Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - California > ◄ SPEED LOGIC ► Modifications, Service & Installs for BMW N54/N55 (OC, LA, IE, SD)
      07-30-2018, 03:32 AM   #1
Speed Logic
Speed Logic's Avatar
Drives: B58, N54, N55, S55, S58, S63
Arrow ◄ SPEED LOGIC ► Modifications, Service & Installs for BMW N54/N55 (OC, LA, IE, SD)
SPEED LOGIC AUTOMOTIVE
7124 Garden Grove Blvd.
Westminster, CA 92683
Phone or Text: (888) 564-4215
Email: info@speedlogicauto.com
Message: Send a Private Message
*By Appointment Only*
We want to give a warm welcome to the Bimmerpost community! We are a fully licensed automotive shop that specializes on the various BMW Turbo Engines (N54, N55, S55, S63, etc). Whether you may be looking for simple plug and play Bolt-Ons, a Turbo Upgrade, or complete Tuning solutions and packages; we can be sure to be able to help you with your needs. We have the resources and BMW specialty tools to get the job done correctly for all the services we offer. Thankfully our employees are car enthusiasts as well and can easily share insight and passion for the lifestyle. We work closely with many brands and vendors within the BMW community, continually staying informed of new product updates and releases. We are looking forward to working with fellow enthusiasts and serving the community!
As an official introduction to the community, we figured we would work out a few deals that many of you may need or want on your BMWs. All specials will require drop-off of the vehicle and include both Parts & Labor. We only use Genuine OEM BMW Parts for all services we perform (please note that #3 and #8 may include aftermarket performance parts). Please be sure to mention E90post/Bimmerpost when contacting us for an appointment so we can sure to price the service accordingly. We are happy to package other items that are not listed, just be sure to reach out to us so we can accommodate for your specific needs. These are limited time specials and the prices will be subject to change at anytime!
*All special prices apply to 1 and 3 Series RWD vehicles - if you have another vehicle model please be sure to reach out to us directly for an estimate as the cost may be slightly additional*
#1 - Walnut Shell Blasting Service for N54 & N55 Vehicles (All models) including Replacement of OEM BMW Intake Manifold Gaskets during Service @ $300 (CLICK HERE)
#2 - Turbo Replacement with OEM Turbos for N54 Vehicles including Installation Kit, Fluids, Labor @ $3400
#3 - Pure Stage 2 Turbo Upgrades for N54, N55 Vehicles including Installation Kit, Fluids, Labor @ Contact for Lowest price in SoCal (CLICK HERE)
#4 - Clutch/Flywheel Replacement for N54, N55 Vehicles @ $500 for Labor if Parts purchased directly through us
#5 - Oil Pan Gasket Replacement for N52, N54, N55 Vehicles @ $800
#6 - Valve Cover Gasket Replacement for N54 Vehicles @ $400
#7 - Oil Filter Housing or Oil Cooler Gasket Replacement for N52, N54, N55 Vehicles $400, or $550 for Both
#8 - Spark Plugs and Coil Pack Replacement with OEM Bosch for N54 Vehicles @ $450
#9 - BMW ECU or DME Unlock for N55 Vehicles with Late model 2012+ @ $300
#10 - Waterpump Replacement for N52, N54, N55 Vehicles @ $800 *Thermostat would be additional*
We are proud to offer a wide variety of services to accommodate for your BMW needs. All services we offer are always performed by qualified technicians using specialized BMW tools. Each service includes a full 1-year warranty on Parts & Labor to give each client full peace of mind. If there are any services or items unlisted that you may be interested in please feel free to reach out directly and we would be happy to accommodate.
