05-15-2019, 08:21 PM | #1 |
1439
Rep 1,614
BMW (finally) publishes S65 Rod Bearing Clearance Specs
There's a new and "shocking" development for the people following the BMW S65 rod bearing issue. After 10+ years, BMW has finally published their rod bearing clearance specifications. To put it mildly, the specs are shocking and are worse than we had imagined.
Every time a new TIS is published, Bert checks to see if BMW has finally published the rod bearing clearance specs. Such was the case last week when Bert was researching the rod bearing specs for S63 motor. That's when Bert pulled up the S65 engine specs, and noticed that they finally contain rod bearing clearances. [LINK] The specs aren't good and confirm a worse-than worst case scenario. When Van Dyne measured the original bearings @ 0.0013 inch, they didn't imagine that was at the top end of the clearance specs. Stewart Van Dyne gave the following comment over the phone: "Well, BMW just confirmed that they're doing what we all know doesn't work." Minimum clearance: 0.0004 inch Nominal clearance: 0.0009 inch Maximum clearance: 0.0013 inch * Same information is posted in the Bearing Clearance Wiki thread. |
17
SoCalRPM885.50 Mjbluth0.00 Iyzmi802.00 Scharbag2622.00 BrewRifle419.50 Icecreamfoo134.00 Mvy540.50 derbo3610.00 schnell1982345.00 dparm3850.50 Law6381.00 inTgr8r2431.50 deansbimmer3752.00 Assimilator1594.00 DrFerry6728.50 ///M Power-Belgium63418.00 L4ces337.00 |
05-16-2019, 11:48 AM | #2 |
Rep 7,113
Thanks Green-Eggs, how interesting! Yeah certainly seems to be on the (extremely) tight side and assumingly a good reason to the wear issues we see. BMW engineering certainly been around so bit of a mystery.
These numbers also make me curious about your own measurement of BMWs shell which comes out with quite a bit more clearance? Nominal Rod Bearing Clearance 0.0381mm Bearing Clearance Variance 0.0292 - 0.0508mm Just trying to understand what we're comparing here. Thanks |
05-16-2019, 12:26 PM | #4 |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
Link doesn't provide the same info found in body of your post. Is there another location with that info. Thanks for posting this!
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
DrFerry6728.50 |
05-16-2019, 02:28 PM | #6 |
Derbo Tuning
3610
Rep 3,022
so now what?
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services |
05-16-2019, 05:23 PM | #7 |
Rep 6,734
I believe that "connecting rod play" is side play - not bearing clearance.
'23 X7
05-16-2019, 05:57 PM | #8 |
1458
Rep 2,336
One could only hope but that won't happen
'09 ///M3 Sedan - Jerez Black/Fox Red Ext.
'09 335i Coupe - Alpine White/Black - SOLD |
05-16-2019, 07:11 PM | #9 | |
1439
Rep 1,614
One thing about those numbers, you' pulled them from the 702 bearings, not the 088 bearings. Since these specs just appeared 10+ years later, we have no idea whether they are for both bearings or not. My personal opinion is that the specs between 088 and 702 bearings didn't change. I know that goes against the general opinions of others. I think those measurement differences are rather insignificant. 0.5/10000 to 2/10000 of an inch difference between paper specs and measured specs is pretty insignificant IMO. |
DrFerry6728.50 |
05-16-2019, 07:17 PM | #11 | |
1439
Rep 1,614
1. Side clearance is typically 10x - 35x larger than these values. If these were side clearance values, the engine wouldn't last. 2. The S63TU engine and other BMW engines also list these specs but add the word "Radial" to them. For S63TU, it's very clearly bearing clearance specs as the wording is consistent across many BMW engines. Here's the link: https://www.newtis.info/tisv2/a/en/f...rings/GIecw87b Still being concerned with the odd wording, Bert checked with Indy and NASCAR engine builder friends. Both confirmed it meant rod bearing clearance; side clearance was therefore excluded. Last edited by Green-Eggs; 05-16-2019 at 07:24 PM.. |
deansbimmer3752.00 DrFerry6728.50 |
05-16-2019, 07:27 PM | #12 |
Rep 3,988
Great to finally get confirmation what we pretty much knew all along. Or actually it is slightly worse than we thought, but we knew it was less than industry standards.
