BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
BPM
      02-02-2014, 04:41 PM   #45
tmntmn
///M
Drives: e92 M3/M-DCT
can you check what 273A error code is?
Thanks
THANKS TO:~<RPM>~ ~<SONICMS>~ ~<MODECARBON>~ ~<McKennaPerformance>~
MODS: MODECARBON V2 GTS FRONT LIP & REAR DIFFUSER, AA GREEN FILTER, RPI SCOOPS, PSW, Verstraβe Extended DCT Shifter, ZCP WHEELS (SEMI-GLOSS), OHLINS R&T, Megan Exhaust, AKRA XPIPE, BMW LED INTERIOR, BLACKOUT W/ORION V4 LED AE, OSRAM CBI
      02-02-2014, 11:25 PM   #46
regular guy
Drives: Sprint car
273a - P2271, 273a - P0136, 273A - P013E, 273A - P2270
273A - P2271
273A - P2271
Information saved inDME
Fault code273A - P2271
Fault textOxygen sensor vibration check behind catalytic converter, bank 1
Fault descriptionO2 Sensor Signal Biased/Stuck Rich (Bank 1 Sensor 2)
Condition for fault identificationTest condition: Trim control suspicion with observation of P component and I component leads to guided LEAN control; if the post-cat oxygen sensor signal fails to respond accordingly, the error is assigned to the post-cat oxygen sensor
Terminal condition: Engine running
Voltage condition: none
Condition for fault memory entryAfter K_LAVK_OBD_ACT_NK_M_CNT (1x) LEAN control events the oxygen sensor remains stuck at RICH
Action in service1. Check exhaust system for leaks
2. If OK, replace post-cat oxygen sensor LSNK B1
Fault effect and breakdown warningMIL on after engine runs 2x / no effects on drivability
Driver informationWarning light: MIL
Service instructionNone
273A - P0136
273A - P0136
Fault code273A - P0136
Fault descriptionO2 Sensor Circuit (Bank 1 Sensor 2)
Condition for fault identificationTest condition: Oxygen sensor signal too low, lower than threshold 649 mV (K_LANK_OBD_S_VL_US) for 2 (K_LANK_OBD_S_CNT) /K_LANK_OBD_S_AUTOM_CNT requests
Condition for fault memory entryTime K_LANK_OBD_S_SA_T (3s) after SA for K_LANK_OBD_S_CNT (2x) /K_LANK_OBD_S_AUTOM_CNT (3x) tries
273A - P013E
273A - P013E
Fault code273A - P013E
Fault descriptionO2 Sensor Delayed Response - Rich to Lean (Bank 1 Sensor 2)
Condition for fault identificationTest condition: * Determine whether oxygen sensor voltage remains above 151 mV (K_LANK_OBD_S_SA_US) * Fault after 2 (K_LANK_OBD_S_CNT)/K_LANK_OBD_S_AUTOM_CNT attempts
Condition for fault memory entryFull-load for K_LANK_OBD_S_VL_T (6s) for K_LANK_OBD_S_CNT (2x) /K_LANK_OBD_S_AUTOM_CNT (3x) attempts
273A - P2270
273A - P2270
Fault code273A - P2270
Fault descriptionO2 Sensor Signal Biased/Stuck Lean (Bank 1 Sensor 2)
Condition for fault identificationTest condition: Trim control suspicion with observation of P component and I component laeds to guided RICH control; if the post-cat oxygen sensor signal fails to respond accordingly, the error is assigned to the post-cat oxygen sensor
Condition for fault memory entryAfter K_LAVK_OBD_ACT_NK_F_CNT (1x) RICH control events the oxygen sensor sticks at LEAN
      02-06-2014, 12:23 PM   #47
MDIAU
MDIAU's Avatar
42
Drives: 2009 AW e92M
Could you help me with code P2626 Bank1 Sensor1? I'm assuming it's the precat o2 sensor.
Thanks in advance!
Cayenne "wifey"
M3 "mine"
Previous toys: 997.1 GT3, C63, e92M3, 350Z, ISF, IS350, B5 S4, R1/Ninja 636
      02-08-2014, 01:01 PM   #48
regular guy
Drives: Sprint car
Thanks in advance!