  • BRAKES
  • Brake Pads & Wear Sensor Replacement
  • Brake Rotors Replacement
  • Stainless Steel Brake Line Installation
  • Big Brake Kit (BBK) Installation
  • MAINTANANCE
  • Walnut Shell Blasting Cleaning Service
  • Vacuum Line Replacement
  • Belt, Belt Tensioner & Idler Pulley Replacement
  • Waterpump and/or Thermostat Replacement
  • Starter Replacement
  • Clutch & Flywheel Replacement
  • Turbo Replacement (Stock Turbos, Upgraded Twin Turbos, Single Turbos, etc)
  • IGNITION COMPONENTS
  • Spark Plug Replacement
  • Coil Pack Replacement
  • Fuel Injector Replacement
  • GASKETS & SEALS
  • Oil Filter Housing Gasket Replacement
  • Oil Cooler Gasket & O-Rings Replacement
  • Valve Cover Gasket Replacement
  • Oil Pan Gasket Replacement
  • Front & Rear Main Seal Replacement
  • FLUIDS
  • Oil & Oil Filter Change
  • Brake Fluid Flush
  • Coolant Flush
  • Power Steering Fluid Flush
  • Automatic Transmission Fluid, Pan, Mechatronic Sleeve Replacement
  • Manual Transmission Fluid Replacement
  • Differential Fluid Flush
  • SUSPENSION & DRIVETRAIN
  • Spring Installation
  • Coilover Installation
  • Differential Installation
  • Control Arm Installation
  • Rear Subframe Bushing Installation
  • Differential Bushing Installation
  • PERFORMANCE BOLT-ON INSTALLS
  • Intake Installation
  • Chargepipe Installation
  • Front Mount Intercooler (FMIC) Installation
  • Turbo Inlet Installation
  • Exhaust Installation
  • Turbo Upgrades (Stock Turbo, Upgraded Turbos, or Single Turbo Kit)
  • Fuel System Upgrades (Available for all power goals)
  • Oil Cooling Upgrades
  • Aluminum Radiator Upgrades
  • OTHER
  • Engine Replacement
  • Transmission Replacement
  • Automatic to Manual Transmission Swap
  • Tapping Intake Manifold for 1/4" Nipple
  • Oil Catch Can Installation
  • MHD Tune or Backend Flash Installation
  • Coding/Programming of any type
  • Alpina Transmission Flash
  • xHP Transmission Flash
  • Contact us directly for any other needs!
We offer many brands and products in addition to the brands below. We specialize in BMW aftermarket products and are happy to source anything you may need for your vehicle or build. We can also provide OEM BMW Parts for Service & Repairs, Retrofits, and Cosmetic Upgrades. Please feel free to ask us for any specific requests and we are happy to accomodate
Hours of Operation: Mon-Fri 10am-6pm, Sat 11am-4pm (PST)
Availability: *By Appointment Only*
Website: http://www.speedlogicauto.com
Instagram: @speedlogicauto
YouTube: @speedlogicauto
      07-30-2018, 05:59 AM   #2
Speed Logic
We are proud to announce that we are running a special for the Pure Turbos Stage 2 product line of Turbo upgrades. They offer a wide variety of Turbo upgrades that are easily able to hit the power goals for most N54 & N55 builds. We work closely with Pure Turbos since they are local to Southern California and provide high quality wear-matched and balanced components. They have a reputation for building the most proven turbo upgrades in the industry. In addition, by joining forces with Pure Turbos we are able to offer these Upgrades installed at a price that no other shop in Southern California can compete with due to our strong relationship. Come find out why these turbos have been making all the buzz within our community!
INCLUDED STANDARD ON ALL TURBO INSTALLS:
-Pure Turbo Upgraded Turbo(s)
-Motul 8100 X-Cess 5w40 Oil (Standard for Upgraded Turbos)
-OEM Turbo Installation Kit (All required Gaskets, Seals, O-rings, etc)
-OEM BMW Oil Filter
-OEM BMW Coolant & Distilled Water
-Full 1-year Warranty on all Parts & Labor
PRICING: Our prices for these Upgrades simply cannot be beat and we stand by it. We offer a Price Match guarantee and will be happy to beat other local and reputable shops. We are willing to do what it takes to earn your business. If you have found a cheaper deal or "special" elsewhere for these Turbos, please reach out and we will be sure to beat any competitor pricing as a means to earn your business. For accurate pricing and estimates - please reach out to us directly through Direct Message, Phone, or Email. Our pricing is so low that we are unable to share it publicly. Please be sure to mention E90post/Bimmerpost when contacting us so we can be sure to price the Turbos accordingly. Special pricing applies to all 1 and 3 Series RWD Vehicles - please inquire about other Models directly. These are limited time specials and the prices will be subject to change at anytime!
N54 VEHICLES:
Package 1 - Pure Turbos N54 Stage 2 DD Model (Daily Driver) - which are capable of ~600hp @ $3095
Package 2 - Pure Turbos N54 Stage 2 HF Model (High Flow) - which are capable of ~700hp @ $3595
Package 3 - Pure Turbos N54 Stage 2 Newest Model (Pure600) - which are capable of ~600hp @ $2200
Package Add-Ons:
(+INLETS) - We highly recommend Upgraded Turbo Inlets during Turbo Installation
(+OUTLETS) - We also recommend Upgraded Turbo Outlets during Turbo Installation
N55 VEHICLES:
Package 1 - Pure Turbos N55 Stage 2 - which is capable of ~550hp @ $2500
Package Add-ons:
(+INLET) We recommend to consider a Turbo Inlet Upgrade during Turbo Installation
(+DV) - We recommend to consider a DV Upgrade during Turbo Installation
Contact us through Direct Message, Phone, or Email for accurate pricing. Please be sure to mention Bimmerpost and include the following information with any inquiry:
-Year and Model Vehicle (ex: 2009 BMW 335i)
-Turbo Package of Interest (ex: N54 Package 1 + Inlets)
Hours of Operation: Mon-Sun 10am-5pm (PST)
YouTube : @speedlogicauto
      07-30-2018, 11:55 AM   #3
Kev0
115
Drives: 2012 BMW E92
You've done the walnut blasting and other installations/repairs on my car before. I will vouch for you. Knowledgeable and thorough guy!
