05-17-2022, 12:03 PM | #1 |
4920
Rep 115,999
N54Tuning.com - B58 Gen 1 (F2X, F3X, G3X, G1X, G0X) Port Injection Kit With Flex Fuel
ORDER LINK
https://www.n54tuning.com/b58-gen-1-...atibility.html B58 Gen 1 (F2X, F3X, G3X, G1X, G0X) PRECISION RACEWORKS SKU: 601-0175 The Precision Raceworks B58 Port Injection kit with flex fuel compatibility is a necessity to safely and sufficiently support the power levels anyone needing additional fueling. This kit is capable of providing supplemental fueling to all BMW's equipped with B58 Gen 1 engine (see fitment guide for full details). The complete kit integrates seamlessly into your car like it left from the factory with it installed; you can barely even see the kit once the car is assembled! This kit includes everything needed to add multi-port injection and is 100% e85 compliant. We include new genuine Bosch Motorsport injectors which are flow matched both static and dynamic by an outside lab to industry leading requirements. A Detailed certificate of conformance and genuine Bosch product certificate is included with each kit giving you all flow data needed for optimal tuning. Don’t be tricked into thinking all port injection kits are equal, the Precision Raceworks is the only port injection kit currently where all 6 injectors have even fuel distribution for each cylinder. Additionally this kit features 750cc* injectors standard (this flow rate is based on industry injector flow test pressure of 43.5psi)at 72psi these injectors flow 1000cc. What this means is our kit is capable of supporting builds from 400whp up to 1,000whp out of the box. Simply pick up this kit and pair it with your favorite injector controller and you are ready to go! Our favorite injector controller is the AIC-6 which is compatible with all B58 cars and is the industry standard which is why we offer it with this kit. Vehicle Fitment Bmw 240i 2017 to 2018 Bmw 240i Xdrive 2017 to 2019 Bmw 340i 2016 to 2018 Bmw 340i Gt 2017 to 2018 Bmw 340i Xdrive 2016 to 2018 Bmw 440i 2017 to 2019 Bmw 440i Gran Coupe 2017 to 2019 Bmw 440i Xdrive 2017 to 2019 Bmw 440i Xdrive Gran Coupe 2017 to 2018 Bmw M140i 2016 to 2019 Bmw M240i Xdrive 2017 to 2018 Engine Compatibility: All B58 Gen 1 engines (see fitment guide for full details) Injector brand: Genuine Bosch Motorsports Advertised Flow - 750cc: 750cc @ 43.5psi , 1050cc @ 72.5psi Advertised Flow - 950cc: 950cc @ 43.5psi, 1226cc @72.5psi Fuel Compatibility: All known fuels including full E85 compatibility Flow Matched: 2% or better (250% more accurate than off the shelf injectors) Connection Type: EV6 (Called US Car Connector) works with AIC and JB4 Controller Hardware included: Yes full stainless hardware included Gasket Type: OEM Spec manifold gaskets (commonly found in BMW N54 applications) Fuel Distribution Pattern: Diagonal equal distribution across all cylinders Fuel Line: Smooth bore PTFE with stainless braid and nylon braid safe for all fuel types |
08-20-2022, 09:05 AM | #2 |
4920
Rep 115,999
09-17-2022, 12:05 PM | #3 |
4920
Rep 115,999
10-02-2022, 07:58 AM | #4 |
4920
Rep 115,999
10-13-2022, 02:58 PM | #5 |
4920
Rep 115,999
10-29-2022, 07:51 PM | #6 |
4920
Rep 115,999
05-23-2023, 03:36 PM | #7 |
4920
Rep 115,999
07-04-2023, 08:49 AM | #8 |
4920
Rep 115,999
12-08-2023, 10:16 AM | #9 |
4920
Rep 115,999
01-19-2024, 01:04 PM | #10 |
4920
Rep 115,999
02-20-2024, 09:08 AM | #11 |
4920
Rep 115,999
