BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      04-08-2021, 12:29 PM   #1
rebelliousfb
Drives: E92 M3
Supersprint Race vs Supersprint Race F1 difference?
I feel like I've been searching and getting varying responses to this. Does anyone know which of these two systems is the louder, more drone-y one? It will be just an axle-back system for now, connected to my stock x-pipe.
The description on the Turner Motorsports link for the F1 says the following: "The Supersprint "F1 Race" mufflers are a more dramatic sound than the standard Race muffler design."
However, this post from Supersprint themselves (albeit on the older side) seems to indicate the opposite: https://www.m3post.com/forums/showpo...8&postcount=18
Specifically, this post claims:
"The ideal configuration for an aggressive sound and very little drone is our new F1 Race mufflers. We integrated a “Helmolthz” resonator into the mufflers’ internals, which gives us the ability to reflect and cancel some frequencies depending on the structure of pipes and chambers. The F1 Race mufflers reduce the rpm range and the decibel levels of the drone and also give an intoxicating sound at high RPM!"
Can someone shed some light on which system is more refined/less drone-y?
BTW the Race setup is about $1000 cheaper than both the Performance and Race F1 systems online which is curious.
Thanks in advance!
      04-11-2021, 08:09 AM   #2
GtiGyver
GtiGyver's Avatar
69
Drives: 2009 Space Grey E90 328i MT
I had for an extremely short time the SuperSprint Race (non-F1) on my M3 with primary cats bypassed. The drone was so bad that I didn't go further than around the block and back.
I also have the 2-pipe mod OEM system and the BMW performance mufflers, both of which sound 1000x better and without drone.
      04-12-2021, 07:42 AM   #3
rebelliousfb
Drives: E92 M3
I've read that a lot about anything beyond an axle-back setup for the Race (non F1). Haven't been able to find much at all for people that have the F1 setup in an axle-back only, though the videos of a full F1 setup do seem quite loud too (understandably).
      04-15-2021, 09:10 PM   #4
6ixSpd
Save the manuals!
6ixSpd's Avatar
6016
Drives: '16 M3, '23 718 Spyder
That's rather surprising. I had SS Race + test pipes for almost two years and never felt the drone was intrusive at all, let alone intolerable. There are much louder setups out there for axle back + test pipes combos.
'16 M3 | '23 718 Spyder
Past: E92 M3, F87 M2, E39 M5, etc
      04-15-2021, 10:07 PM   #5
Bimmer Barney
Bimmer Barney's Avatar
1250
Drives: 2011.5 E90M ZCP
I have race F1. They sound amazing. More exotic than most and no drone. Just rear section and everything else is stock. Sedan.
I pass Laguna Seca dB requirement.
2011.5 E90 M3 DCT ZCP Slicktop
M3MATT91.00
      04-20-2021, 01:51 PM   #6
Ultimatemj
Ultimatemj's Avatar
Drives: 2012 E92 M3 ZCP
How about freeway roadtrip volume? I'm running catless with ACM modded OE muffler. It sounds great! Doesn't drone, but is LOUD enough you have to "talk over it" and/or turn up the tunes.
'12 E92 M3 ZCP Ruby Black Metallic, BBS E88, Ohlins R/T, Eventuri, Dinan exhaust, Tune +36whp, S752 + JL Audio XD1000/5 & 12w6v3, Dinmann
      04-20-2021, 05:24 PM   #7
Bimmer Barney
1250
No not an issue.
      04-20-2021, 07:35 PM   #8
Frozen
Frozen's Avatar
Drives: Frozen Red e92 ZCP
Interesting. No drone at all?
      04-20-2021, 08:48 PM   #9
Bimmer Barney
1250
No drone at all
      04-27-2021, 12:01 PM   #10
rebelliousfb
Drives: E92 M3
This is awesome, thanks a ton Bimmer Barney
      04-27-2021, 06:07 PM   #11
wyatth
3549
Drives: E90 ZCP
Bat-Signal derbo
Also has the F1. Sounds good on the outside. I think volume may be close to Race levels, but it should drone less given the helmholtz resonators.
      04-28-2021, 12:21 AM   #12
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
Originally Posted by wyatth View Post
Bat-Signal derbo
I'm the same setup as Barney.
SS F1 with stock x pipe. I also passed Laguna Seca sound while full throttle.