      07-31-2018, 12:06 AM   #4
Deluvio2527
Drives: BMW 335i
One of the best and trusted mechanics I know Speedlogicauto hands down to Rob he always go beyond to your expectations
      08-13-2018, 12:54 PM   #5
Speed Logic
Kev0 Thank you for the kind words! We definately remember getting the Walnut Shell Blasting completed on the car a few years back. Hope she is still treating you well. If you ever need anything feel free to reach out!
Deluvio2527 Thank you for the comment. Glad to be a part of your build and have the opportunity to show you what we do best! As you know, we do take a lot of pride in our work quality and approach. Thank you so much for taking the time to post on this thread to let others know!
      08-14-2018, 03:25 AM   #6
Joec001
Drives: 2011 335is Convertible
Rob at speed logic is the best mechanic around. I have a 335is and been to a few other mechanics and none were as honest and friendly as him. He treated my car like it was his own. Got a walnut blast (has videos to show before and after) not too long ago and gave me lots of tips about my N54. Very noligable about Bmws and tuning. And to top everything off, he has the lowest prices you can find anywhere. Will be going back when I need anything done. Definitely message him or give him a call and you will see. Thank you Rob.
      08-21-2018, 06:13 PM   #7
Speed Logic
Thank you for kind words and review Joec001 . It was a pleasure working with you and having the opportunity to help with your 335is. Beautiful car without a doubt! Please reach out at anytime and we are more than happy to assist with anything you may need for the car. Thanks again!
      08-30-2018, 04:18 AM   #8
Speed Logic
Arrow ◄ SPEED LOGIC ► Walnut Shell Blasting for BMW N54 and N55 Engines @ $200 *SPECIAL*
What is Walnut Shell Blasting?
Walnut Shell Blasting involves "shooting" a mixture of compressed air and Walnut Shells into the Intake Ports to clean carbon deposits and buildup that occurs slowly over time on the Intake Valves. It is considered a scheduled maintenance service that is required only on Engines that have Fuel systems known as Direct Injection (or DI). Many vehicle makes and manufacturers have modern vehicles that are Direct Injection which would also require this cleaning at a specified interval, not just BMWs.
Modern day BMW's all use Direct Injection Fuel Systems - which as the name implies allows fuel to be “directly injected” into the cylinder combustion chamber. This enables the vehicle to be much more gas efficient, make more power with lower octane fuels, and allows manufacturers to meet efficiency requirements. While it provides many benefits, one specific drawback of the Direct Injection style Fuel system is that the Intake Valves are not cleaned with fuel or detergents. It creates the need for a Walnut Shell Blasting cleaning as a scheduled maintenance which should be performed regularly. If you have a Stock or Tuned vehicle and this service has yet to be completed - it would certainly be a good idea to get it taken care of!
How Often Do I Need Walnut Shell Blasting?
The service should be completed based on a balance of how the car was driven as well as modifications during this time. If the vehicle is completely stock, then the Walnut Shell Blasting Service should be completed as a scheduled maintenance service every 50K miles. With elevated heat cycling and levels with a modified or tuned vehicle - the need for the scheduled maintenance service becomes more important to be completed every 30-40K miles depending on use within this time. Many owners have more mileage than these recommendations, previous owners responsible for a large amount of mileage, or even drive the vehicles lightly. Any of these circumstances may call for slightly different intervals and if you have any specific questions in this regard please feel free to reach out to us directly and ask. We are happy to answer any questions specific to your application.
Which Vehicles Need Walnut Shell Blasting?
-BMW 135i w/ N54 Engine (2008-2010)
-BMW 135i/135is w/ N55 Engine (2011-2013)
-BMW 335i/335xi w/ N54 Engine (2007-2010)
-BMW 335is w/ N54 Engine (2011-2013)
-BMW 335i/335xi w/ N55 Engine (2011-2013)
-BMW 535i/535xi w/ N54 Engine (2008-2010)
-BMW Z4 35is w/ N54 Engine (2009-2016)
-BMW X1 xDrive 35is w/ N55 Engine (2011-2016)
-BMW X6 xDrive 35is w/ N54 Engine (2009-2016)
What are Symptoms of a Vehicle that Requires a Walnut Shell Blasting?
-Car is due for scheduled maintanance cleaning (Every ~30-40K Tuned and Every 50K Stock)
-Vehicle has Misfires in One or more Cylinders
-Rough Idle (May occur during Idle or Cold Start)
-Car has sluggish response overall
What is the Cost of Walnut Shell Blasting?
