03-07-2021, 11:11 AM | #25 | |
Rep 413
03-13-2021, 01:07 AM | #26 | |
Rep 9
Can you also help with the numbers for clutch bolts and other stuff needed for clutch work? Part number is 21212284034. |
10-02-2021, 01:47 PM | #29 |
2631
Rep 2,142
Drives: 2011 E92 M3
I think there is an error as the first post says to tighten the oil sensor unit to 18Nm. That is way too tight according to ISTA.
Cheers,
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
10-03-2021, 11:39 AM | #30 |
Rep 413
Good catch, correction made.
11-16-2022, 07:40 PM | #35 | |
Rep 404
2. Yes, it is the right spec. 3. Your profile says 2011 328i. This is an M3 forum. These specs are for an M3, which apparently has bigger fasteners and calls for 2x the torque. You didn't use the M3 spec on a 328i, did you? 4. Even if you did... 56 Nm is not a ton of torque. You sure that's all you used? 5. Blaming others for your mistakes is bad for you. 6. Melting down on a free resource that obviously took a lot of time to assemble, and that a lot of people are grateful for, isn't a great way to introduce yourself to the community. Last edited by IamFODI; 11-17-2022 at 10:05 AM.. |
02-15-2023, 08:31 AM | #36 |
9
Rep 29
Drives: 2011 E92 M3
Rear Diff Torque missing
One Torque setting I did not see and need are the bolt to the Diff side flanges. and rear cover
E92M3 DCT Rear Diff See pic. thanks |
02-15-2023, 09:24 AM | #37 | |
Rep 413
Edit: Added to the reference page, thanks.
IamFODI365.50 |
02-15-2023, 10:39 AM | #38 |
9
Rep 29
Drives: 2011 E92 M3
02-15-2023, 01:04 PM | #39 | |
Rep 413
I added the rear differential cover screws to the reference page which have a 60NM (42 ft lb) torque spec with Loctite 270 (green thread locker), but they are larger M10 screws and have greater tensile strength as they are a grade 10.9 screw. |
IamFODI365.50 |
02-28-2023, 06:10 PM | #40 | |
Rep 1,529
Drives: '11 BMW M3
Can anyone confirm the torque specs for bolts 1 and 2 in the diagram above for the tensioner assembly? There seems to be a few different numbers floating around in the original thread and online for those 8.8/10.9 M8 bolts and just looking to confirm.
New: '11.5 e90 M3 | DCT | Space Gray/Novillo | ZCV | ZCW | ZP2 | ESS 625 | BPM | M Performance | iPE | BC Racing | BPM | iND | LUX | Volk | Coby | Recaro
Sold: '11.5 e92 M3 | DCT | Mineral White/Novillo | ZCP | ZCV | ZCW | ZP2 | M Performance | ACM | BPM | iND | Thule | LUX | Macht Schnell | Broadway Static | Rogue Engineering | BBS | Challenge | Metak |