Most likely you're looking for 2b26. The display in a lot of code readers make it hard to tell the difference between "b" and "6."
2B26 - P155D, Post-44
      02-23-2014, 10:18 AM   #49
regular guy
Drives: Sprint car
2b16 - P1630, 2b16 - P210a, 2b16 - P0639
2B16 - P1630
2B16 - P1630
Fault code2B16 - P1630
Fault textThrottle-valve actuator, governor monitoring, bank 2
Fault descriptionThrottle Valve Circuit (Bank 2)
Condition for fault identificationTest condition: Actuator shifts to Failsafe mode
Terminal condition: TERM87
Condition for fault memory entry10 ms
Action in service1. Clear fault memory, conduct EDR electronic throttle control system test,
2. Check plug and wiring harness at DKG2 and EDR2,
3. Replace DKG2 or EDR Bank 2
Fault effect and breakdown warningCC message
Engine speed limited
Reduced power
MIL after engine runs 2x
Driver informationWarning light: MIL, EML, CC message, backup program
2B16 - P210A
2B16 - P210A
Fault code2B16 - P210A
Fault descriptionThrottle Actuator 'B' Control Motor Circuit/Open
Reduced power
2B16 - P0639
2B16 - P0639
Fault code2B16 - P0639
Fault descriptionThrottle Actuator Control Range/Performance (Bank 2)
Condition for fault identificationTest condition: Actuator reports system error
Reduced power
2B16 - P0639
2B16 - P0639
4. With UMWB engine protection check throttle valve assembly for stiction
Reduced power
      02-24-2014, 09:09 PM   #50
regular guy
Drives: Sprint car
2b0d - P152c, 2b0d - P152d, 2b0d - P152e, 2b0d - P152f
2B0D - P152C
2B0D - P152C
Fault code2B0D - P152C
Fault textIdle actuator monitoring, bank 1
Fault descriptionIdle-Speed Control Valve Monitoring Dissimilar Desired Values (Bank 1)
Condition for fault identificationTest condition: Difference too large
Voltage condition: Battery voltage > 6.8V (k_egas_can_ed_ub_min)
Condition for fault memory entry300 ms
Action in service1. Clear fault memory, LLS idle actuator system test
2. Check LLS1 voltage supply
3. Replace LLS1
Fault effect and breakdown warningDSC lamp / CC message / engine speed limited to 5000 rpm / reduced power / engine start may be possible only with use of accelerator pedal
2B0D - P152D
2B0D - P152D
Fault code2B0D - P152D
Fault descriptionIdle-Speed Control Valve Monitoring Incorrect Actual Value (Bank 1)
Condition for fault identificationTest condition: Error detection received via CAN
Condition for fault memory entry100 ms
3. Replace LLS1
2B0D - P152E
2B0D - P152E
Fault code2B0D - P152E
Fault descriptionIdle-Speed Control Valve Monitoring Actual Value / Desired Value Correlation (Bank 1)
Condition for fault memory entry350 ms
3. Replace LLS1
2B0D - P152F
2B0D - P152F
Fault code2B0D - P152F
Fault descriptionIdle-Speed Control Valve Monitoring Reset Error (Bank 1)
Condition for fault identificationTest condition: Not identical for too long
Condition for fault memory entry250 ms
3. Replace LLS1
      02-26-2014, 09:50 AM   #51
regular guy
Drives: Sprint car
27af - P1411
27AF - P1411
27AF - P1411
Fault code27AF - P1411
Fault textSecondary-air pump
Fault descriptionSecondary Air Pump No Activity Detected
Condition for fault identificationTest condition: sls_obdh_mdf_max_intg_norm (after 20s) < KL_SLS_OBDH_HFM_DIAG_MIN & > K_SLS_OBDH_SLP_DEF or
sls_obdh_mdf_max_intg_norm (after 20 sec.) < KL_SLS_OBDH_HFM_DIAG_MIN & < K_SLS_OBDH_SLP_DEF & exhaust lamda not high
Voltage condition: Battery voltage > 10.8 V (k_sls_obd_ub_min)
Condition for fault memory entry30000 ms
Action in service1. Check wiring to secondary air pump
2. Check plugs and wiring harness on secondary air pump
3. If OK, remove secondary air pump relay, and connect the two terminals (30 and 87) in the socket with ignition on, if secondary air pump still does not start, it is defective, replace secondary air pump.
