BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > FIXED :) water in battery well caused corrosion... [see post #19]
      03-03-2014, 11:44 AM   #23
hmpmarketing
BMW Fan
hmpmarketing's Avatar
17
Drives: E93
Originally Posted by achu View Post
i feel like the whole water in the battery well isn't taken as seriously as it should be! people say it too casually lol...
anyways, i found more water down below the battery tray and what i saw after scared the shit out of me... how it did not short or blow up, i have no idea but check this out:
those were the +ve connections at the bottom by the battery :\
when i tried to clean it up the thicker wire just broke off :|
anyways, i used brake cleaner to take out all the crap and wiped it all down... clipped the corroded bits off the wires and recrimped them and applied heatshrink and this is how it finished:
everything connected up and the car was fine
and i closed myself in the boot and looked around with a torch as a friend hosed the car to spot where the leak was coming from... turns out the boot rubber sealing around the trunk was caught somewhere which misshaped it and it let droplets of water through... ordered a new one and put some silicone in its place as a temp fix... left the battery open to let the area dry out properly...
i didn't need a new battery in the end! i'm gonna try get my old one back and keep it as a spare or recharge it then sell it... get back some of the unnecessary money i spent! the fix in the end was technically free!
anyways, i feel like everybody should check the battery area for water cos this shit could fvck up your whole car!
hope i helped!
It looks exactly like mine did
      03-03-2014, 04:52 PM   #24
achu
103
Drives: E93 335i
Originally Posted by hmpmarketing View Post
Really glad!!!!
Also maybe we should meet sometime and get a photoshoot done together? what u say
aha you're in my area as well, come down to the meet on the 9th?
i'll be there taking photos...
PAST: 2007 E93 335i 6MT
NOW: 2012 F10 M5
Facebook: Achu Ckr|Twitter: AchuCkr|Instagram: AchuCKR|Flickr: AchuCKR|G+: achu.ckr
THE BUILD THREAD|COMPILATION OF PHOTOS
      03-04-2014, 02:40 AM   #25
Josh1a1h
170
Drives: AzuriteBlack 335i E92
Wow that is terrible!
So this was a leak through the boot? Not the LCI Lights?
Was this due to the CSL Boot? Or do you think it was happening with the stock boot?
Your car must be faster now it isn't carrying around 6L of water
But glad you sorted this mate. I may check mine on the weekend
      03-04-2014, 02:52 AM   #26
achu
103
Drives: E93 335i
nahh through the boot... a bit of the seal around the mouth of the boot wasn't holding properly and let water through... i think i bought the car like that you know...
it's actually a common problem, google it, coupes estates and saloons get it! definitely worth a check...
NOW: 2012 F10 M5
      03-04-2014, 03:12 AM   #27
Josh1a1h
170
Got a pic of the spot?
      03-04-2014, 01:02 PM   #28
achu
103
Drives: E93 335i
i doubt i'll be able to take one this week! but i will post it up when i do
NOW: 2012 F10 M5
      03-05-2014, 01:53 AM   #29
Flywalker
Drives: 123d
Was there any signs of moisture in the car asides from what you found when you removed the battery ? ie car misting up or a damp smell ?
      03-05-2014, 02:33 AM   #30
achu
103
Drives: E93 335i
nope nothing at all inside the cabin... but the tray under the cover on top of the battery would get moist and only when i saw that, I realised water has been leaking in....
NOW: 2012 F10 M5
      03-05-2014, 03:25 AM   #31
Dizzle
Dizzle's Avatar
56
Drives: F30 335xD
Good work lad
      03-05-2014, 06:07 PM   #32
Flywalker
Drives: 123d
I better have a good look around the battery at the weekend.
Thanks for the 'heads up'
      03-06-2014, 12:08 PM   #33
Alfamale
Drives: 335i E93
Same damn thing happened to me yesterday car wouldn't start, jumped started fine, got it to garage to replace battery only to find its sat in 3" of water!
Main cable underneath completely corroded away. BMW wanted £100 new cable, garage ended up striping cable back and soldering on new connector.
BMW mechanic advised to drill a couple of holes through battery tray for water to drain away.
Bloody car has only just turned 30k miles so can't believe this has happened.
      03-06-2014, 01:03 PM   #34
achu
103
Drives: E93 335i
[IMG]http://img.photobucket.com/albums/v4...psijjp55df.jpg[/IMG]
please don't do that, that a fix for the symptom not a fix of the cause... water will still be passing through that area and something worse could happen...
first check your drainage points under the mudflaps... if they are clear, something else is making water go to that area, lie in the boot in a foetal position (yes it sounds stupid but trust me) and ask someone to hose the car down and look for the leak with a torch... and then fix that!
NOW: 2012 F10 M5
      03-06-2014, 03:28 PM   #35
Alfamale
Drives: 335i E93
Agreed, new boot seal ordered too but is 5-6 day delivery from BMW.
      03-07-2014, 03:37 AM   #36
Josh1a1h
170
Stand outside with an umbrella?
Gd luck in fixing!!!
      03-07-2014, 03:41 AM   #37
Alfamale
Drives: 335i E93
LOL garage said its a tiny leak that been building up for sometime so couple of days won't hurt. Plus they drilled the drain holes as per the BMW recommendation.
      03-08-2014, 10:53 AM   #38
hmpmarketing
BMW Fan
17
Drives: E93
Seems this is a common thing now after a long season of rain!!!
      01-14-2020, 01:45 PM   #39
7shivagens
Drives: 2007 BMW 335i Convertible E93
Water in battery well, need help on what should it cost to repair.
335i_cab
I have a BMW 335i convertible, and the same thing happened to me.. the car wouldn't start after heavy rains, got it towed to BMW dealer, they found water in battery well, +ve terminal rusted (see picture), and they refused to repair, and asked me to take it to a body shop. They are saying it will require the battery well tray to be replaced, cut out and welded, etc,
Any help on what it should cost to repair, and how you resolved your issue, would be greatly appreciated.
      01-22-2021, 01:20 AM   #40
pbedrosi
pbedrosi's Avatar
Drives: BMW E91
Just fixed mine, but did create other issues with the cables, but ended up sealing the entry point of the positive cables.
Mine looked horrible, but cleaned up decently. Still trying to diagnose the no-start. I doubt your pan is rusted enough for a pan replacement.
https://www.e90post.com/forums/showt...1#post27145947
      05-13-2022, 02:45 AM   #41
Aode06
Drives: E92
This post has to revived. This is not a complete repair.
You have to jack the car up,remove the rear passenger tire, clean and repair the other 2 terminals ON THE OUTSIDE OF THE CAR. Or have a car audio shop crimp and solder 0guage wiring and discard your BMW conectors and run new holes through the rear panel with groomets.
      01-23-2024, 10:25 AM   #42
kurtyboy
Drives: bmw 2011 320d cabriolet
Can anyone tell me how easy it is to change the positive battery terminal to the bulk head near wheel arch. I’ve had the water issue but was 10-12 inches high covered 2/3 of the battery. After investigating? And a new battery later still not working so as everyone states it starts okay on the jump + in engine bay. Found cable totally rusted through. Any pics on how they secure to the bulkhead or advice please. Thanks in advance
Hi
