnito's Avatar
yeah I'm not sure what the previous owner did. I've just had the HFPF go out but that's under a recall. that's it since I've owned it-60k+
I'm pretty sad about not being able to use a catless DP, has anyone else experienced this?
      03-10-2014, 05:34 PM   #79
Unklejoe
98
Drives: 335i
Small Update:
I got the new bolts in the mail.
These are steel class 8.8. Should be the exact same size as the original ones.
      03-10-2014, 05:38 PM   #80
Markus8291
Markus8291's Avatar
Austria
19
Drives: 2011 bmw 335i xdrive M-Sport
Originally Posted by Unklejoe View Post
Small Update:
Awesome! Very excited to find out how easy it is to replace these!
2011 BMW 335i xDrive M-Sport, Alpina B3 TCU flash, JB4 (ISO 5.3, Map 5), BMS DP, BMS Intake, BMS CP, KW V1's
      03-15-2014, 10:29 AM   #81
GB-335xiCoupe
Libertarian
GB-335xiCoupe's Avatar
Drives: 29k mi per year.
http://bmwfans.info/parts-catalog/E9...cylinder_head/
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi
Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k
Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k
      03-16-2014, 03:16 PM   #82
Unklejoe
98
Drives: 335i
Anyone stumble upon any pics of the valve cover removed on an actual N55 engine? It's hard to tell if we can get to the bolts from the pictures so far in this thread.
      03-20-2014, 09:29 AM   #83
houston2011
Drives: 2006 530i
I am having this problem with my 2011 335i coupe, took the valve cover off yesterday! I will be taking pictures of the engine today!! Need more info on the screws! Please help!
      03-20-2014, 09:51 AM   #84
dcaron9999
dcaron9999's Avatar
157
Ive ordered the transmission and engine magnetic drain bolt from http://www.drainplugmagnets.com/.
This is obviously not a cure, but cant hurt if the VANOS bolt heads ever pop, and fall in the oil pan, by pure luck.
Since my N55 is in the dreaded production date range (May 2010), I will eventually be doing the Vanos bolt replacement fix as a DIY, maybe before the base warranty ends.
Really hoping to see someone take the plunge soon, and document his DIY procedure.
      03-20-2014, 10:04 AM   #85
dcaron9999
dcaron9999's Avatar
157
As per the SIB include in this thread, these are the N55 engines at risk.
MODEL
E70 produced from 2/2010 to 12/2010
E71 produced from 2/2010 to 12/2010
E82 and E88 produced from 2/2010 to 12/2010
E90, E91, E92 and E93 produced from 2/2010 to 12/2010
F07 535i produced from 2/2010 to 12/2010
F10 535i produced from 2/2010 to12/2010
F12 and F13 produced from 2/2010 to 12/2010
F25 produced from 2/2010 to 12/2010
Just need to check your Production date. Do this with the last 7 VIN digits againt REALOEM.COM ...
Then, if you are in the hit list, use your best PR skills to convince your Service Advisor, or his manager to get this SIB implemented as a preventive maintenance. I dont think any members have succeeded, unless the issue has actually occurred under base warranty.
      03-20-2014, 10:10 AM   #86
dcaron9999
dcaron9999's Avatar
157
Im not a mechanical engineer, but I assume that specific bolt material is critical (must mate with gear material, must not expand over a specific level when heated, must resist to vibration, etc).
Please take pictures of the steps leading up to your valve cover removal!
      03-20-2014, 12:07 PM   #87
Andrewe92
enthusiast
Andrewe92's Avatar
MODEL
Interesting is there an actual sib number or anything I can bring to my SA ? He is a nice guy but he will most likely wanna see something I can bring him
      03-20-2014, 12:27 PM   #88
houston2011
Drives: 2006 530i
Anklejoe, where did get the bolts from? Thanks!!
n55, solenoid, vanos