The Walnut Shell Blasting Service costs $350 and includes Replacement of the OEM BMW Intake Manifold Gaskets during the service
CURRENT SPECIAL: $300 out the door for a Limited time when you mention Bimmerpost!
What is the Difference between Speed Logic and the Other Shops offering Walnut Shell Blasting?
Experience and Quality. With regard to Experience, we have performed over 1000+ Walnut Shell Blastings for Enthusiasts within the Southern California area and beyond. Not a single shop can complete with the number of cleaning we have completed for locals. On the other hand, don't let the number of cars we have Walnut Shell Blasted fool you. We take our time and treat every car as if it is our own - during cleaning and also careful reassembly. We simply won't reassemble the car unless it looks like one of the videos on this post. And we mean it! We have hundreds of videos we are happy to share to prove this is not an anomaly. Every single car that comes through our doors for this service gets cleaned with this expectation. Lastly, since we didn't answer the question directly - go ahead and answer it yourself by taking a look or asking for end results of those Other Shops? We promise our work is unmatched by any other Shop in this regard - not to mention we have the videos to PROVE it and are happy to do so
Contact us through Direct Message, Phone, or Email to setup an appointment. Please be sure to mention Bimmerpost to receive special pricing. We will need the car dropped off for this special pricing. We generally need the car dropped off for a minimum of 4 hours or about half the day. Depending on workloads we may need the car for longer - but will always be able to provide a same day or 1-day turn around for this service. For any questions, please inquire directly!
      08-30-2018, 04:19 AM   #9
Speed Logic
Do you have any Videos to better explain the Before & After Results?
Yeah, we sure do! We are confident in our results on every car that gets this service performed in our Shop. Here are some Before & After Video Results of a Client with a 2008 BMW 335i with the N54 Engine. This vehicle had 60K on a Stock Vehicle prior to this service being performed. The After results clearly show the Intake Valves and the dramatic difference with the Walnut Shell Blasting Service. We see this here visually, but this is also felt with power, response and gas mileage.
Before Cleaning:
After Cleaning:
      08-30-2018, 10:45 PM   #10
Rogue-OP
Rogue-OP's Avatar
58
Drives: to Drum & Bass
Damn those SoCal prices are nuts!
      09-07-2018, 05:03 PM   #11
Speed Logic
Bump!
      09-10-2018, 11:30 AM   #12
hipnotic
hipnotic's Avatar
Drives: e92 335i
2008 335i coupe  [7.00]
I just had my e92 walnut blasted & the car feels a lot smoother. Rob is the best!! He treats you & your car with respect and explains to you what will be done. He even has videos of you car before & after. He is never in a rush & takes his time to thorough do the best job he can. I was even shocked that my engine bay was super clean after the walnut blasting. Highly recommended & will refer other members to him. Great job & keep up the quality work Rob!!!!
      09-15-2018, 01:21 PM   #13
Haideezy
Boost>N/A
Drives: 2007 BMW 335i Sedan
Good lord, I may have to stop by Fullerton on the way to SD hahaha.
      09-19-2018, 03:46 PM   #14
Speed Logic
Thank you Josh! Was a pleasure working on the car and having an opportunity to clean the Intake Valves on your E92 335i. Glad the car is running well and happy we were able to provide a great experience. Thank you again!
      09-20-2018, 02:32 PM   #15
ZerenDip
Drives: 2008 BMW 335i Sedan
I went to Rob a few months ago before these posts started popping up. He's gone above and beyond when working on my car and his prices are way under the market prices for his quality of work. Definitely recommend getting your walnut blast done with Rob if you're near the area.
      09-29-2018, 12:46 PM   #16
Speed Logic
Bump!
      10-04-2018, 02:43 PM   #17
Speed Logic
@ZerenDip Thank you so much for the kind words and support! It has been a pleasure getting your car setup and running well over the past few months. You may have posted in the wrong thread though, we have done a lot more than just the Walnut Shell Blasting for your build
Bump to the top!
      10-20-2018, 10:48 AM   #18
geost
42
Drives: 2011 335d M Sport
No love for the diesel engine even if a little more $$?
      10-20-2018, 02:00 PM   #19
Speed Logic
This special is only available for Gasoline models, our apologies. We don't offer the service for Diesels at this time.
      11-06-2018, 03:18 PM   #20
Speed Logic
Bump!
      11-06-2018, 10:27 PM   #21
Ksalanguit
Drives: BMW 335i 2007
Cobb
Do you guys make tunes for Cobb accessport?
      12-06-2018, 03:54 PM   #22
Speed Logic
Bump!
135i, 135is, 335i, 335is, 335xi, california, carbon cleaning, n54, n55, socal, southern california, special, walnut shell blasting
