TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > cmbe92guy's 8hp swap
      02-08-2024, 02:22 PM   #23
cmbe92guy
cmbe92guy's Avatar
Drives: 2011 e92 335i xdrive
I have not got the paddle shifters working yet. I’m waiting to get a DCT M3 steering wheel before I wire them in. Trying to limit the amount of times I have to get under the dash lol.
Question: what trans option should I check on MHD? I’m just running an OTS tune right now. It feels like I’m getting some throttle closures at WOT not present before the swap. Rail pressure is fine. Should I let the DME mess with torque if I’m on the stock TCU tune? Maybe it’s something with the gearing that makes the car feel like it’s down on power in the higher gears.
I mean not to overlook your question. The ptcan code is annoying me too. I’ll let you know if I find a fix.
      02-08-2024, 02:41 PM   #24
Keystonezzzzz
Keystonezzzzz's Avatar
Drives: 2013 E92 335i Xdrive
I also hit a “torque” limiter depending on the gear, i’m single turbo with custom tune tho. so i’m not sure i just have xhp tuned auto selected in mhd + custom tune. The torque correction is WAY off tho i think and i’ll get throttle closures when WOT in 5-6-7-8 any long gears.
      02-08-2024, 03:36 PM   #25
cmbe92guy
cmbe92guy's Avatar
Okay good that we’re in the same boat. It seems that the trans is happier rowing through the lower gears accelerating than through the higher gears (5,6,7) at speed. It makes sense that this has something to do with torque simulation. Are you on the stock TCU tune? I wonder how we can improve the torque simulation.
      02-08-2024, 03:38 PM   #26
Keystonezzzzz
Honestly not sure tune wise, I’ve tried flashing xhp but it’s almost like the trans doesn’t properly store the flash or something, it’ll save some options and other things it won’t. it’s weird
      02-08-2024, 05:41 PM   #27
colorado.e9x
eBay Special
colorado.e9x's Avatar
Drives: E90 330xi
2007 BMW 328xi  [9.50]
2006 BMW 330xi  [10.00]
Have you tried going through Sutphin? He makes custom tunes through xHP
Common sense is a flower that does not bloom in everyone's garden
      03-04-2024, 09:57 PM   #28
siado
Drives: 128
I'm planning this swap now on a 128. Any issues with the trans mount? I assume the rear bracket from the 8HP45 mates to the 6HP cross brace?
      03-06-2024, 01:01 PM   #29
cmbe92guy
cmbe92guy's Avatar
I used the stock atc300 t case with the factory trans mount. I’m haven’t done much research on 1ers.
      03-06-2024, 09:21 PM   #30
siado
Drives: 128
Oh, right...duh. Keeping the xfr case keeps the rear mount.
      04-10-2024, 01:43 AM   #31
Arthuar
Drives: BMW E91 330xd 2007
admiring the job done
cmbe92guy
Absolutely wonderful "wiki" thread you wrote.
I am going , even though a bit scared, to do the same with an E83 car, considered the platform it's the same at th end of story.
sent some small message months ago with Kenneth, and it's doable.
I will like to know if any update with the gears showed happen.
some gears lever hole photo might be useful either..
Obviously, we need a video on downshifting !
very very Well done
      04-15-2024, 07:28 PM   #32
cmbe92guy
cmbe92guy's Avatar
Originally Posted by Arthuar View Post
cmbe92guy
very very Well done
Thanks for the feedback man—good luck on the x1 project. So far I have not gotten the dash to correctly display gear. Someone in the CANTCU Facebook group directed me to some coding that seems like the fix I’m searching for— see attachment. Right now, I’m reverting back to the e9x stock trans cooler set up. My AM t stat/Rad keeps the trans too cool for my liking. Will soon be flashing the trans with XHP— Kenneth said that should fix my torque limiter problem. A buddy is also testing out a new CANTCU logic that should take care of the PT-CAN issues. Things are coming together…finishing a project is always the longest step.
      04-24-2024, 10:58 PM   #33
EJLew3221
EJLew3221's Avatar
Drives: 2011 335i N55 Xdrive
@cmbe92guy could you please email me. I own a 2011 335i xdrive. I have a 6 speed automatic that is not in the best shape. I have a spare 535i 2013(I think) xdrive 8 speed automatic transmission. Could I use the steps you used? Please email me @ejlew3221@gmail.com. Thank you.
      04-25-2024, 04:33 PM   #34
tlow98
Drives: 2009 E91, 2014 F15 x35i
Love this idea! How did driveshaft go? Did you have to go custom?
      04-27-2024, 08:46 PM   #35
cmbe92guy
cmbe92guy's Avatar
Stock driveshaft and stock tcase bolt up to the back of the 8hp
      04-27-2024, 08:47 PM   #36
cmbe92guy
cmbe92guy's Avatar
The Canformance wiki page (google it) has a step-by-step guide for CANTCU installation. Removal/install of the transmission can be found on YouTube.
