04-23-2010, 05:27 PM | #1 |
549
Rep 5,695
▀▄ eas | DIY: Macht Schnell - Competition Stud Conversion Kit Installation
Step 1
Jack up the vehicle and secure it on jackstands.Unbolt the lug bolts. Step 2 Remove wheel from hub. Step 3 Remove wheel and clean hub of all dirt and/or surface rush with a wire wheel to ensure a clean and flush surface. [optional] Step 4 Apply loctite onto the end of the studs and hand tighten the studs onto the hub. Step 5 Use an allen wrench to completely tighten the studs onto the hub. Step 6 Put your wheel back on and torque down the wheel locks. Repeat for the other three wheels. This is how it will look finished without the wheel on it yet(also has a spacer on it) Enjoy! |
04-23-2010, 10:42 PM | #2 |
Rep 598
This is an awesome DIY. Answers many questions I had regarding. THANKS!
Current: 2006 Lotus Elise SC
Previous: 2008 AW E92 M3 6MT - Sold 2004 AP2 S2000 - Sold |
04-26-2010, 12:42 PM | #5 |
549
Rep 5,695
The torque spec is the same as your lugs.
Many people prefer studs because of the ease of swapping wheels, and not having to change lugbolts every time they change wheels. Those would be the advantages of doing a conversion. |
04-26-2010, 10:42 PM | #6 |
Rep 1,339
I think he was asking the torque of the bolts in the wheel hub...although this is moot if they are stuck with Loctite?
04-28-2010, 06:10 PM | #7 |
Formerly K335i
19
Rep 215
Turner recommends 16 ft-lbs of torque for the stud in the hub. Nuts to stud should be the same as your original lug bolts (around 85 ft-lbs).
2009 E92 M3 :: Jet Black :: Fox Red Extended :: Carbon Leather :: 6MT :: JRZ RS Suspension :: RD Sport Sways :: StopTech Trophy Brakes :: Cantrell Brake Cooling |
04-29-2010, 06:01 AM | #8 |
Rep 1,339
05-04-2010, 12:24 PM | #9 |
E90 - the Ultimate family hauler
22
Rep 578
How much is a kit like this? Considering the amount of times per year I swap wheels for track and street duty this might be a great mod.
2008 AW E90 M3 - current
2002 TIAG E46 M3 - gone 1991 DiamondSchwartz E30 M3 - gone but not forgotten |
05-04-2010, 12:37 PM | #10 |
8288
Rep 18,861
Drives: BMW
Everything can be found on our website.
07-23-2011, 07:57 AM | #11 |
The General
34
Rep 496
Thanks for the write up David. Been looking for this.
E92 M3
2011.5 AW / DCT / ZCV / ZP2 / Heated Seats (SOLD) 2018 M3CS |
12-31-2011, 11:55 PM | #12 |
definitivecars.com
354
Rep 3,833
Drives: Elsa - 2015 F80 M3 - YMB/SS
Garage List 2011 E90 M3 [6.66]
2009 (Lease up Sept ... [0.00] 2007 (Lease up 6/19 ... [0.00] 2007 (Lease up Octo ... [0.00] |
Question, Can you get these off later, Like 1.5 years later for lease return?
D |
01-03-2012, 02:14 PM | #13 |
549
Rep 5,695
01-03-2012, 04:07 PM | #14 |
definitivecars.com
354
Rep 3,833
Good to know thanks.
05-09-2012, 09:49 PM | #15 |
Rep 6,763
Can someone please explain why 16 torques is sufficient, when the lugs will need 85? Won't the studs come off when you try to remove the wheel?
Does the loctite hold it together? I mean, the hub can take 85 and more...
2018 F80 Santorini 2019 Z4 3.0i 2022 X2 M35i |
05-11-2012, 12:40 PM | #16 |
549
Rep 5,695
The stud torque is just to keep it on the hub when you loosen the lugs. The 88 ft lb. on the lug nut will determine the actual torque of the stud and nut.
10-30-2012, 03:58 PM | #17 |
coupe la goon
373
Rep 1,644
Drives: green, black, white
Garage List 2011 BMW 1M Coupe [10.00]
2013 BMW M3 Coupe [10.00] 2010 BMW 535i xDriv ... [0.00] 2008 BMW M3 Coupe ( ... [0.00] |
Good lord, imageshack as an image host, and in a vendor DIY? Unimpressive.