4. If secondary air pump
Fault effect and breakdown warningMIL is on after 2x engine cold start
      02-26-2014, 05:45 PM   #52
Bx Tpr
Bx Tpr's Avatar
123
Drives: 23 CSL
Fault code 5A43? Came up for my DCT once.
Can't find it anywhere.
      02-26-2014, 08:15 PM   #53
regular guy
Drives: Sprint car
Sorry, I only have ECU fault codes, not tranny fault codes.
      02-26-2014, 09:06 PM   #54
Bx Tpr
Bx Tpr's Avatar
123
Drives: 23 CSL
Any idea where I can find tranny fault codes other than the dealership?
      02-26-2014, 09:29 PM   #55
BPMSport
BPMSport's Avatar
Drives: Harrop M3 / F10 M5 / F82 M4
2000 BMW M5  [0.00]
1990 BMW 735i Turbo  [0.00]
2008 BMW M3  [7.50]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
We can read them remotely if needed. Other than that, an independent shop with a BMW specific tool should be able to.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |-----
----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133----
      02-26-2014, 09:36 PM   #56
BPMSport
BPMSport's Avatar
2000 BMW M5  [0.00]
2008 BMW M3  [7.50]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
5A43: DCT Pressure sensor, clutch 2, total failure
This could mean that the pressure sensor is reporting incorrect values, that the pressure sensor circuit has shorted or that the circuit is open.
First thing to do is to read the sensor data from pressure sensor on clutch 2. It's supposed to be within .2 and 1.8 bar pressure.
If the pressure sensor is reporting incorrectly, it needs to be replaced.
Otherwise there is a hardware issue or fluid issue.
This fault will cause clutch circuit 2 to be turned off, which will prevent selection of gears 2, 4 and 6.
Hope this helps.
      02-26-2014, 09:51 PM   #57
Bx Tpr
Bx Tpr's Avatar
123
Drives: 23 CSL
Hope this helps.
It absolutely did! Sending you another PM regarding this.
      02-27-2014, 12:32 AM   #58
Brian_Fantana
Brian_Fantana's Avatar
Drives: 09 Alpine white E90 M3 DCT
2009 M3  [0.00]
How about 27c3? I thought it was the gas cap but just bought one and it came back. Then read it was the dtml pump but read another guy had this code and replaced his pump but it didn't fix it. His last resort was a leak somewhere in his exhaust and he needed a smoke machine.
They've done studies, you know. Sixty percent of the time, it works every time. ~ Brian Fantana
      02-27-2014, 12:58 AM   #59
regular guy
Drives: Sprint car
27c3 - P0456
27C3 - P0456
27C3 - P0456
Fault code27C3 - P0456
Fault textDMTL leakage detection
Fault descriptionEvaporative Emission System Leak Detected (very small leak)
Condition for fault identificationTest condition: Current rise during diagnosis less than (dmtl_i_ref - dmtl_i_min) x KL_DMTL_I_REF_KORR + dmtl_i_min
Terminal condition: TERM15 off
Voltage condition: 11V < UBatt < 14.5V (k_dmtl_ub_min ; k_dmtl_ub_max), with start using tester: None
Condition for fault memory entrynone
Action in service1. Check filler cap seal
2. Pressurize tank and search for leaks
Fault effect and breakdown warningCC message / possible gasoline odor
Driver informationWarning light: MIL, EML, default program
      03-02-2014, 02:42 PM   #60
regular guy
Drives: Sprint car
2739 - P2433, 2739 - P2432, 2739 - P2430
2739 - P2433
2739 - P2433
Fault code2739 - P2433
Fault textAir-mass sensor, secondary air, electrical diagnosis
Fault descriptionSecondary Air Injection System Air Flow/Pressure Sensor Circuit High (Bank 1)
