10-07-2022, 11:43 AM | #177 |
Supreme Allied Commander
3888
Rep 54,572
Drives: F80 M3
The basic front only kit consists of a custom upper spring perch, Swift springs, and Swift thrust sheets.
The complete kit will come with rear Swift springs, Swift thrust sheets, and a pair of rear height adjusters. For those who wish not have to mess with machine work on the front lower spring adjusters, we also have a kit with machined adjusters included. The bottom photo is he front kit mounted on KW struts, one with the stock upper mount, and the other with Vorshlag camber plate. ***Slight machine shop work is required for the front lower spring perch, which can easily be done at a local mahine shop. Alternatively, you can purchase new machined KW adjusters from us as well.*** A wide variety of spring rates are available to choose from or we can make a recommendation for you. Camber plates(Vorshlag) is optional but recommended if you are attending HPDE or track days. We can custom tailor Swift spring upgrades for many KW, Bilstein, Ohlins and other coilovers. |
11-10-2022, 12:29 PM | #179 |
3888
Rep 54,572
Drives: F80 M3
The complete kit will come with rear Swift springs, Swift thrust sheets, and a pair of rear height adjusters. For those who wish not have to mess with machine work on the front lower spring adjusters, we also have a kit with machined adjusters included. The bottom photo is he front kit mounted on KW struts, one with the stock upper mount, and the other with Vorshlag camber plate. ***Slight machine shop work is required for the front lower spring perch, which can easily be done at a local mahine shop. Alternatively, you can purchase new machined KW adjusters from us as well.*** A wide variety of spring rates are available to choose from or we can make a recommendation for you. Camber plates(Vorshlag) is optional but recommended if you are attending HPDE or track days. Available for Ohlins, TC Kline Racing, Bilstein and other coilovers as well. PM for details. |
12-22-2022, 12:30 PM | #181 |
3888
Rep 54,572
Drives: F80 M3
The complete kit will come with rear Swift springs, Swift thrust sheets, and a pair of rear height adjusters. For those who wish not have to mess with machine work on the front lower spring adjusters, we also have a kit with machined adjusters included. The bottom photo is he front kit mounted on KW struts, one with the stock upper mount, and the other with Vorshlag camber plate. ***Slight machine shop work is required for the front lower spring perch, which can easily be done at a local mahine shop. Alternatively, you can purchase new machined KW adjusters from us as well.*** A wide variety of spring rates are available to choose from or we can make a recommendation for you. Camber plates(Vorshlag) is optional but recommended if you are attending HPDE or track days. Attached Images |
