BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
European Auto Source (EAS)
      12-09-2019, 05:18 PM   #1
divadp17
divadp17's Avatar
194
Drives: e90 m3 6mt
RTD v4 mini shifter
Alright guys just wanted to share this post for anyone that plans to get a RTD V4 shifter for their e9X m3.
First of all the built quality of this shifter was very nice. IMO it was worth every penny as I didn't like the shift the way the stock shifter felt. The shift on the rtd is really short, no slop, and very easy to install.
The only complaint I have is the shifter not coming with a rubber seal for the chassis mounting areat. Without that rubber cover expect all types of noise and air to channel through that mounting point. Eventually I couldn't handle the noise and amount of dust that was accumulating in the interior. So what i did to fix this issue was by using the oem rubber cover and cutting the bottom half where the thick mounting point is. Then apply some silicon glue to mount the rubber seal on the RTD shifter. This basically reduced all the noise and the air from channeling in.
I highly recommend doing this if you plan on getting this shifter.
08 E90 M3 6MT
IG: divadp17
Appreciate 5
      12-09-2019, 08:27 PM   #2
Conzyo
Pho is yummy
Conzyo's Avatar
Drives: E90 M3 & E70 X5M & 12' GTR
Thanks for the heads up.
I've been wanting one for awhile now.
Where did you order from?
Thanks again
2008 | 6 SPD | Fox Red | Forgestars | B&G Springs | M Performance Exhaust | Catless X pipe | Alpine Tune
      12-10-2019, 11:37 AM   #3
Drifter2090
Drifter2090's Avatar
910
Drives: E90 M3 | E92 335i | E90 335d
Looks great! Does adding the rubber effect the shifting at all?
MGM F82 M4 DCT / MPerformance / Swift / CSF / IND / Turner / BimmerWorld
BSM F87 M2 6MT / Fabspeed / MPerformance / Turner / AutoID - SOLD
JB-NB E92 M3 6MT / IND / RTD / Alpine / KW / ActiveAutowerke / 360Carbon - SOLD
SS2-FR E90 M3 6MT / IND / AFE / ActiveAutowerke - SOLD
AW-FR E90 M3 DCT / ACM / IND / AutoTecknic / K&N / H&R / Bilstein - SOLD
//steve\\1074.00
      12-10-2019, 03:38 PM   #4
divadp17
divadp17's Avatar
194
Drives: e90 m3 6mt
Thanks again
I ordered from the RTD site.
http://rtd-motorsports.com/product/r...r-kit-e8x-e9x/
08 E90 M3 6MT
IG: divadp17
Conzyo767.50
      12-10-2019, 03:39 PM   #5
divadp17
divadp17's Avatar
194
Drives: e90 m3 6mt
No there is enough space and buffer from any interference.
08 E90 M3 6MT
IG: divadp17
      12-10-2019, 09:04 PM   #6
nycplumber
Drives: slow
They look so nice it makes me want to buy a manual
      12-10-2019, 10:10 PM   #7
Conzyo
Pho is yummy
Conzyo's Avatar
How long was the wait for the shifter?
Thanks
      12-11-2019, 10:18 AM   #8
divadp17
divadp17's Avatar
194
Drives: e90 m3 6mt
Thanks
So for me it took 3 month due to some logistic issue they were having but they ended up giving me 50% discount which made up for the wait.
08 E90 M3 6MT
IG: divadp17
Conzyo767.50
      12-16-2019, 11:03 AM   #9
Conzyo
Pho is yummy
Conzyo's Avatar
Cool, will be doing this as well.
How was the install? Pretty easy?
      12-16-2019, 12:12 PM   #10
divadp17
divadp17's Avatar
194
Drives: e90 m3 6mt
Yea it was straight forward.
You have to remove your stock mid pipes and the heat shields.
Uninstalling your oem shifter might be a little challenging because of the limited space but its a job that can be completed in 2-3hrs.
08 E90 M3 6MT
IG: divadp17
Conzyo767.50
      12-16-2019, 12:30 PM   #11
Conzyo
Pho is yummy
Conzyo's Avatar
Thank you
      12-16-2019, 03:08 PM   #12
pbonsalb
Drives: 18 F90 M5, 99 E36 M3 Turbo
Did you use sheet metal screws, bolts and nuts, or nut serts with bolts?
      01-06-2020, 12:51 PM   #13
divadp17
divadp17's Avatar
194
Drives: e90 m3 6mt
Sorry for the late reply but I used the hardware that came with the shifter.
When installing from the top side I i used the bolt, washer, washer, nut.
08 E90 M3 6MT
IG: divadp17
      01-11-2020, 01:29 AM   #14
m3boost
m3boost's Avatar
81
Drives: e92 M3 ESS625, Bronco
I ended up using a bunch of microfiber towels zip tied around some of the points that are open and the OEM foam too completely seal it.
      04-05-2021, 03:32 PM   #15
TheLuky8
24
Drives: E90 M3
Appreciate the tip with the rubber. I just ordered mine. Where did you get that shifter boot/bezel? I think that fits the RTD so well.
      04-07-2021, 11:56 AM   #16
divadp17
divadp17's Avatar
194
Drives: e90 m3 6mt
I went to a local fabrication shop to get it made. I'm currently making my own cover in carbon fiber. I will post when completed incase anyones interested
08 E90 M3 6MT
IG: divadp17
      04-08-2021, 03:10 PM   #17
TheLuky8
24
Drives: E90 M3
I just might be. I'll keep an eye out.
      08-21-2021, 08:41 AM   #18
DoubleYellow
32
Drives: 2012 M3 ZCP
Is it ready yet? About to install mine.
      04-27-2022, 10:26 AM   #19
swhat
Drives: '11 MW E92
Anyone know if you can reduce the shift length on an RTD shifter?
      04-27-2022, 12:21 PM   #20
amrazM
mTekMods
amrazM's Avatar
Drives: like a granny.
Using a IRP shifter boot to seal the bottom of the rtd shifter.
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged
First DCT to Manual Conversion Worldwide
KW CS, BBS RI-A, BW Headers, Snow 2.5
divadp17193.50
      07-20-2022, 07:34 PM   #21
DoubleYellow
32
Drives: 2012 M3 ZCP
Attachment 2869561
Same here. My shop wasn't able to get the stock rubber seal to work so we went with the IRP boot. Works well after a little modification (see the quoted picture).
      10-09-2022, 08:11 PM   #22
airindia33
Drives: BMW M3
Great write up and adding pics. I’m ordering my shifter this week. I’m wondering if the RTD shifter has any rattles etc. I had an IRP in my other car and it rattled quite a bit. I would like to hear your review on this. Thanks
rtd
m3post