Queue those who don't know anything coming in to say...."but BMW must know what they were doing and must have done it for a reason." |
DrFerry6728.50 |
05-16-2019, 09:50 PM | #13 | |
Stop the hate, get a V8
3851
Rep 8,625
Well it's not like BMW has never built engines before. A bearing clearance is not something they just arbitrarily pick, this shit goes through a lot of R&D. That being said, we don't have any information about what kind of data led them to that design. It's very possible it was based on bad data.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
05-16-2019, 10:04 PM | #14 |
Rep 942
Thanks for the info, OP. Similar to what someone asked in the parallel thread on this issue - why did BMW do this?
Perhaps, the tight clearance stems from some kind of performance based standard that originated in F1 or some other racing development? If they carried over specs from race engines that likely see rebuilds long before road-going passenger vehicles ever would, then maybe there wasn't sufficient data on the long-term reliability. I suppose it's immaterial, the clearance data itself being outside of industry standard should be enough to deter them. Ultimately, it still comes down to either BMW didn't know, or worse, they didn't care. |
05-17-2019, 07:34 AM | #15 | |
Rep 7,113
For what its worth it seems that at least the 702 shell often comes out around 0.04mm using plastigage, which would match your own number pretty well. |
Assimilator1594.00 DrFerry6728.50 |
02-02-2024, 08:55 PM | #16 |
Rep 1,026
Drives: BMW M3 e92 08 & 330d e90 10
Old thread I know, but still relevant.
I've recently been involved in an argument over at m3cutters regarding S65 bearing clearances and rod bearing problems (some there don't believe it's a clearance problem...). As a side shoot from that discussion Paul Gros of MAR Motorsport, an official seller of Mahle MotorSport bearings etc (& he's apparently formerly from Mahle itself), has dipped his toes into it, and then in a separate thread posted clearance specs for the OEM lead/copper bearings which he states are not made by Clevite, but by Mahle/Glacier Vandervell and that the "mean clearance was 0.046mm and the grading scheme allowed a total range of 0.029/0.062mm" It would seem the figures from TIS (& AIR) are not the rod bearing clearances.... And it would seem the OEM mean (nominal) figures aren't as tight as we thought, although still less than industry standard and BE bearings and Mahle Motorsports own bearings. Seems to me the OEM ones are still somewhat on the tight side, especially at the lower end, just a little less tight than we originally thought (in respect to nominal clearances, not measured). Thoughts?
Oil analysis for finding wearing rod bearings?. Collation of oil analysis reports with some rod bearing photos for the M3's S65. My categorisation of pulled rod bearings in the rod bearing condition thread. My updated 'Blown engines' list. Last edited by Assimilator1; 02-02-2024 at 09:13 PM.. |
02-02-2024, 09:26 PM | #18 | |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
///M Power-Belgium63418.00 |
02-02-2024, 09:33 PM | #19 | |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
Honda S2000 (F22C1) Engine capacity - 2 ltr Engine power - 237 hp Hp/ltr - 118.5 Redline - 8000 RPM Preferred oil spec - 5w30 Rod bearing clearance variance - 0.02-0.06mm Crankshaft pin/rod journal diameter - 49.988mm Clearance to Journal Size Ratio - 0.008mm S65 specs Engine capacity - 4 lts Engine power - 414 bhp Bhp/ltr - 103.5 Redline - 8300 RPM Spec'd oil - 10w60 Nominal rod bearing clearance - 0.0381mm (0.00150") Rod bearing clearance variance - 0.0292 - 0.0508 mm (from BE's S65 wiki for the later Alu/tin shells, which apparently have a slightly higher minimum) Crankshaft pin/rod journal diameter - 51.9786-51.9887 mm (official specs posted in the S65 wiki) Clearance to Journal Size Ratio - 0.0007mm Source Assimilator1 's thread: https://www.m3post.com/forums/showthread.php?t=1827360
02-03-2024, 01:09 AM | #20 |
80
Rep 117
I started the initial discussion thread over on m3cutters and after a private email conversation with paulgros, I found myself hanging on his every word. His engineering and specifically bearing knowledge is almost encyclopedic.
The key point is that the numbers that started this thread are definitely the correct ones for con rod play and con rod play is very much not the same as clearance. It seems that a lot of people have been taken in by an incorrect assumption. The oem nominal clearance is certainly bigger than is being touted here. Main reason for UK skepticism is the disproportionate number of failures you have had compared with us. It suggests there’s something else going on, other than just slightly lower than normal rod bearing clearance. |
02-03-2024, 01:32 AM | #21 | |
46
Rep 32
DrFerry6728.50 |
02-03-2024, 03:18 AM | #22 | |
71
Rep 70
DrFerry6728.50 |