I will note there is drone under 2500 rpm. It only occurs when you are accelerating with heavy throttle and it is far from the crazy loud setups. It's very tolerable. I think it's loud enough to hear with my helmet on, but not overly loud to blow sound and the neighborhood. Freeway speeds are above 2.5k RPM and do not have drone. You can enjoy a conversation without raising your voice.
IG:ruhrohz_m3
Journal: Link
E9x ZCP Suspension Info: Link
Track Chat Discord: https://discord.gg/VsKbTyqBVj
SF Bay Area: DM For coding services
      03-11-2024, 07:19 PM   #13
M3MATT
M3MATT's Avatar
91
Drives: E92 M3
2012 E92 M3 ZCP  [10.00]
Did you like it? Any sound clips?
      03-11-2024, 09:07 PM   #14
GinTonic
126
Drives: E92 M3
SS Race, test pipes, AFE air filter, and Epic tune. Above 3k its sweet. Below 3k and higher gears can be a bitch especially with a passenger in the car. But, its the best looking exhaust for this car, and Supersprint quality is hard to beat. The polished stainless steel looks money too. Ignore the whistling noise in the background, pulleys needed replacement when i recorded this video, and it's before I did underdrive pulleys. They are worth their own weight, if you don't already have them.
      03-12-2024, 11:57 AM   #15
M3MATT
M3MATT's Avatar
91
Drives: E92 M3
Originally Posted by GinTonic View Post
SS Race, test pipes, AFE air filter, and Epic tune. Above 3k its sweet. Below 3k and higher gears can be a bitch especially with a passenger in the car. But, its the best looking exhaust for this car, and Supersprint quality is hard to beat. The polished stainless steel looks money too. Ignore the whistling noise in the background, pulleys needed replacement when i recorded this video, and it's before I did underdrive pulleys. They are worth their own weight, if you don't already have them. https://www.youtube.com/watch?v=gOMBGVciaKM
Is there a lot of drone? Like is it comfy driving for hours on end on the highway?
      03-13-2024, 03:30 AM   #16
--Aramis--
124
Drives: M3
I have the full setup SS F1, HFC, mid section with resonator and F1 Race Mufflers
Sound is pur porn when you open throttles bodies and near quiet like OEM at stabilized speeds
I do mountain and highways drivings, with this setup you could do 4 or 6 hour highway journeys without any problems
Setup is expensive but top class
Appreciate 3
M3MATT91.00
Tuner199.00
      03-13-2024, 11:18 AM   #17
smokinjoe64
Naval Aviator
smokinjoe64's Avatar
Drives: 12 e92 M3 6MT
Talking
Welp...pulled the trigger today!
Purchased SS F1s
Ordered direct from SS, 20% off, free air shipping, ~2-wk delivery
Appreciate the Community feedback/posts; definitely influenced selection!!!
derbo
omgzirra_exe
Bimmer Barney
Upgraded tips...
e92 M3 - Interlagos Blue | Recaros w/Fox Red Extended |Carbon Leather
Performance Mods: Alpine Stage II; SuperSprint F1s; Cat-less Bomiz X-Pipe; aFe CAI; Bilstein B16s w/EDC; Brembo BBK; AutoSolutions SSK
      03-13-2024, 02:18 PM   #18
GinTonic
126
Drives: E92 M3
Its not overly obnoxious. I've learned to over come it or just drop down a gear. It' not like a Gintani exhaust.
M3MATT91.00
      03-13-2024, 02:26 PM   #19
smokinjoe64
Naval Aviator
Originally Posted by --Aramis-- View Post
"Sound is pure porn when you open throttles bodies and near quiet like OEM at stabilized speeds"
Exactly, my 'target' too ...pure ear & eye porn
      04-13-2024, 01:08 PM   #20
smokinjoe64
Naval Aviator
Thumbs down Suspersprint Fail
UNBELIEVABLE!!!
Direct ordered from SS, a set of F1 Race axle-back.
After 16 days to fab, a 9-day US Customs clearance delay due to SS incomplete, inaccurate, documentation...the f'in left side shows up with foreign object trapped inside canister.
Hard to believe the fabricators, QA, and packing personnel could miss the unmistakable rattling with ANY handling/movement.
[wish upload here were possible to hear it]
Attempts to dislodge unsuccessful; tried to ‘shake out’, also used automotive magnetic pick-up tool.
Whatever it is rolls, rattles, clanks around...unusable
Wrote SS an email with pic and audio file. Awaiting response and effort by SS to remedy...Epic fail & disappointment
Oh BTW - - these don't fit F1s either:
https://www.m3post.com/forums/showpo...5&postcount=17
m3post