Condition for fault identificationTest condition: Air mass > 70 kg/h (K_SL_ML_HFM_DIAG_MAX)
Voltage condition: None
Condition for fault memory entry5 ms
Action in service1. Check plug and wiring harness on Mini-HFM
2. Replace Mini-HFM
2739 - P2432
2739 - P2432
Fault code2739 - P2432
Fault descriptionSecondary Air Injection System Air Flow/Pressure Sensor Circuit Low (Bank 1)
Condition for fault identificationTest condition: Air mass < -10kg/h (K_SL_ML_HFM_DIAG_MIN)
2. Replace Mini-HFM
2739 - P2430
2739 - P2430
Fault code2739 - P2430
Fault descriptionSecondary Air Injection System Air Flow/Pressure Sensor Circuit (Bank 1)
Condition for fault identificationTest condition: Air mass > 0.5 kg/h (K_SL_ML_HFM_OFFSET_MIN)
Terminal condition: Engine off
2. Replace Mini-HFM
      03-02-2014, 02:49 PM   #61
regular guy
Drives: Sprint car
2743 - P0155
2743 - P0155
2743 - P0155
Fault code2743 - P0155
Fault textOxygen sensor heater resistance diagnosis before cat. converter, bank 2
Fault descriptionO2 Sensor Heater Circuit (Bank 2 Sensor 1)
Condition for fault identificationTest condition: The upper or lower threshold of the resistance values has been violated, above/below 6.0 ohms (K_LSHVK_DIAG_RU) 14.5 ohms (K_LSHVK_DIAG_RO)
Voltage condition: Battery voltage > 9V (k_ed_ubmin)
Condition for fault memory entrymin. K_LSHVK_DIAG_ANZ_MESS (100) valid calculations of heater resistance - roughly.1.5 sec.
Action in service1. DME software release must be more recent than 07-06-510, fix incorporated since 07-09-521
2. Check plug, wiring harness on pre-cat oxygen sensor LSVK B2,
3. If OK, replace oxygen sensor
Fault effect and breakdown warningMIL lamp on after engine runs 2x /Small influence on drivability
      03-02-2014, 02:50 PM   #62
Amirsm3
Amirsm3's Avatar
514
Drives: 2011 Space Grey e90 M3
Wow, thanks for the detailed descriptions! Definitely gonna keep this handy in case something happens and I pop a CEL.
2011 e90 M3 Space Grey DCT ZCP- eAs, BMW Performance, Agency Power, Macht Schnell, iND, Milltek, Volk, Challenge, Stoptech, Ohlins
BMWCCA:518970
      03-09-2014, 08:53 PM   #63
tmntmn
///M
Do you know what codes 2789 and 278a are
Thanks
      03-12-2014, 11:18 PM   #64
regular guy
Drives: Sprint car
273e - P0030
273E - P0030
273E - P0030
Fault code273E - P0030
Fault textOxygen sensor final stage diagnosis heater before cat. converter, bank 1
Fault descriptionHO2S Heater Control Circuit (Bank 1 Sensor 1)
Condition for fault identificationTest condition: Driver info includes OPENLOAD
Terminal condition: none
Condition for fault memory entry5000 ms
Action in service1. Check plug and wiring harness on pre-cat oxygen sensor LSVK B1,
2. If OK replace oxygen sensor
      03-12-2014, 11:37 PM   #65
regular guy
Drives: Sprint car
273f - P0050
273F - P0050
273F - P0050
Fault code273F - P0050
Fault textOxygen sensor final stage diagnosis heater before cat. converter, bank 2
Fault descriptionHO2S Heater Control Circuit (Bank 2 Sensor 1)
Action in service1. Check plug and wiring harness on pre-cat oxygen sensor LSVK B2,
      03-12-2014, 11:41 PM   #66
regular guy
Drives: Sprint car
2724 - P0132
2724 - P0132
2724 - P0132
Fault code2724 - P0132
Fault textOxygen sensor, signal before cat., bank 1
Fault descriptionO2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
Condition for fault identificationTest condition: lavk_atic42_pin_diag_b1 BIT1 or BIT3 or BIT5 or BIT7 set
Condition for fault memory entry3000 ms
m3post
